2012 Ford Focus Steering Problem - Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum
Old 07-14-2011, 07:17 PM   #1
MN 2012 Ford Focus
Fan#: 87809
What I Drive: 2012 Ford Focus Hatchback
FF Reputation: 1 MN 2012 Ford Focus Good Standing Member
I bought a 2012 Ford Focus Hatchback in Minnesota in June. The test drive was great (only 3 to 4 miles). When driving the car home (which is about 60 miles from the dealer), after 25 miles or so, the steering seemed to stiffen up and I found myself kind of zig-zaging within the lane (new cement freeway less than one year old). Thought maybe I was not used to the new car, or maybe it was the road? Since then, I paid close attention to the steering. I don't know what causes the steering to stiffen and free up at times. For now it seems to happen only at crusing speed (60-65) after some distance...and the distance seems to vary. So I decided after several hundred miles it wasn't the road or my ability to drive, it was the steering in the car that was the problem. I brought the car back to the dealer to be fixed and they said it drove fine. I asked them how far they drove it, and they said less than 10 miles. I asked them if they would drive it 20 to 30 miles on the freeway. They did, and found the car to be doing what I said it was doing with the steering getting stiff and then free. But they said nothing could be done about it. I am wondering how the car is going to act on ice this winter driving down the freeway. Anyone else hear about, or having this steering problem?
MN 2012 Ford Focus is offline
Old 07-14-2011, 08:03 PM   #2
seamustry
Fan#: 86768
What I Drive: :::
FF Reputation: 1 seamustry Good Standing Member
yes there are a few reports in the 2012 focus section...i would post in technical section as well
seamustry is offline
Old 07-14-2011, 08:18 PM   #3
mmmoose
Bunneh Fanatic
mmmoose's Avatar
Fan#: 39963
What I Drive: 2008 United Gray VW Rabbit
FF Reputation: 9 mmmoose Good Standing Member
What you're describing is a feature that's common for electronic power steering. It sounds to me like you're used to older cars which use hydraulic assisted steering, where the steering is either loose or tight all the time. With electronic power steering the level of assist the electronic motor applies is proportional to the speed you're traveling.
You can test this out by going to a parking lot and driving around at a very slow speed (~10 mph). Do a few turns and notice how the steering wheel is very loose and easy to turn. Now drive off onto a main road and speed up a bit. As you get closer to 35+ mph, the steering wheel will gradually tighten and become more responsive. This is 100% completely normal with electronic power steering systems.
I can't explain the zig-zagging that you describe, because I don't know if you're naturally overcompensating for a steering system you're not used to. But I think a quick way to figure out whether it's really a problem or not is to visit your dealership and test drive another Focus (or another Ford model) to see if it really is the steering system. I don't want to discredit you entirely because maybe you really may be onto something. But I just figured I'd explain how newer steering systems work.
I can tell you right now that almost all cars that use electronic power steering have speed proportional assist. It took me a while for me to get used to it too when I bought the Rabbit. Sport trim cars (GTI, MazdaSpeed3, etc.) have their assist levels turned a little lower to emulate old school hydraulic power steering responsiveness (which is probably what you're more used to). I'd rather have that feeling too, but unfortunately these cars have steering that's tuned more for comfort rather than precision.
The good news is that the level of assist can be tweaked very easily. People who work for Ford can use a diagnostic tool hooked up to your car's computer to actually change the value of the level of assist (much like changing the mouse sensitivity on your computer). The bad news is that your dealership probably won't let you do it by request. Believe me I've tried to get them to set mine to a sportier setting (GTI's default value) and they refused even when I attempted to bribe them, stating liability reasons.
-Moose
mmmoose is offline
Old 07-15-2011, 02:15 AM   #4
DrkKnight614
GO Green
DrkKnight614's Avatar
Fan#: 14522
Points 26,111, Level 96
Points: 26,111, Level: 96 Points: 26,111, Level: 96 Points: 26,111, Level: 96
Level Up 77% Completed
FF Reputation: 47 DrkKnight614 Great Standing Member
Posted via FF Mobile All cars with electronic power steering have this feature...its not a problem. At highway speed it tightens up because you want to be able to make small inputs to change lanes and stuff, not wrestle the well around. At parking lot speeds, it lightens up so its easy to turn the wheel.
