2012 a/c problem - Page 4 - Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum
Old 04-28-2012, 04:02 PM   #31
mcbeenb
Fan#: 97940
What I Drive: 2012, Blue, Ford Focus
FF Reputation: 1 mcbeenb Good Standing Member
Fixed!
Great news guys. Our car is fixed. As it turned out, it was a combination of issues, but the primary problem was the sensors in the climate control system were not set/calibrated. This was causing lots of heat from the heater coil to spoil the system. On top of that, our condenser was defective, causing very poor cooling... if any.
So, in our case persistence paid. The main problem was that since the car was so new, there were a lot of areas the techs initially refused to look. They had a hard time believing the system could be so badly broken.
Yesterday when the wife picked me up I was amazed at the difference. The car was keeping cool easily on low fan speeds, and the temp control actually worked! Before the fix the temp dial was a psychopathic monster. A hair of a turn was the difference between uncomfortable and burnt. The temp dial now actually gives us a full range of temps! What a concept! This is definitely related to the calibration issue... and I hope it helps you guys track down your issue.
The A/C system does in fact work if its running right. So there's hope!
mcbeenb is offline
Old 04-28-2012, 04:22 PM   #32
mikebontoft
Aurelius Pardus
mikebontoft's Avatar
Fan#: 58647
Points 23,632, Level 94
Points: 23,632, Level: 94 Points: 23,632, Level: 94 Points: 23,632, Level: 94
Level Up 29% Completed
Level up: 29% Level up: 29% Level up: 29%
Forum Activity 16%
Activity: 16% Activity: 16% Activity: 16%
well that's good to hear :)
Also I don't know how I missed this awhile back but though it was technical, there wasnt really any advice I could give to let you fix it yourself so I believe this should go in the Third Generation section.
enjoy your AC, I removed mine from my car a month ago. It will be missed.
mikebontoft is online now
Old 04-28-2012, 04:34 PM   #33
allyy
Guest
Fan#: 95236
What I Drive: 2012 focus
FF Reputation: -3 allyy Poor Behavior Needs Improvement
Mine works Great
allyy is offline
Old 04-28-2012, 09:23 PM   #34
HappyHarryNET
Fan#: 98338
What I Drive: 2012 Kona Blue Focus SE
FF Reputation: 1 HappyHarryNET Good Standing Member
Hello Everyone!
So glad we checked to see if the 2012 Focus had a forum or if Googling found air conditioning problems with the new 2012 Focus autos; and there is!
Our 2012 Focus SE since the minute we drove it off the lot has had the weak air conditioning issues described here on this forum.
When our weather became 75 and 80 degrees, having the A/C set 100%, recycling air, even after 10 minutes of cool air, it does not cool you off! Our 2003 Focus' A/C kicks holy butt on this car. But now that we have read, we need to call Ford and schedule a warranty fix. I plan to PRINT OUT THIS FORUM to show proof there is a problem with new units and what they need to look for to correct OUR air conditing. We are within our bumper-to-bumper 36,000 mile warranty and we also purchased Ford's platinum 7 year warranty; glad we did now.
Problems:
+ air only cool at best on full blast; will not cool you off even when only 70F degrees outside
+ turning air thermostat to just below the start of the white area on dial, warm air begins to appear. THIS IS WRONG
We will report to Ford:
+ the condenser may be bad
+ the air dampers may not be set correctly, allowing hot air into the system from the heater even when the A/C was on
AND WE WILL FOCUS THEM ON THIS FACT:
whereas the car is new, there were a lot of areas the techs initially may refuse to look or troubleshoot; leading to customer disatisfaction and a non-repaired vehicle. Ford may have a hard time believing our A/C system could be so badly broken with only a few hundred miles on the vehicle.
WE will provide Ford this Ford Forum's reporting and will not let them bait us to accept anything less than ICE COLD AIR CONDITIONING!
CUSTOMER RESPONSE AFTER FIXING THIS PROBLEM:
Yesterday when the wife picked me up I was amazed at the difference. The car was keeping cool easily on low fan speeds, and the temp control actually worked! Before the fix the temp dial was a psychopathic monster. A hair of a turn was the difference between uncomfortable and burnt. The temp dial now actually gives us a full range of temps! What a concept! This is definitely related to the calibration issue... and I hope it helps you guys track down your issue. The A/C system does in fact work if its running right. So there's hope!
The above customer statement PROVES our air conditiong IS IN FACT not functioning properly and had I tested the A/C before taking delivery, I NEVER would have taken delivery of our car!
HHNET
HappyHarryNET is offline
Old 04-30-2012, 04:29 PM   #35
FordService
Official Ford Rep
FordService's Avatar
Fan#: 79824
What I Drive: Ford Focus
Points 3,366, Level 36
Points: 3,366, Level: 36 Points: 3,366, Level: 36 Points: 3,366, Level: 36
Level Up 11% Completed
Forum Activity 20%
Activity: 20% Activity: 20% Activity: 20%
Originally Posted by mcbeenb View Post
Great news guys. Our car is fixed...
