How Do I Know If I'm In Overdrve (2012 Focus) - Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum
Old 07-25-2011, 02:00 PM   #1
BWMorrison
Fan#: 88189
What I Drive: 2012 Ford Focus SEL
FF Reputation: 1 BWMorrison Good Standing Member
I have the Selectshift Auto Trans in my 2012 Focus and can't figure out when I'm in Overdrive or not. The book says to hit a button on the shifter.
I have the +/- button on the shifter for when I'm in Sport Mode. Can't find the button that puts me in or out of overdrive.
Help!
BWMorrison is offline
Old 07-25-2011, 02:19 PM   #2
Gobird
Gobird's Avatar
Fan#: 83191
What I Drive: 2012 Blue Candy Titanium Hatch
FF Reputation: 1 Gobird Good Standing Member
There is no overdrive that I know of. I have the same trans. and when in Sport mod. you just tap that switch and it will show up on the dash as to what gear you are in. It's a 6 speed trans. and once in 6th. gear that's the highest you can go.
2012 Titanium Hatch, Blue Candy
2002 Thunderbird, Thunderbird Blue
1973 MGB Dark Metallic Green
Gobird is offline
Old 07-25-2011, 02:29 PM   #3
BWMorrison
Fan#: 88189
That's what it appears to be. Someone just told me that if I want to be in overdrive,
driving in "D" will ALWAYS be in the automatic overdrive mode.
And that if I want to get out of auto o/d, I should shift to "S" mode, and then once I get up to 6th gear, hit the "-" on the +/- button, which would bring it down to 5th, and out of overdrive.
What do you think?
Old 07-25-2011, 02:33 PM   #4
BWMorrison
Fan#: 88189
What I've been told sounds logical, but let's say I decide to tow a (very) small boat. I would then have to start driving, getting it up to 6th gear, and then back it down to 5th by hitting the "-"
button.
Sounds like a chore just to get the darn car out of overdrive.
Old 07-25-2011, 02:34 PM   #5
Joeywhat
Strichmädchen & Koks
Joeywhat's Avatar
Fan#: 85247
What I Drive: 2014 Mustang 3.7L SGM
Points 7,950, Level 59
Points: 7,950, Level: 59 Points: 7,950, Level: 59 Points: 7,950, Level: 59
Level Up 50% Completed
Forum Activity 9%
FF Reputation: 11 Joeywhat Great Standing Member
Drive will always shift to the highest gear for fuel economy. The top two gears are overdrive, although the ratios escape me at the moment.
Sport mode disables 6th gear, but still allows 5th gear. This is still an overdrive gear, and still gives decent economy at non highway speeds (and doesn't do TOO bad on the highway, either). If manually selecting gears in sport mode you can select any gear you wish (including 6th), assuming the computer lets you to avoid stalling.
If you don't want OD for whatever reason (pulling a load, steep inclines, whatever) I would manually select the gears, assuming you're able to know which gear you need to be in. Sport mode would work better then drive, but still upshifts to the highest gear when possible, which may not be desirable.
Hatch Nation #29
Joeywhat is online now
Old 07-25-2011, 02:40 PM   #6
BWMorrison
Fan#: 88189
Joeywhat, so to repeat, when towing or going up a steep incline, I should drive in Sport mode rather than in D. Correct?
Old 07-25-2011, 02:42 PM   #7
Gobird
Gobird's Avatar
Fan#: 83191
What I found is if you start in Sport mod. and tap the - on the switch it will start in first gear and stay there until you tap the + button and move up a gear. It will work that way until you shift it back the drive. At least that's the way mine works.
Gobird is offline
Old 07-25-2011, 02:52 PM   #8
BWMorrison
Fan#: 88189
So if you were to tow something or go up a steep incline, would you do it in Sport mode?
Old 07-25-2011, 02:54 PM   #9
iso3200
iso3200's Avatar
Fan#: 86554
What I Drive: 2012 Focus SE Hatchback
Points 1,026, Level 17
Points: 1,026, Level: 17 Points: 1,026, Level: 17 Points: 1,026, Level: 17
Level Up 26% Completed
FF Reputation: 1 iso3200 Good Standing Member
Any gear less than a 1:1 ratio is an overdriven gear. Isn't this right?
In my old Protege5 5-speed manual, 4th gear had a ratio of 1:0.97 - so I had overdrive in 4th and 5th which helped fuel economy.
Anyone know the gear ratios in the PowerShift 6spd?
iso3200 is offline
Old 07-25-2011, 03:07 PM   #10
Gobird
Gobird's Avatar
Fan#: 83191
I used it a couple times when hauling 30 pcs of sod in the back of the car. It was a heavy load and allowed me to get the rpm's up before shifting into another gear. Once I got moving in 3rd. gear I bumped it up to drive. To answer your question I would say yes. I plan on getting a hitch so I can use my 5'x8' utility trailer and when towing I'll be using it.
Gobird is offline
