How can I force the revs to hang? - Page 2 - Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum
Old 08-03-2011, 09:17 PM   #11
Paladin
VEKTOR PLATE
Paladin's Avatar
Fan#: 64465
What I Drive: blue sub #6
Points 5,736, Level 48
Points: 5,736, Level: 48 Points: 5,736, Level: 48 Points: 5,736, Level: 48
Level Up 93% Completed
Level up: 93% Level up: 93% Level up: 93%
Forum Activity 3%
FF Reputation: 10 Paladin Great Standing Member
I can see why. In traffic civility has gone away a bit in my svtf since I did the lightweight flywheel. It's just the nature of the beast. All I can suggest is to practice your throttle control till you and your car know what eachother wants. I had to completely re-learn my driving style after the flywheel.
MR. freaking negative
i'm not an enthusiast...... the internets told me.
Paladin is offline
Old 08-03-2011, 09:58 PM   #12
iminhell
C2H5OH
iminhell's Avatar
Fan#: 36222
Points 18,684, Level 86
Points: 18,684, Level: 86 Points: 18,684, Level: 86 Points: 18,684, Level: 86
Level Up 67% Completed
Forum Activity 18%
Buy-Sell-Trade Rating: (4)
So "Dashpot Adder With RPM" or "Dashpot Decay Rate" might be the ticket?
Haven't played with that yet because I really don't understand it. But if it's based on RPM I'd be happy.
OH, you're not playing dumb ...
iminhell is offline
Old 09-01-2011, 02:47 PM   #13
illinipo
Token Engin-nerd
illinipo's Avatar
Fan#: 37693
What I Drive: dirty wag; Party; Bavarian phallus
FF Reputation: 272 illinipo Outstanding Standing Member illinipo Outstanding Standing Member illinipo Outstanding Standing Member
Buy-Sell-Trade Rating: (19)
Something I posted a while back at the other place, hope it helps
Originally Posted by illinipo
This has to do with dashpot. It is a hard topic for a lot of people to understand (mostly because the way it is usually described). This topic alone could be its own thread.
There are 3 important dashpot parameters:
preposition
decay rate
clip
The dashpot will "fill" up to the preposition value in part throttle or WOT. This is how much air the IAC valve lets in when you let off the throttle. Changing this will control how hard the car bucks or how stiff or light the car engine brakes IMMEDIATELY after letting the throttle off.
Then the decay rate comes into play. The decay rate changes how quickly the dashpot ramps down to the clip value (it is a power law regression re-calculated 26 times a second). Changing this will control how hard the car engine brakes during coasting. It can also cause the problem you have of the car dying when you put the clutch in.
The clip value is the minimum amount of air to send through the ISC valve on decel IN ADDITION TO the ISC Netrual Idle Air table... So you basically want to set the dashpot clip 1 to all 0's unless you want hanging rev's. And who the hell wants hanging rev's???
One caveat to setting clips to 0. This caveat requires you to know that the ECU switches from dashpot mode to idle mode at 10mph. I had to set the clip at 0 rpm to a small value like 0.0200 to prevent the car from dropping under idle speed if I crossed over 10mph as I was putting in the clutch.
Dashpot is the thing I have spent the most time on in my tune. It is a serious aid for drivability tuning. The car engine breaks and idles down exactly how I like it, how quickly I want it to, so I'm not wasting clutch material bringing the revs down or needing to shift too quickly to avoid going down to idle between shifts.
Originally Posted by Dennis_Grant
Remember this list: Bilstein; Penske; Koni; Ohlins; Sachs; Dynamic Suspension.
Not on this list? Almost certainly crap.
SUV this!
illinipo is offline
Old 09-01-2011, 09:04 PM   #14
1turbofocus
FF Affiliate
1turbofocus's Avatar
Fan#: 1123
Points 51,900, Level 100
Points: 51,900, Level: 100 Points: 51,900, Level: 100 Points: 51,900, Level: 100
Level Up 0% Completed
Forum Activity 31%
Activity: 31% Activity: 31% Activity: 31%
Buy-Sell-Trade Rating: (28)
If it was me I would play with the ISC Daspot gain in scalars , this is what controles the flair when you push in the clutch , done slowly this would slightly lift the rpm when you went to shift or at least hold or slow down
I would start there vs the stuff listed above
Customer Support
AIM: hpdyno
Email: hpdyno@aol.com
Phone: 704-249-3745
Site: focus-power.com
Elder 1turbofocus
1turbofocus is offline
Old 09-02-2011, 01:03 AM   #15
03OrangeSVT
LETS TURN DIRT!!!!
03OrangeSVT's Avatar
Fan#: 19169
What I Drive: MINI Cooper S TURBO
FF Reputation: 152 03OrangeSVT Excellent Standing Member 03OrangeSVT Excellent Standing Member
^^^^ I on the other hand usually adjust the decay rate to get the RPM drop where I want it.
[B]1951 McCormick FARMALL M
2007 MINI Cooper S Turbo... new project car
1998 Chevy 3500 Ext cab, long bed, 4x4, duelly, turbo diesel
2004 Harley V-Rod.... sex on wheels
2011 Harley Electra Glide Ultra Limited
[/b]
03OrangeSVT is offline
Old 09-02-2011, 01:10 AM   #16
illinipo
Token Engin-nerd
illinipo's Avatar
Fan#: 37693
The preposition is really fun to play around with and also very important in autocross and road racing. You can tune how hard it hits when the throttle closes for inducing oversteer on entry or transition. Too hard though, and it can be a little scary on the street
SUV this!
illinipo is offline
Old 09-02-2011, 02:46 AM   #17
aprophetofone
Fan#: 85867
What I Drive: 01 grabber green zx2
FF Reputation: 1 aprophetofone Good Standing Member
this would be nice with a flip chip setup.
what parameters would need to change to smooth things out? sitting in first gear in traffic sucks.
aprophetofone is offline
