Road Racing & Rally The place to discuss information about road/rally racing stats, tips and events. Track sanctioned events only.
#11 | ||||
PS here is a video someone took of me coming around turn 9 I was probably just shifting into 4th after the turn.
http://youtu.be/SY6VemIIb90 Also I really need a new muffler. lol
NW Posse #30 |
| Sponsored Links | |||
Advertisement | |||
#12 | ||||
.Flat Out.
You could always try an app called 'Harry's Lap Timer Pro' it works for the iphone and believe Andriods.
it uses the GPS feature of your phone. it actually works pretty good. an alternate to the 500+ data loggers out there. i've used it a few times and it's amazing the info it can provide.
The Rich Get Richer Until The Poor Get Educated. Do Vegetarians eat Animal Crackers? Moderator of Ford Focus Racing Discussions & Rocky Mountain Fanatics |
#13 | ||||
Thanks for all the info, good stuff.
NW Posse #30 |
#14 | ||||
From the track map and satellite photo of the track you would need to get as much speed as possible exiting turn 8. A couple of mph there would give a higher top speed towards turn 2 if you could carry the speed through the jogs in the track. Similarly you will need to get out of turn 3B cleanly to make speed towards 5A.
From the videos you were using all of the track at the exit of 8 which is good. If you notice a number of the other cars were not. They were leaving a lot on the table by not finishing off the turn properly. I tell my students to get on the power as soon and as hard as they can to the point where you won’t need to get out of it. Most people apply too much throttle too early and too hard, then back out and back on again. It is a real momentum killer, especially in a low horsepower car. I ask my students if they have taken calculus (see, book learn’n ain’t all bad after all). Think about the area under a curve. A nice throttle application would be a smooth arc upwards that maximizes both the time the throttle is applied and the amount of throttle. Someone who gets on the throttle a tick later or applies it too soon and has to back off would have a jagged line with spikes and valleys. Less area under the curve. I run a SVT Focus with Cobalt pads, they are phenomenal. I do much of my “accelerating” while under braking because the car stops so well. Most folks starting out do not use their brakes as efficiently as they could. Many back off the throttle, coast down a ways then apply a little brake, then a little more before turn in. Exactly as you would while driving to work approaching a signal light. On track the rules are different. Keep on the throttle to the braking zone and then get on the brakes hard until turn in. If the car has ABS, find out where the threshold is and get as close to that point as you can before the turn. On a non ABS car it will take a bit more practice. As for more power, it is nice but won’t necessarily make you faster. I have a friend that I run with at Mosport. He has a SVT with Hoosiers and a Torsen. I have a PWSC SVT with NT01’s and a Torsen. So I have more power but his tires are a little stickier. When we go out to play I can run him down and pull away at will with my power advantage all day long. However, he has larger testicles than I. In turns 1 through 4 he carries way more speed than I am comfortable with. He brakes later and less and gets back on the power a little earlier. He also keeps the car up in the rev band while I tend to short shift. If we were in identical cars, he would simply pull away from me and it would appear to anyone watching that he had tons more power because of the distance he gains exiting the turns. In a 20-25 minute session he would probably be 3 or 4 turns ahead by the end of the session. |
#15 | ||||
If you are better in the corners and are on a guys ass coming to the straights the proper way to run is the guy let's you go and then the next lap you will stretch out on them. Most guys ego won't let them do this though and unless you have good corner workers that will help you with passing flags, ect or instructors that pay attention it is hard to do.
2009 EMRA Time Trail Tuner Under Champion 2010 EMRA Time Trail Tuner Over Champion 2001 Ford Focus ZX3 S2 with PWSC 265 whp |
#16 | ||||
What is a PWSC? I tried googling it but got no definitive answer. My best guess is a supercharger of some sort?
Yeah a lot of those guys wouldn't hold back and I don't blame them, I actually like the turns more than the straights I like the technical aspects of them. I've actually heard that Pacific raceways is probably one of the most technical courses around hear, with all the elevation changes and turns. I really hope to get to go out there and play more and learn as much as possible. I have started the process in getting my novice license now I just need to get a car prepped for racing or rent one. The original goal was to have the car built for Group 2 rally and just rally but I need to do something in between rally so I figure circuit racing would be a good choice since the operate year round. It may be a pain in the ass but I figure I could use the car as a dual purpose car. I figure id have to change out the suspension and wheels and I could get by. The cage is my biggest hurtle at the moment. I'm not sure if its the wisest plan. I have been looking at the Pro3's they seem fun and very cost effective to race on a budget.
NW Posse #30 |
#17 | ||||
.Flat Out.
Correct, it's a PowerWorksSuperCharger
i would just pick up a beater hatch for rally, then build it for rally only. less of a headache. plus Rally beats up the car pretty bad, i'm not sure if i'd want to rally a car then take it on the track where speeds can reach the triple digits..
#18 | ||||
NW Posse #30 |
#19 | ||||
FF Affiliate
A good way to add 20-30HP is a SVT header , 2.5 exh , drop in filter , TB and a tune would net you a good 20+ HP to the wheels and you will be surprised what it will do on the track , a lot of this you can find used here on FF
Focus-Power: Your #1 Source for Ford Focus Speed, Tuning & Performance! Customer Support AIM: hpdyno Email: tom@focus-power.com Phone: 704-249-3745 Site: focus-power.com Elder 1turbofocus |
#20 | ||||
I have a 2.5 exhaust in it (came with it) I'm going to get a new muffler because this one sounds horrible at high RPMs not natural sounding at all. I do plan on getting new TB and tune but also want to get new camshafts and valves, but not sure what order to do it in. I imagine the tune will be last, at least it makes sense. I also want new wheels but that comes in the "looks" category.
NW Posse #30 |
| Thread Tools | |
| Display Modes | |
