2008 Focus with 65K, time to change spark plugs yet? - Page 2 - Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum
Go Back   Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum > Ford Focus Second Generation > DURATEC Performance (2008-2011)
DURATEC Performance (2008-2011) The place to chat about any Duratec 20 engine performance, tuning and exhaust related upgrades.
Old 02-23-2014, 04:08 PM   #11
Longbowman
Longbowman's Avatar
Fan#: 144057
What I Drive: 2008,Kiwi Green, SE Sedan
Points 12, Level 1
Points: 12, Level: 1 Points: 12, Level: 1 Points: 12, Level: 1
Level Up 23% Completed
FF Reputation: 1 Longbowman Good Standing Member
Smile 2008 Focus FE 2.0 Engine
I just changed my original spark plugs with 132,000 miles on them and they gapped and looked just fine. They were an iridium plug ITR 5F13.
I replaced them with the Motorcraft SP-448 (AGSF-32Y-PC) that appeared to be identical.
I have determined by my experience with all my Ford vehicles that have platinum or Iridium plugs in them it is a waste of my money to change before 100K. I changed the original plugs in my daughters 2005 Ford 500 V6 that had 130,000 on it and those plugs looked fine also.
I have done well using a combination of manufacture recommendations and take a peek on modern vehicle maintenance. These are not the leaded gasoline and distributer contacts monsters we used to take care of.
Longbowman is offline
Old 02-23-2014, 04:17 PM   #12
sailor
Elder
sailor's Avatar
Fan#: 57268
Points 13,328, Level 75
Points: 13,328, Level: 75 Points: 13,328, Level: 75 Points: 13,328, Level: 75
Level Up 20% Completed
Forum Activity 99%
Pulled 'em out, checked 'em, never seized & reinstalled at about 75,000. Didn't want to worry about getting them out later...
"Rubber Side Down"
S.R. #275 Focus Takeover #003
sailor is online now
Old 02-23-2014, 05:42 PM   #13
elsolo
elsolo's Avatar
Fan#: 96835
Points 2,615, Level 31
Points: 2,615, Level: 31 Points: 2,615, Level: 31 Points: 2,615, Level: 31
Level Up 10% Completed
Originally Posted by don627 View Post
I don't understand why everyone feels the need to change the plugs at 10000 miles that is rather excessive in my opinion. I would just like to say that car manufacturers are not going to recommend a certain maintenance interval without having thought the matter through and after much real world testing. If the manual says 100000 miles for standard usage that is what I'm going to do my money and time are much to important to be worrying about such mundane things. I have an '03 with 80000 and an '07 with 50000 both run great by following fords schedule.
Those people are runnning copper plugs, not platinum.
New plugs are under $20 and fifteen minutes, if there is any improvement in fuel economy it will pay for itself.
I am sure your cars run fine, but you have only one data point with nothing to compare it to.
2.3, home fabbed Mustang GT brakes, SVT suspension
67 Chevelle SS-496, owned since 1991
elsolo is offline
Old 02-24-2014, 06:33 PM   #14
Longbowman
Longbowman's Avatar
Fan#: 144057
Points 12, Level 1
Never Seize
Never seize is one of the smartest things we can use on almost everything that could rust or seize up to have a little compassion for the next person that has to take it apart. Lug nuts included!
Old 03-17-2014, 03:13 PM   #15
Gettysburg150
Gettysburg150's Avatar
Fan#: 97408
What I Drive: 08 Silverfrost Metallic SE, 5 speed
Points 1,255, Level 19
Points: 1,255, Level: 19 Points: 1,255, Level: 19 Points: 1,255, Level: 19
Level Up 55% Completed
FF Reputation: 2 Gettysburg150 Good Standing Member
Lug nuts don't get stuck usually because they are rusted, but because they are over torqued.
Anti seizing your lug nuts lubricates the threads which changes the amount of twisting youre going to do before the reach the approved torque spec. This puts more stress on the threads of both the nut and stud. Also with the lubricant in there, you have the possibility of the lug nuts coming loose because you "thought" they were tight enough.
I don't recomend anyone anti seize their lug nuts.
