Mk3 Recalls and TSBs - Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum
Old 07-28-2011, 05:24 PM   #1
DrkKnight614
GO Green
DrkKnight614's Avatar
Fan#: 14522
Points 25,851, Level 96
Points: 25,851, Level: 96 Points: 25,851, Level: 96 Points: 25,851, Level: 96
Level Up 51% Completed
Level up: 51% Level up: 51% Level up: 51%
FF Reputation: 47 DrkKnight614 Great Standing Member
Exclamation Mk3 Recalls and TSBs
Figured Id make this thread as it will be useful for potential buyers and owners, now and in the future. Also because I want to know what tsbs are out there right now so that when my parents get their focus it can have those addressed before it leaves the driveway. Would be nice if this got stickied too. So post up known Tsb's and recallls. All I got now is the TSB for MFT that just came out. And the steering one.
2012 Ford Focus Steering Service Bulletin 107553
NHTSA: Action Number: 10039118Service Bulletin Number: 107553
Report Date:
May 04, 2011Component:
Steering
Summary: Ford: there may be steering assist warning lights as well as well as a stored trouble code. 2012 focus. *rm
Posted via FF Mobile
DrkKnight614 is offline
Old 08-23-2011, 05:33 PM   #2
csvt2060
csvt2060's Avatar
Fan#: 84122
What I Drive: 2013 Ford Escape Titanium
FF Reputation: 2 csvt2060 Good Standing Member
Can someone post the full TSB information for the Steering Service Bulletin above?
Thanks
csvt2060 is offline
Old 08-23-2011, 05:59 PM   #3
elwood125
elwood125's Avatar
Fan#: 17784
What I Drive: Mk 3 Blue Candy SE Sport 5spd Hatch
Points 1,122, Level 18
Points: 1,122, Level: 18 Points: 1,122, Level: 18 Points: 1,122, Level: 18
Level Up 22% Completed
FF Reputation: 4 elwood125 Good Standing Member
Some 2012 Focus vehicles equipped with electric power assisted steering (EPAS) and built on or before 04/19/2011 may exhibit a lack of power steering assist on vehicle start up and may exhibit a diagnostic trouble code (DTC) C102D. The customer will see Steering Assist Fault Service required message, the steering wheel icon, and a yellow dot in the instrument cluster, and hear the soft warning chime. Steering assist will remain for that key cycle. For the next key cycle at vehicle startup, the customer will see Steering Loss Stop Safely message, the steering wheel icon, and a red dot in the instrument cluster, and hear the hard warning chime. Steering assist will be removed for that key cycle and all future key cycles.
ACTION:
Reprogram the power steering control module (PSCM) to the latest calibration using IDS release 72.04 and higher or 73.01 and higher. This new calibration is not included in the VCM 2011.5 DVD. Calibration files may also be obtained at www.motorcraft.com.
NOTE: DIFFERENT MODULES MAY GENERATE DTC'S DURING REPROGRAMMING OF THE PSCM. FOLLOW IDS INSTRUCTIONS TO CLEAR DTC'S FROM ALL MODULES.
