Exhaust Tip - Page 8 - Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum
Old 03-27-2012, 12:20 AM   #71
Fuzzy Logic
Fuzzy Logic's Avatar
Fan#: 91597
What I Drive: 2012 White Plat Met Tri Ti HB
FF Reputation: 2 Fuzzy Logic Good Standing Member
Originally Posted by jsphtn8 View Post
For those who used the tip from walmart. Did you use the bracket or just the screws? I had trouble using both brackets. I ended up putting only ome of the brackets and just the screw on the other side.
i used both brackets. took both brackets off, slid on the exhaust tip, reapplied the brackets by hand, tightened with a ratchet. took 5 mins.
...SLOFOFO...
2012 Platinum White Tri-Coat Metallic Titanium
401A, Winter Package, Sport Package, Park Tech. Package, Power Moonroof, MFT/HD Sirius/Nav
Fuzzy Logic is offline
Old 03-27-2012, 12:54 AM   #72
Duffman355
Tasty Red Meat
Duffman355's Avatar
Fan#: 31282
What I Drive: 2012 Sonic Blue SE Sport 5 Spd
Points 18,698, Level 86
Points: 18,698, Level: 86 Points: 18,698, Level: 86 Points: 18,698, Level: 86
Level Up 70% Completed
Forum Activity 80%
Activity: 80% Activity: 80% Activity: 80%
FF Reputation: 43 Duffman355 Great Standing Member
Originally Posted by BiggerBoat View Post
Have you posted any underside shots of yours cause that looks like a cat-back re-do.
that was the point. I was being a smartass. I did the FS Werks race exhaust. good luck with your cutting though. It really shouldn't be too hard/you would be hard pressed to screw it up. What was hard was trying to cut the lunchbox section off from under the car on stands without a sawsall (I used a saber saw). There is practically no room under there by the rear suspension.
Also do you think becasue of the size of your exhasut tip that it will contact the bumper and melt it? Is that why you are cutting a hair off?
ST Crew #11 / SSR #5
Official Mayo Hater #1
Randomie's Lover #8
Duffman355 is offline
Old 03-27-2012, 08:31 AM   #73
BiggerBoat
BiggerBoat's Avatar
Fan#: 85913
What I Drive: 2012 Red Candy Titanium Hatch
FF Reputation: 3 BiggerBoat Good Standing Member
Yeah, your approach is obviously more real (vs our Wal-Mart approach).
I will need to make sure the tip is not right up against the bumper to avoid melting it. But the main reason I'm considering cutting the original pipe is that when I position the new tip how I want it (more level than pointing down) you can see the OEM pipe (light colored metal) drooping down inside the the new tip which looks pretty lame, especially if you stand farther back or are lower to the ground. So, that was the desire to either paint the OEM pipe dark so it is less noticeable or cut off about 1 1/2". Most of the pics of others tips are from higher or side angle so I cant tell if others have the same issue. Or, maybe no one else cares and I am being OCD.
BiggerBoat is offline
Old 03-27-2012, 12:22 PM   #74
Fringe
Fringe's Avatar
Fan#: 95955
What I Drive: 2012 SE 5DR Sport 5spd
FF Reputation: 1 Fringe Good Standing Member
I picked one up yesterday.. Overall it makes for a nicer appearance but it does look a bit lame with the angle too.... I'm a bit disappointed but for 9 bucks I shouldn't be heehee.
Now I'm gonna start obsessing over the door sill plates.....
Fringe is offline
Old 03-27-2012, 01:44 PM   #75
Sargetalon
Sargetalon's Avatar
Fan#: 95695
What I Drive: 2012 White Platinum Ford Focus SEL
Points 40, Level 1
Points: 40, Level: 1 Points: 40, Level: 1 Points: 40, Level: 1
Level Up 80% Completed
FF Reputation: 1 Sargetalon Good Standing Member
Just installed mine this weekend.
2012 Ford Focus SEL- White Platinum Metallic Tricoat/Medium Light Stone Interior
-Equipment Group 303A/Winter Package/Power Moon Roof
-Add-Ons: Engine Cover, Front & Rear Splash Guards, Stainless Steel Door Sills, Cargo Net, Chrome Exhuast Tip
Sargetalon is offline
Old 03-27-2012, 02:22 PM   #76
Duffman355
Tasty Red Meat
Duffman355's Avatar
Fan#: 31282
Forum Activity 80%
how how much did you pay for those?
Randomie's Lover #8
Old 03-27-2012, 04:27 PM   #77
mustang0
mustang0's Avatar
Fan#: 96079
What I Drive: 2012 Blue Candy SE HB Sport Package
Points 732, Level 14
Points: 732, Level: 14 Points: 732, Level: 14 Points: 732, Level: 14
Level Up 32% Completed
FF Reputation: 1 mustang0 Good Standing Member
Oh boy those look really good, where did they come from. FRP?
65 Racestang 96 Mustang 2012 Focus SE HB Sport Pac 5 speed man. NewMission Cold Air, lunchbox Delete,Custom 3" Magnaflow exhaust, Steeda Rear Sway Bar, Steeda STS,Axis wheels, Blox shift knob,Focus elecrtic RMM, Injected 93 Tune V1 176HP 152Torque
mustang0 is offline
Old 03-27-2012, 05:40 PM   #78
Sargetalon
Sargetalon's Avatar
Fan#: 95695
Points 40, Level 1
I think they were about $75 from parts cheap but last I heard they were having difficulty acquiring them.
Old 03-27-2012, 06:45 PM   #79
FocusBoy58
Sonic Mk3 Crew #03
FocusBoy58's Avatar
Fan#: 38424
What I Drive: 01 Turbo,12 SE,95 Vette 396
Points 20,766, Level 90
Points: 20,766, Level: 90 Points: 20,766, Level: 90 Points: 20,766, Level: 90
Level Up 84% Completed
Forum Activity 2%
FF Reputation: 14 FocusBoy58 Great Standing Member
Buy-Sell-Trade Rating: (16)
Ebay has em
2012 Audi Q7 TDI S Line ABTuning 391whp588wtq
01 Turbo Focus 300+ whp
2012 Focus 19" Niches, AEM CAI, F2 Race Header, 3" Borla Dual Exit, H&Rs, Eibach Sways 183whp157wtq
FocusBoy58 is offline
Old 03-27-2012, 10:52 PM   #80
r1derbike
r1derbike's Avatar
Fan#: 62667
What I Drive: '12 SE Sport Hatch - Sterling Grey
FF Reputation: 4 r1derbike Good Standing Member
I got mine far enough up the tailpipe that it doesn't point downward much...very close to the slight downward slant of my stock '10 SES tip.
I don't mind it, but then I'm blind in one eye and can't see out of the other...
Those door sill plates look very nice!
2012 Focus; Maybe 3rd Time's the Charm?
r1derbike is offline