Sedan Revolution Two Three Zero
FRPP, "Stealth" CAI, Debadged, wider tires, louder stereo, turbo mainfold in the wrong place...
Gettysburg150 is offline
Old 03-17-2014, 03:25 PM   #16
crice8
crice8's Avatar
Fan#: 84830
What I Drive: 2010 Sterling Gray Focus SE Sedan
Points 8,540, Level 62
Points: 8,540, Level: 62 Points: 8,540, Level: 62 Points: 8,540, Level: 62
Level Up 30% Completed
FF Reputation: 9 crice8 Good Standing Member
Buy-Sell-Trade Rating: (13)
Agreed. If you have to put it on your lug nuts anyways then your doing it wrong
Galatians 6:14
crice8 is offline
Old 03-17-2014, 09:51 PM   #17
sailor
Elder
sailor's Avatar
Fan#: 57268
Forum Activity 99%
A bit off the spark plug subject... You'll get arguments about never seize there as well.
If you aren't from a real "Rust Belt" area you won't see why it's such a religion to use that product wherever possible. Thread lock as a substitute in the few places it's really not advisable.
Heck - if you don't use it on the wheel hubs when installing aluminum wheels, give it some time & you won't even NEED the lug nuts - wheels are corroded on so tight you could drive a ways without them. People have loosened the nuts & driven around to break them loose & they still don't come off.
Gettysburg is where people from around here go to find cars that aren't badly rusted, and unless you're by the Ocean in TX, who worries about rust/corrosion down there? Only antiques have corrosion issues to compare at all when out of the Salt zone.
NOT using the stuff up here is the mark of half-assed work on a car you never expect to work on again.
"Rubber Side Down"
Old 03-18-2014, 09:46 AM   #18
Gettysburg150
Fan#: 97408
Agree and disagree. We lubricate hubs at work cause they stick on just as you stated. BUT in areas where a item is supposed to be torqued dry you should not apply a lubricant (e.g. head bolts, lug bolts, crank bolt, etc). Now I'm curious as to what the Ford service manual says, anyone got one?
Hijack over lol.
Old 03-18-2014, 03:19 PM   #19
sailor
Elder
sailor's Avatar
Fan#: 57268
Forum Activity 99%
You are actually correct - Lugs are supposed to be torqued Clean & Dry.
Wish you were wrong, and that lubricated was the standard - it would avoid so many of the corrosion issues that make repair difficult & expensive.
The days of "Grease is cheaper than bearings, so use plenty" are long gone. That quote is from the Model T era, and I don't know how long it lasted past that. Using the minimum necessary saves $, and isn't often an issue during warranty.
Corroded fasteners need more torque to tighten properly, lubricated need less, crossing fingers a bit & lubricating corroded fasteners seems to work in practice.
Avoiding over-torque becomes more important, I've seen 20% as a recommended reduction on clean fasteners. Gets into judgement calls on re-use of fasteners at all sometimes.
Nice clean Engine components aren't an issue (head, crank as you mentioned). Spark plugs can be, steel into aluminum is the worst & almost universal currently.
Never-Seize has been wonderful whenever I chose to use it, brakes that work for years instead of giving trouble is just one example.
Guess it depends on circumstances. In a salt corrosion environment it can save a lot of grief.
"Rubber Side Down"
Old 03-18-2014, 03:53 PM   #20
Gettysburg150
Fan#: 97408
Not arguing with you there, corrosion does suck big time.
I like using it on areas that you know are going to be a problem such as exhaust bolts, glow plugs, spark plugs, differing metals (steel bolts into aluminum and vice versa), etc, etc.
Anti-seizing everything is not good practice IMO lol. I just had an audi come into work that had the lug bolts covered in goop. All that did was make a mess for me to clean up and even then I was not comfortable that the wheels were torqued properly. Not much you can do though.
I've just never seen a wheel stuck due to corrosion on the threads of the hub or studs/nuts. The hub and wheel surface itself (center) yes, all the time. Just cleaning that up makes a world of a difference the next time around, and a little bit of grease usually stops any future issues