DrkKnight614 is offline
Old 07-15-2011, 03:42 PM   #5
sehatch
Fan#: 87659
What I Drive: 2012 Gray Focus Hatch
FF Reputation: 3 sehatch Good Standing Member
Highway lane drifting
MN 2012 Ford Focus, see this thread http://www.focusfanatics.com/forum/s...light=steering. Itís a defect in the TRW steering rack as noted by fanddp. The problem goes far beyond speed sensitive steering and those not having the problem have difficulty understanding what we are experiencing. I have returned my Focus while they sort it out. Dealer tells me Ford sent a list of parts to be replaced. SEHATCH
sehatch is offline
Old 07-15-2011, 11:16 PM   #6
MN 2012 Ford Focus
Fan#: 87809
mmmoose, thank you for your response offering me a driving lesson by explaining the difference between electronic assist and hydraulic power steering; as if I understood how electronic assist worked, then there would not be a problem with the steering. Obviously, I need to explain in more detail. As I said in my first attempt to explain the problem, it is not when the car reaches 60 to 65 mph (if that was the case, I could understand what was going on), but after some distance at that speed. I wonder (I am guessing) if when the car senses no activity, such as on a straight-a-way where there is no correction going on to keep the car straight, then maybe the electronic assist shuts down to save on power for better gas mileage. Now, that's when the steering gets stiff. So when you need to correct it to stay centered in the lane, it takes more pressure to turn the steering wheel, then for an instant, the electronic assist kicks in, the steering loosens up, and the car darts in the direction you were correcting it to go. Then it stiffens up right away, so when you correct it back, the process repeats. So I find myself zig-zagging down the lane. Now I find that if I move the steering wheel back and forth rapidly for a few times (not swerving the car, just shaking the steering wheel left-to-right slightly) I can make the car stop acting up and it will drive fine...sometimes for a long distance, sometimes for a short distance. It's like I have to wake up the steering so it will respond normally without jerking when you try to correct it. I hope this is a better explanation of what's going on with the steering.
Old 07-16-2011, 10:02 PM   #7
MN 2012 Ford Focus
Fan#: 87809
sehatch, thank you for direction to the other thread and for your support. I knew there must be others having the same issue with the steering as I am having. Thanks again!
Old 07-18-2011, 06:24 PM   #8
FordService
Official Ford Rep
FordService's Avatar
Fan#: 79824
What I Drive: Ford Focus
Points 3,469, Level 36
Points: 3,469, Level: 36 Points: 3,469, Level: 36 Points: 3,469, Level: 36
Level Up 80% Completed
Forum Activity 18%
Hi MN 2012 Ford Focus,
It is my pleasure to help with resolving your drifting concern. Please PM me with your VIN, contact information, mileage, and servicing dealer name/state so I can assist.
~Natasha
FORD SERVICE
p: 800.392.FORD
FordService is offline
Old 07-19-2011, 06:12 PM   #9
MN 2012 Ford Focus
Fan#: 87809
Why would I give you my peronal information and why can't my dealer take care of it?
Old 07-19-2011, 07:22 PM   #10
Phokus
Shiny Metal Titanium
Phokus's Avatar
Fan#: 60433
What I Drive: 2013 Performance Blue Titanium Seda
Points 12,706, Level 73
Points: 12,706, Level: 73 Points: 12,706, Level: 73 Points: 12,706, Level: 73
Level Up 64% Completed
FF Reputation: 7 Phokus Good Standing Member
Buy-Sell-Trade Rating: (9)
That's someone that works at Ford, they'll help you get things rolling if the dealer is resistant or unable to
1965 Mustang Coupe 289 4spd
2003 Land Rover Discovery II SE
2013 Lincoln MKZ Hybrid
Phokus is online now
