2012 a/c problem - Page 9 - Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum
Old 05-23-2012, 03:26 PM   #81
JesseE1981
Fan#: 88551
What I Drive: 2012 Sterling Grey Focus Hatchback
FF Reputation: 1 JesseE1981 Good Standing Member
I've been playing around with my AC, and here is what I discovered, which MAY answer some other people's questions.
If you turn the knob to the colder settings, but don't turn the AC button on, it does blow some cooler aid (which is what I have experienced in EVERY vehicle I've ever owned), but you also get sort of a musty like smell as well. For those of you who have the AC button on, and are getting cool air (not cold), and the musty smell, I'm wondering if the AC compressor is actually not functioning in this case for you. The button is on telling you it's on, but it's not actually functioning, and therefor you don't actually have any AC.
I've also noticed that when the AC is on, my car seems to have a varying degree of coldness output, even when on the coldest Max AC setting. Sometimes it just seems to be cooler than without the AC button on, other times it seems to be blowing out pretty cold air. The test I always do it holding my hand up to a vent. At it's coldest, it does cool my hand down enough that I actually want to remove it because it seems like it's getting too cold. When it doesn't seem to be functioning at it's coldest, I could leave my hand on the vent all day long.
This morning I found it kind of odd (even though my car had been sitting outside all day yesterday in the sun), that when I turned the AC on this morning (again, using Max AC setting), it was blowing relatively hot air out for about a good 10 seconds or so before it started to blow out cooler air.
It's not officially summer yet, so I'm still using the AC off and on, but I'm not sure I'm satisfied with how it's performing, so I may need to take my car in for service for this issue. With that said, I do recall saying right where I got the car (and I took delivery last August), that the AC didn't at all feel like it was outputting cold air like it should, like I never wanted to turn the fan setting off from "4", because then it would get too warm.
JesseE1981 is offline
Old 05-23-2012, 03:30 PM   #82
Cylander
Fan#: 97131
What I Drive: 2012 Sterling Gray Focus Sedan SE
FF Reputation: 1 Cylander Good Standing Member
You should be to turn on the AC and then pop the hood and see if the compressor is running. That would tell you if the compressor is just not turning on.
Cylander is offline
Old 05-23-2012, 07:32 PM   #83
Fine Focus
Fine Focus's Avatar
Fan#: 88092
What I Drive: 2012 Sonic Blue Focus 5 Door
FF Reputation: 1 Fine Focus Good Standing Member
Originally Posted by Uptcv1 View Post
not sure if A/C is the issue here... perhaps some thermostat and/or calibration is off.. mine basically blows warm when dial is to left-cold seting -without A/C on- but even when it is not really warm outside.. 50's 60's temp out... so when A/C is on it helps cool but feels like all the way to left is what it should be at at say 9-10 oclock dial position...
see what I hear back from dealer today..
I have noticed the same issue with mine. It feels that the HVAC controls even on the SE are "fly by wire" and not mechanical so there may be no adjustment. I did use the AC on an 80 mile trip last Sunday and the cabin was very comfortable. The real test will be when the really hot and humid weather kicks in soon .
2012 Sonic Blue SE 5 Door
5 Speed, sport, winter packages
Fine Focus is offline
Old 05-23-2012, 10:16 PM   #84
ChrisRyan
Fan#: 97815
What I Drive: '12 SE Sterling Grey(5door) 5M 203A
Points 769, Level 14
Points: 769, Level: 14 Points: 769, Level: 14 Points: 769, Level: 14
Level Up 69% Completed
FF Reputation: 2 ChrisRyan Good Standing Member
I have had to have the AC on max and fan setting at 4 to have the cabin temp approach comfortable also. When the Texas summer hits full force the AC will simply not keep up. I hope with the information I see on this thread I can bring the technicians up to speed if it is something they have not encountered yet.
ChrisRyan is offline
Old 05-24-2012, 09:55 PM   #85
VTwin60
VTwin60's Avatar
Fan#: 99432
What I Drive: 2012 Tuxedo Black Focus SE
FF Reputation: 1 VTwin60 Good Standing Member
Its amazing that I came upon this forum and read about this issue. Summer is about to hit in the southwestern desert of the US and I have to say I'm more than a bit disappointed with my AC thus far. We have about 4.4k miles on our '12 Focus and 2 small children. The AC intermittently working fine and then not working at all is a bit of a concern. Tomorrow morning I have an appointment with my local Ford dealer to get its oil changed and tires rotated. I'll be asking them to take a look at the AC unit and its nice to see that there is indeed a known issue.
