Mk3 Recalls and TSBs - Page 2 - Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum
Old 05-16-2012, 04:25 PM   #11
PratoN
PratoN's Avatar
Fan#: 88058
Points 3,022, Level 33
Points: 3,022, Level: 33 Points: 3,022, Level: 33 Points: 3,022, Level: 33
Level Up 82% Completed
Forum Activity 12%
FF Reputation: 15 PratoN Great Standing Member
Originally Posted by got3fords View Post
Hmm, I have the (slight) vibration in park, neutral, and starting in first. I assumed it was due to the undersized (right?) engine mount. But perhaps I have an unbalanced clutch assembly? I don't think my dealer would want to do anything about it, though. Its not horrible so Ill probably just have to wait until it goes out (hopefully within 6years/125k miles).
PratoN is offline
Old 05-17-2012, 11:51 AM   #12
Imaruningbulseye
Fan#: 99099
What I Drive: 2012 Ford Focus
FF Reputation: 1 Imaruningbulseye Good Standing Member
I think it for that one
FORD: 2006-2007 Focus
This article supersedes TSB 06-25-2 to update the model years and Service Procedure.
ISSUE:
Some 2006-2007 Focus vehicles may exhibit a squeaking noise from the rear of the vehicle over bumps. This noise may be caused by contact between the rear parking brake cable sleeve and the wire form bracket located under the vehicle near the rear suspension tie bar being transferred into the vehicle body.
ACTION:
Follow the Service Procedure steps to correct the condition.
SERVICE PROCEDURE
Remove the parking brake cable bolt. (Figure 1)
Figure 1 - Article 08-4-15
Insert the plastic insert into the square hole used for locating the parking brake cable guide. (Figure 1)
Remove any existing grease from the cable guide and cable (in this area only) by wiping clean with a suitable service towel.
Install the cable guide onto vehicle by inserting the locating tab of the guide into the center of the plastic insert and reinstalling the parking brake cable bolt. Torque to 17 lb-ft (23 N-m).
Imaruningbulseye is offline
Old 05-17-2012, 11:59 AM   #13
danyall2010
Fan#: 89399
What I Drive: 2012 Red Candy Focus Titanium Sedan
FF Reputation: 3 danyall2010 Good Standing Member
ISSUE:
ACTION:
SERVICE PROCEDURE
This thread is for 2012 Focus TSBs and recalls!
danyall2010 is offline
Old 05-17-2012, 12:13 PM   #14
BetaDnB
Drum n Bass Lover
BetaDnB's Avatar
Fan#: 87466
What I Drive: 2012 Silver SE Sport
Points 2,305, Level 29
Points: 2,305, Level: 29 Points: 2,305, Level: 29 Points: 2,305, Level: 29
Level Up 4% Completed
Forum Activity 4%
FF Reputation: 13 BetaDnB Great Standing Member
ISSUE:
ACTION:
SERVICE PROCEDURE
Welcome...but this is the 3rd gen forum.
Originally Posted by Rat Fink View Post
2.0L GDI AND MANUAL TRANSMISSION - CALIBRATION UPDATE - VARIOUS DRIVABILITY IMPROVEMENTS - BUILT ON OR BEFORE 2/29/2012
Publication Date: May 8, 2012
FORD: 2012 Focus
This article supersedes TSB 12-1-4 to update the Title, Issue Statement and Service Procedure.
ISSUE:
Some 2012 Focus vehicles equipped with a 2.0L gasoline direct injection (GDI) engine, manual transmission and built on or before 2/29/2012 may exhibit diagnostic trouble codes (DTC) U0422, P00D2, P068A, P0850, P2610, P2832, P286F, P2877, P00C6, P0607, P0457 and/or P06B8 and may be accompanied by engine drivability concerns. Refer to the calibration content for additional calibration details.
ACTION:
SERVICE PROCEDURE
Reprogram the powertrain control module (PCM) to the latest calibration using IDS release 78.02 and higher. This new calibration is not included in the VCM 2012.3 DVD. Calibration files may also be obtained at www.motorcraft.com.
Reset the Oil Minder, refer to Workshop Manual (WSM), Section 413-01.
