Go Back   Focus Fanatics > Ford Focus Tech Discussions > ECU Tuning Chat
ECU Tuning Chat Discuss performance tuning options for your Ford Focus.
Old 07-28-2011, 03:42 PM   #1
YellowJellyBean
Love CA / Hate CARB
YellowJellyBean's Avatar
Fan#: 69030
What I Drive: 2006 Screaming Yellow ZX3 SES
FF Reputation: 13 YellowJellyBean Great Standing Member
Can I still datalog without a wideband?
I've had my tune for a while, and I've put off datalogging anything until I get a wideband installed. Well, I picked up an AEM wideband A/F and just started researching what I would have to do to install it. Basically, it would take either a bunch of custom fab work or a new header, which isn't an option for me (I'm in CA). So, can I datalog my car to get a better tune without the wideband? I understand it wouldn't be as good, but it's looking like I don't really have any other options.
"My yellow, in this case, is not so mellow" -Jimi Hendrix
Focus Fanatics
Extremely helpful people
I made a haiku
YellowJellyBean is offline
Fan#: 1
Old 07-28-2011, 04:10 PM   #2
1turbofocus
FF Affiliate
1turbofocus's Avatar
Fan#: 1123
What I Drive: 2000 ZX3 / 2002 SVT , Turbocharged
FF Reputation: 146 1turbofocus Excellent Standing Member1turbofocus Excellent Standing Member
Buy-Sell-Trade Rating: (28)
Not sure what custom work would be needed , drill a hole and weld in a bung , this takes about 15-30 Min and most muffler shops do it for about 20-30.00 then screw in your o2 and wire it up
Customer Support
AIM: hpdyno
Email: tom@focus-power.com
Phone: 704-249-3745
Site: focus-power.com
Elder 1turbofocus
1turbofocus is offline
Old 07-28-2011, 04:27 PM   #3
YellowJellyBean
Love CA / Hate CARB
Fan#: 69030
I've heard from a number of people that welding in a bung is only possible if you remove the manifold, and that the labor to do that would be very expensive.
Back to my question, though. Is it still possible to datalog without a wideband?
Focus Fanatics
I made a haiku
Old 07-28-2011, 04:37 PM   #4
Justin svt
Justin svt's Avatar
Fan#: 58325
What I Drive: 2002 CD Silver SVT
FF Reputation: 2 Justin svt Good Standing Member
if you dont have anything custom or boost then yes
Posted via FF Mobile
Justin svt is offline
Old 07-28-2011, 05:09 PM   #5
bespurcell
bespurcell's Avatar
Fan#: 60917
What I Drive: 2003 black svt
FF Reputation: 2 bespurcell Good Standing Member
Any reputable muffler shop can weld in a bung.
Dominant Eng. orp, ITG Maxogen panel filter, Focus-Power tune, Team Dynamic Pro Race 2 16x7 wheels in black(36 lb weight reduction from stock tire/wheel combo)
bespurcell is offline
Old 07-28-2011, 06:42 PM   #6
YellowJellyBean
Love CA / Hate CARB
Fan#: 69030
Would you consider bolt-ons "custom?" I currently have a CAI, and plan on adding a cat back and throttle body in the future.
I don't doubt that they can, but I've heard from people that the labor required costs a lot, because they have to remove the exhaust manifold from the car first.
Focus Fanatics
I made a haiku
Old 07-28-2011, 07:29 PM   #7
1turbofocus
FF Affiliate
Fan#: 1123
Datalog with out a wide band can be done yes , For a tuner to send you a tune with the WOT fuel safe and at best TQ / HP no
Customer Support
AIM: hpdyno
Phone: 704-249-3745
Elder 1turbofocus
Old 07-28-2011, 09:27 PM   #8
Justin svt
Justin svt's Avatar
Fan#: 58325
bolt-ons are okay. I mean custom intakes/manifolds ect. Tom is an amazing tuner and has my car running flawlessly after a few data-logs
2002 silver ZX3 SVT #2318: Tom's Tune, 8.2mm Taylor Thundervolt wires, Custom ORP, Full Prothane bushing swap
"I buy things I don't need, with money I don't have, to impress people I don't know"
Old 07-28-2011, 09:37 PM   #9
iminhell
C2H5OH
iminhell's Avatar
Fan#: 36222
FF Reputation: 33 iminhell Great Standing Member
Buy-Sell-Trade Rating: (4)
Keep in mind he's talking about adding a bung to the factory manifold, which would be a PITA W/O having it off the car.
Look at the header install how-to, remove the manifold and bring it in and have a bung welded on. Mark where you want it before hand and be sure to allow clearance for the sensor.
More than likely the only good spot will be right under the EGR tube. Passenger side the power steering pump is probably in the way. To the engine side the valvecover is in the way. Out the front is just ugly.
^For a zetec that is.
Duratec should be easier I'd think.
The other option, which is the best option IMO, is to remove the factory front O2 and put the WBO2 there. Then use the analog output of the AEM to run the ECU.
The purpose of the analog is to simulate a stock narrow band sensor. It works perfectly fine, you don't have to do any fab work, you don't have to remove the manifold ... it's a win win.
iminhell is offline
Old 07-28-2011, 10:33 PM   #10
1turbofocus
FF Affiliate
Fan#: 1123
The wide band as a narrow band means that when you have any issues that doesnt look right they you will be changing the wide band o2 to eliminate the issues or going back to stock o2
I did the wide/narrow band back in 2002 and just found it not worth it and I havent seen much changes in the wide band o2
Yes I know some do it and havent had many/any issues so to each there own
Customer Support
AIM: hpdyno
Phone: 704-249-3745
Elder 1turbofocus