VTwin60 is offline
Old 05-24-2012, 10:52 PM   #86
Power Surge
Fan#: 55878
What I Drive: 2012 Race Red SE 5-door
FF Reputation: 1 Power Surge Good Standing Member
I am a technician, and I agree that our AC sucks. In my car, it takes a WHILE for the AC to cool the car down. It's definitely abnormal, compared to other cars. If I start my car and it's over 85 degrees, I have to put it on max and 4 and wait about 10 minutes before I start getting good cold air. Now if I get up to highway speeds then it comes on sooner. That usually points to poor air flow across the condenser at low speeds, which would be the job of the electric fan. I am wondering if the fan in our cars in inadequate for the job.
I work on all brands of cars all day, and some cars will chill me within 30 seconds of starting them up with the AC on.
Sal
2012 Race Red 5-door SE, 18" Ti wheels, Ti headlights/fog bezels, 20% tint, debadged trunk
2002 Sonic Blue SVT - supercharged (sold)
2008 Vista Blue SE (gone)
Power Surge is offline
Old 05-25-2012, 11:09 AM   #87
blackraven456
Fan#: 88061
What I Drive: 2012 Black Focus Titanium Sedan
FF Reputation: 1 blackraven456 Good Standing Member
Hmmmm, I think I read in another thread that ford doesn't fully charge the ac with coolant to save money. I don't know if its true or not but it might be a good idea to run it by your dealers. For the record I have the automatic system and have no complaints.
2012 Titanium Sedan, Ebony Black - 400A, Luxury Package
Ordered: July 14 VIN received: August 19 Sticker: Sept 3 Build Date: Sept 10 Delivered: Sept 21
blackraven456 is offline
Old 05-25-2012, 11:26 AM   #88
Uptcv1
Uptcv1's Avatar
Fan#: 88390
What I Drive: 2012 sonic blue SE sport DCT hatch
Points 2,514, Level 30
Points: 2,514, Level: 30 Points: 2,514, Level: 30 Points: 2,514, Level: 30
Level Up 43% Completed
FF Reputation: 1 Uptcv1 Good Standing Member
Good to see a techs view w 12 focus daily driver..
What do you think about the temp dial.. (not sure what controls this.. Sensors?) it appears many might agree it isjust off.. I would expect around the middle to register temps in the comfort zone (my vw cc displayed 72 right on mid -12 oclock position) and then just go warmer or cooler by direction..
This one feels like this:
Middle -12 oclock- HOT
Further to the right: gets real hot..
All the way right : HELL
To the left at ~ 9-10 oclock: comfortable
Further left gets more comfortable
All the way to left- max cold: give it all u got - feels like this maybe the only setting that defies any sensors/ programing / logic whatever it is.. and works
Uptcv1 is offline
Old 05-25-2012, 11:31 AM   #89
suss6052
suss6052's Avatar
Fan#: 95752
Points 10,261, Level 67
Points: 10,261, Level: 67 Points: 10,261, Level: 67 Points: 10,261, Level: 67
Level Up 53% Completed
Forum Activity 37%
Activity: 37% Activity: 37% Activity: 37%
FF Reputation: 26 suss6052 Great Standing Member
What you read in another thread was speculation from some one on the forum, not sure I would trust that as gospel. You can have just as many problems from over charging the system as you can from undercharging the system with the added risk of a high pressure a/c line rupture.
suss6052 is offline
Old 05-25-2012, 11:45 AM   #90
TboneZX3
Ford Fiend
TboneZX3's Avatar
Fan#: 90494
Points 1,277, Level 19
Level Up 77% Completed
This is a good description of how mine operates. However, I don't have any of the "intermittent cooling" issues some are reporting and my MkIII cools better than my MkI Focus does. Neither are powerful A/C systems, but I feel that the operation is normal for a car with a 2.0L engine.
I don't know about Ford intentionally under-filling the r-134a, but my '01 was under-filled from the factory. About 2 years into ownership, I had it charged, and it has run much better for the remaining 10 years of ownership. My MkIII Focus still cools a bit better.
Hatch Nation #90
TboneZX3 is offline