Previously Released Calibration Content
Previously released calibration content contained improvement actions and enhancements to address the following on vehicles equipped with a manual transmission:
Intermittent vehicle speed control inoperative.
Engine no-start with engine coolant temperature (ECT) open circuit faults.
Intermittent no-crank/no-start condition after performing normal Powertrain Control/Emissions Diagnosis (PC/ED) pinpoint test (PPT) procedures.
Intermittent false initialization to 21 C (70 F) on the instrument cluster's ambient temperature display upon engine start up.
A/C performance at idle and high engine coolant temperature readings in cold ambient temperatures below 0 C (32 F) on vehicles equipped with automatic grill shutters (AGS).
Oil change minder not lighting up in instrument panel cluster (IPC) when vehicle surpasses 10,000 miles.
Difficulty launching from a stop when not using the accelerator pedal.
Low speed tip-in/tip-out shuffle in 1st, 2nd and reverse gears
NOTE: PLEASE ADVISE THE CUSTOMER THE VEHICLE'S OIL MINDER HAS BEEN RESET AND TO FOLLOW THE RECOMMENDED OIL CHANGE INTERVAL AS DESCRIBED IN THE OWNERS MANUAL.
WARRANTY STATUS:
Eligible Under Provisions Of New Vehicle Limited Warranty Coverage And Emissions Warranty Coverage
IMPORTANT: Warranty/ESP coverage limits/policies/prior approvals are not altered by a TSB. Warranty/ESP coverage limits are determined by the identified causal part and verified using the OASIS part coverage tool.
OPERATION DESCRIPTION TIME
120505A 2012 Focus 2.0L GDI And Manual Transmission: Check DTCs And Reprogram The PCM, Includes Time To Reset The Oil Change Minder (Do Not Use With Any Other Labor Operations) 0.4 Hr.
DEALER CODING
BASIC PART NO. CONDITION CODE
RECALEM 04
TSB
12-4-13 LOW WASHER SOLVENT WARNING MESSAGE MAY NOT DISPLAY ON VEHICLES BUILT ON OR BEFORE 1/14/2012
Publication Date: April 30, 2012
FORD: 2012 Focus
ISSUE:
Some 2012 Focus vehicles built on or before 1/14/2012 may not display the low washer solvent message as detailed in the Owner's Guide.
ACTION:
SERVICE PROCEDURE
Using the Ford Integrated Diagnostic System (IDS) start a new IDS session.
ID the vehicle; select the tool box at the vehicle screen.
Select module programing.
Select programmable parameter.
Select car configuration parameters.
Select vehicle configuration.
Retrieve professional technician society (PTS) delivered as-built data.
Follow the on-screen prompts.
WARRANTY STATUS:
120413A 2012 Focus: Follow Service Procedure To Repair Concern (Do Not Use With Any Other Labor Operations) 0.3 Hr.
DEALER CODING
14A068 04
Sedan Revolution #249 - 2012 SE Sport - ╠╬╝ - Ingot Silver - 201A - K&N w/ snorkel delete - Blox Type R Knob
BetaDnB is offline
Old 09-19-2012, 03:28 PM   #15
blasman
Fan#: 102236
What I Drive: 2012 SEL
FF Reputation: 1 blasman Good Standing Member
TSB List as on 9/19/12 For 2012 Focus
Tsb 12-08-20 - reduced driving range, intermittent no start or no high voltage battery charging
tsb 12-08-11 - 2.0l gdi - front control interface module (fcim) illumination flickering or prematurely dimming in low ambient light conditions,built on or before 5/15/2012
tsb 12-06-17 - crunching or creaking noise from front of vehicle on low speed turns and bumps - built on or before 4/2/2012
tsb 12-05-05 - 2012 focus 2.0l gdi with manual transmission - calibration update - various drivability improvements - built on or before 2/29/2012