elwood125 is offline
Old 08-23-2011, 08:08 PM   #4
Kabigon
Fan#: 88299
Points 4,382, Level 42
Points: 4,382, Level: 42 Points: 4,382, Level: 42 Points: 4,382, Level: 42
Level Up 16% Completed
Level up: 16% Level up: 16% Level up: 16%
Forum Activity 10%
FF Reputation: 11 Kabigon Great Standing Member
Technical Service Bulletins
11-8-11
FRONT DOOR TO REAR DOOR CONTACT AT THE TOP WEATHERSTRIP
11-8-1
VISIBLE DEPRESSION IN HOOD SURFACE
11-7-29
VARIOUS FUNCTIONALITY CONCERNS WITH MYFORD TOUCH - BUILT ON OR BEFORE 7/25/2011
11-7-22
RPM FLARE OR ROUGH IDLE ON DECELERATION - BUILT ON OR BEFORE 6/28/2011
11-7-13
BATTERY LIGHT ON - DTCS MAY ALSO BE PRESENT U012D, U0140, B11DB, U0422, P2610, P06B8 OR U0257
11-6-23
DIAGNOSTIC TROUBLE CODES (DTC) P0010, P0012, P0013, P0014, P052A OR P054B - VARIABLE CAMSHAFT TIMING (VCT) OIL CONTROL SOLENOID
11-5-11
DTCS P068A, P2610, U0422 AND P00D2 - BUILT ON OR BEFORE 5/3/2011
11-5-1
LACK OF POWER STEERING ASSIST ON VEHICLE START UP - DTC C102D - BUILT ON OR BEFORE 4/19/2011
Kabigon is online now
Old 08-23-2011, 08:45 PM   #5
csvt2060
csvt2060's Avatar
Fan#: 84122
Thanks guys. I was hoping this was the one for the steering "wander" at highway speeds that has been posted at length on this forum. Mine isn't doing it but we have a customer that has complained about it. Bringing up the concern in the system does not show a TSB.
csvt2060 is offline
Old 08-23-2011, 08:52 PM   #6
feta_mgp
feta_mgp's Avatar
Fan#: 88210
Points 3,286, Level 35
Level Up 58% Completed
This thread deserves a sticky and maybe a moderator can add a post up top that can be updated with all the TSBs so we dont have to search through the thread?
Sonic Crew #28
feta_mgp is offline
Old 08-23-2011, 09:24 PM   #7
bsp_53
bsp_53's Avatar
Fan#: 87580
What I Drive: 2012 FF Titanium HB, Yellow Blaze
Points 519, Level 10
Points: 519, Level: 10 Points: 519, Level: 10 Points: 519, Level: 10
Level Up 38% Completed
FF Reputation: 1 bsp_53 Good Standing Member
Sticky please and ditto the rest ... right on.
bsp_53 is offline
Old 05-16-2012, 11:30 AM   #8
Imaruningbulseye
Fan#: 99099
What I Drive: 2012 Ford Focus
FF Reputation: 1 Imaruningbulseye Good Standing Member
FORD: 2012 Focus
This article supersedes TSB 12-1-2 to update the production fix date and Part List.
ISSUE:
Some 2012 Focus vehicles built on or before 12/12/2011 may exhibit a steering wander at highway speeds over 72 Km/h (45 MPH). Customers may indicate they have to frequently adjust the steering wheel slightly to maintain the direction of travel.
ACTION:
Follow the Service Procedure steps to correct the condition.
Saw it a little late but it out there
SERVICE PROCEDURE
Replace the Steering Gear. Refer to Workshop Manual, Section 211-00.
NOTE: FOLLOW THE RECOMMENDED TORQUE SEQUENCE AND TORQUE SPECIFICATION. IMPROPER TORQUE SEQUENCE MAY RESULT IN THE STEERING CONCERN REOCCURRING.
Imaruningbulseye is offline
Old 05-16-2012, 01:57 PM   #9
got3fords
Fan#: 93395
What I Drive: 2012 Sterling Gray SE Sport HB 203A
FF Reputation: 1 got3fords Good Standing Member
Found this:
http://www.ford-trucks.com/tsb/tsb.p...y-2012/d-FOCUS
And this:
http://www.automd.com/tsb/ford_m/
got3fords is offline
Old 05-16-2012, 03:17 PM   #10
HOTFOCUS101
HOTFOCUS101's Avatar
Fan#: 96284
What I Drive: 2010 White Suede SEL focus -
FF Reputation: 1 HOTFOCUS101 Good Standing Member
Question
http://www.focusfanatics.com/forum/showthread.php?t=221339 <--- any bulletins for this problem ???
HOTFOCUS101 is offline
