JRSC install - Page 10 - Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum
Old 01-05-2012, 01:50 AM   #91
2KZX3
2KZX3's Avatar
Fan#: 33342
What I Drive: 2000 Twilight Blue ZX3 Jrsc
FF Reputation: 4 2KZX3 Good Standing Member
Buy-Sell-Trade Rating: (9)
That's definitely an M45 supercharger which is for the standard zetec, the m62 is for the svt its bigger and won't line up with your manifold. Are you hearing the belt slip mine would squeal for a second when it would slip, and you could actually see my boost drop when it would start slipping.
Float like a Cadillac, Sting like a Bimmer
ATX Crew #1
2000 JRSC BBK ZX3 - The Little Blue Rocket
2000 SE Sedan - Great White = Traded
1990 Chevy 1500 6" lift Monster Truck
2KZX3 is offline
Old 01-05-2012, 08:38 AM   #92
xy0s08
xy0s08's Avatar
Fan#: 65298
What I Drive: 00 ZX3 Kona, 00 ZX3, 04 SVTF
Points 4,484, Level 42
Points: 4,484, Level: 42 Points: 4,484, Level: 42 Points: 4,484, Level: 42
Level Up 67% Completed
FF Reputation: 7 xy0s08 Good Standing Member
No i do not see the boost dropping I can only get about 3 psi of boost max. I don't really notice any squealing
MARCH ROTM 2010 Midwest crew #58
9/11 was an inside job! fluoride is poisoning all of you! The Federal Reserve is a private bank that is making fake money and bankrupting America! Open your eyes to what is going on in the US! Infowars.com
xy0s08 is offline
Old 01-05-2012, 03:17 PM   #93
egman2005
Slow n lifted
egman2005's Avatar
Fan#: 44983
What I Drive: 2003 SVT Focus
Points 9,658, Level 66
Points: 9,658, Level: 66 Points: 9,658, Level: 66 Points: 9,658, Level: 66
Level Up 2% Completed
Forum Activity 5%
FF Reputation: 21 egman2005 Great Standing Member
Buy-Sell-Trade Rating: (7)
Try your stock intake. That blower has to work hard for the air with that cold air intake
Originally Posted by I <3 my ZX3 View Post
ed is right.
egman2005 is online now
Old 01-05-2012, 03:51 PM   #94
forddorf
Fan#: 31248
What I Drive: 2001 malibu blue zx3 / turbo-2004
Points 925, Level 16
Points: 925, Level: 16 Points: 925, Level: 16 Points: 925, Level: 16
Level Up 25% Completed
Level up: 25% Level up: 25% Level up: 25%
FF Reputation: 3 forddorf Good Standing Member
Here are my pulley sizes (these are measured to outside of the shoulders and are close measurements not exact, inside diam. will be smaller).
SC snout pulley (yours) 3"
Belt idler pulley 2 11/16" right side of sc (facing the sc snout from passenger side of the car)
Power steering pulley 5"
AC pulley 5 3/4"
Crankshaft pulley 5 1/8"
Water pump pulley 4"
Belt tensioner pulley 2 3/4"
Idler pulley 2" left side of the sc (facing the sc snout from the passenger side of the car)
Alternator/generator pulley 2"
forddorf is offline
Old 01-24-2012, 06:06 PM   #95
xy0s08
xy0s08's Avatar
Fan#: 65298
okay i tried the other intake today and i am still only getting 3 psi of boost
xy0s08 is offline
Old 01-25-2012, 03:02 AM   #96
Dago
Dago's Avatar
Fan#: 33842
What I Drive: 2004 comp orange svt
Points 4,550, Level 42
Points: 4,550, Level: 42 Points: 4,550, Level: 42 Points: 4,550, Level: 42
Level Up 50% Completed
FF Reputation: 1 Dago Good Standing Member
IMHO your supercharger is been under driven, that's why you are only making 3 psi, I also think your idler pulley is bigger ( not the one from the jrsc kit but the one from the car) therefore your issues with the belt size and also with the jrsc been under driven, the longer the belt the least rpm your accessories get
JRSC BBK tuned by Tom, 65mm TB, 180 deg thermostat, aem wideband, 9mm ford racing wires, removed lunchbox, CFM hfc, front suspension polyurethane bushings, hella dynabeam headlights, keenwood ddx512
John 3:16
Dago is offline
Old 01-25-2012, 05:19 PM   #97
iceberg65
Fan#: 64382
What I Drive: 00 laser red cougar
FF Reputation: 2 iceberg65 Good Standing Member
Belt length doesn't determine how fast a given pulley spins.
Having a larger Idler pulley would simply mean that that Idler would see less RPM's. It could explain the belt length issue though. I know I had to reef on my tensioner pretty good to get enough space to fit my belt on.
The formula for how fast a given pulley spins is:
Crank pulley Diameter/ diameter of pulley your calculating RPM for= Pulley ratio (for each rotation of the crank, this pulley rotates x times)
Pulley ratio* engine RPM = pulley RPM
So the only way the blower would be under-driven is if he has a smaller then stock crank pulley or a larger blower pulley.
iceberg65 is offline
Old 01-26-2012, 05:45 PM   #98
Rod H
Rod H's Avatar
Fan#: 53555
What I Drive: 1959 Austin Healey (Zetec Engine)
FF Reputation: 1 Rod H Good Standing Member
Just a shot in the dark, but are you running stock cams? if not, what is your overlap?
If you are absoulutely certain that you have no vacuum leaks, I would change your pulleys to the large crank, smaller S/C ones, if you do not see significant improvement in boost, your s/c is not producing boost. Any chance someone did a home port job on it?
just thinking out loud, we kinda.
Rod
ps: I will have an m45 s/c for sale soon if yours turns out to be bad.
Rod H
The older I get the more cynical I become, but, I can't keep up
Rod H is offline
Old 01-26-2012, 08:17 PM   #99
xy0s08
xy0s08's Avatar
Fan#: 65298
I have stock cams in my car. And I am pretty sure its the stock crank pulley (I've never changed it) and I have no clue if some one did a home port job.
xy0s08 is offline
Old 01-27-2012, 09:47 AM   #100
Rod H
Rod H's Avatar
Fan#: 53555
You may have a vacuum/pressure leak which is not showing up until you are under boost.
I had the same conditon when I did my set-up I ended up using a manifold/head gasket from retroford and trimming it for the fuel injectors. Moss does not sell the intake/head gasket.
Here's a link: http://www.retro-ford.co.uk/shop/node/209
Rod H
Rod H is offline