tsb 12-05-04 - 2012 focus - 2.0l gdi - dtc p0010, p0012, p0013, p0014, p052a or p054b - vct oil control solenoid - built on or before 5/6/2011
tsb 12-05-02 - 2012 focus 2.0l gdi - oil leak - rear upper exhaust manifold stud area
tsb 12-04-13 - 2012 focus low washer solvent warning message may not display on vehicles built on or before 1/14/2012
tsb 12-02-17 - 2012 focus steering wander - built on or before 12/12/2011
tsb 12-02-15 - 2012 focus passive anti theft system (pats) spare key programming issues - without intelligent access - built on or before 2/22/2012
tsb 12-01-07 - message center displaying horizontal lines - erratic fuel gauge - built on or before 8/16/2011
tsb 11-12-13 - 2012 focus - automatic transmission fluid leak
tsb 11-10-01 - 2012 focus - intermittent remote keyless entry (rke) operation - built on or before 8/3/2011
tsb 11-09-14 - 2011 fiesta / 2012 focus - recreational towing - automatic transmission - built on or before 7/15/2011
tsb 11-09-03 - 2012 focus - inaccurate fuel gauge - dtcs p0456, p008a, p1450, p2196 - built on or before 8/3/2011
tsb 11-08-11 - 2012 focus front door to rear door contact at the top weatherstrip
tsb 11-08-01 - visible depression in hood surface
tsb 11-07-13 - 2012 focus battery light on - dtcs may also be present u012d, u0140, b11db, u0422, p2610, p06b8, u0257
tsb 11-05-01 - 2012 focus lack of power steering assist on vehicle start up and dtc c102d - built on or before 4/19/2011
blasman is offline
Old 09-20-2012, 06:25 AM   #16
Guimpy
Fan#: 88333
What I Drive: 2012 Platinum White Titanium
Points 141, Level 2
Points: 141, Level: 2 Points: 141, Level: 2 Points: 141, Level: 2
FF Reputation: 1 Guimpy Good Standing Member
Already posted - sorry
Guimpy is offline
Old 03-25-2013, 03:13 PM   #17
GhiaFan
GhiaFan's Avatar
Fan#: 50498
What I Drive: 2007 Panther Black Focus 1.6 Ti-VCT
Points 13,315, Level 75
Points: 13,315, Level: 75 Points: 13,315, Level: 75 Points: 13,315, Level: 75
Level Up 17% Completed
Forum Activity 13%
FF Reputation: 13 GhiaFan Great Standing Member
TSB 13-2-5 February 11, 2013 - When using the Remote Start feature, customers may experience a Crank No-Start or Stall shortly after vehicle is
driven.
http://www.fordservicecontent.com/pu...sb13-02-05.pdf
GhiaFan is offline
Old 03-27-2013, 04:38 PM   #18
PratoN
PratoN's Avatar
Fan#: 88058
Forum Activity 12%
About freaking time! (Even though I don't have a sedan...)
Broadcast Message 5845
2012-2013 Focus - Rear Parcel Shelf - Vent Foam Deteriorating Or Falling Apart Built On Or Before 2/9/2013
See TSB: 13-03-20 for details.
See this thread for pics: http://www.focusfanatics.com/forum/showthread.php?t=291723
PratoN is offline
Old 04-08-2013, 09:51 AM   #19
PratoN
PratoN's Avatar
Fan#: 88058
Forum Activity 12%
For the love of God, can someone get the text of this TSB for me?
2011-2013 Fiesta and 2012-2013 Focus - DPS6 - Intermittent Transmission Clutch Shudder DPS6 Automatic Transmission
See TSB: 13-04-05 for details. 13-04-05
PratoN is offline
Old 04-08-2013, 11:43 AM   #20
RAF_S197
RAF_S197's Avatar
Fan#: 91991
What I Drive: 2014 Oxford white Sport Black Pack
Points 7,541, Level 57
Points: 7,541, Level: 57 Points: 7,541, Level: 57 Points: 7,541, Level: 57
Level Up 96% Completed
Forum Activity 15%
Activity: 15% Activity: 15% Activity: 15%
FF Reputation: 21 RAF_S197 Great Standing Member
Does anyone have a list of TSB's for the 2013 Focus? Everything I'm seeing only applies to 2012's
2014 Oxford white Focus SE Sport Black pack
Instagram: 5_POINTOH
RAF_S197 is offline