Yesterday when the wife picked me up I was amazed at the difference. The car was keeping cool easily on low fan speeds, and the temp control actually worked!...
Hello again mcbeenb,
Thatís great to know! If you ever need assistance in the future, donít hesitate to shoot me a PM.
Originally Posted by HappyHarryNET View Post
...Our 2012 Focus SE since the minute we drove it off the lot has had the weak air conditioning issues described here on this forum...
Hi HappyHarryNET,
Welcome to the forum!
Iíll be happy to arrange a call from the Customer Service Manager for your area. In order to do so, send a PM with your contact information, dealer name/state, approximate mileage, and VIN.
Noemi
FORD SERVICE
p: 800.392.FORD
FordService is online now
Old 05-01-2012, 10:07 AM   #36
KukaaKatchou
Fan#: 96771
What I Drive: 2012 red Ford Focus SE Hatchback
FF Reputation: 1 KukaaKatchou Good Standing Member
Hmm this may explain some things I noticed about my car as well. As soon as the engine warms up I get warm air on any setting of the thermostat if AC is off. I have to go in for transmission problems (after only 2 weeks with the car!) so I'll ask them to check this as well *sigh*
KukaaKatchou is offline
Old 05-03-2012, 12:20 PM   #37
dcamfam
Fan#: 93153
What I Drive: 2012 5 door Focus White
FF Reputation: 1 dcamfam Good Standing Member
Originally Posted by IMACHU View Post
Has any one had issues with their 2012 Focus in stop and go traffic with the a/c stops blowing cold air?When my Wife first got the car a/c would not work took it back and they said a fuse had dislodged and reinserted it no problems after that until this problem and of coarse Ford can not locate this issue has to become more of problem for them to locate this issue.
my 2012 is in the shop for a second time. 4000 miles... air conditioner is great, then stops blows hot or warm humid air and a weird smell. Fist time in the shop, they said the system was not charged properly. Recharged, and a dye test. Worked fine for about 10 days and then started in again. I hope we get the problem solved, as my wife wants me to sell the car cause she cant stand the smell when it stops... that shoud cost me big bucks
dcamfam is offline
Old 05-04-2012, 03:41 PM   #38
FordService
Official Ford Rep
Fan#: 79824
Forum Activity 20%
Originally Posted by KukaaKatchou View Post
...As soon as the engine warms up I get warm air on any setting of the thermostat if AC is off. I have to go in for transmission problems (after only 2 weeks with the car!) so I'll ask them to check this as well *sigh*
Hi KukaaKatchou,
Itís a pleasure to meet you!
Iím glad your Focus will be visiting the local Ford dealer. A representative from the Ford of Canada Customer Relationship Center will also be happy to assist. Give them call at 1.800.565.3673 when you have a chance.
Originally Posted by dcamfam View Post
my 2012 is in the shop for a second time. 4000 miles... air conditioner is great, then stops blows hot or warm humid air and a weird smell....
Hello again dcamfam,
Thank you for your patience as the dealer repairs the issue.
Have you contacted the Customer Service Manager assigned to your case previously? Send me a PM with the request; I'll be happy to do so on your behalf.
Noemi
FORD SERVICE
p: 800.392.FORD
Old 05-09-2012, 10:19 AM   #39
Uptcv1
Uptcv1's Avatar
Fan#: 88390
What I Drive: 2012 sonic blue SE sport DCT hatch
Points 2,514, Level 30
Points: 2,514, Level: 30 Points: 2,514, Level: 30 Points: 2,514, Level: 30
Level Up 43% Completed
FF Reputation: 1 Uptcv1 Good Standing Member
Mine will need to be checked too... Seems to also produce hot air at any setting when a/c off which makes necessary to use a/c very often... Even when outside temp is not high.. When using a/c need to dial close to max cold setting to feel cold air... Whats odd is the left vent from central dash always blows warmer air vs the right one...
Uptcv1 is offline
Old 05-09-2012, 11:58 PM   #40
Armando2012
Armando2012's Avatar
Fan#: 89153
What I Drive: 2012 Focus S Sterling Gray Metallic
FF Reputation: 1 Armando2012 Good Standing Member
Well funny how this has become an issue because I brought it up once last summer here and it was ignored.
I was living in the southwest where the temps were really high last summer and I noticed the A/C did not cool very well when the temp outside was high, like over 95.
I have since moved to east Texas where in the summer you get high humidity as well as very high temperatures.
Now the weather has been warm here and low humidity, but summer is not here yet.
So I will see how well my 2012 Ford Focus handles the high heat and humidity.
I hate the major inconvenience of having to take it to the dealer so they can "look" at it and then slowly figure it all out.
Maybe the factory condenser is not made to handle high outside temperatures.
We'll see what happens and I'll keep this forum posted.
From another forum posting:
http://www.focusfanatics.com/forum/showthread.php?t=286869
Armando2012 is offline
