How to: Clean a Zetec IAC - Page 2 - Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum
Old 08-02-2011, 10:12 PM   #11
Reefmonster
Fan#: 88330
What I Drive: 2001 Green Focus SE Wagon
FF Reputation: 1 Reefmonster Good Standing Member
Awesome write-up! I have been looking on here for DAYS for a how-to for this...Thanks!
Reefmonster is offline
Old 08-03-2011, 10:11 AM   #12
foxyl6162
foxyl6162's Avatar
Fan#: 84165
What I Drive: 2002 GREY FOCUS ZTW ZETEC 156K
FF Reputation: 1 foxyl6162 Good Standing Member
I went to ford here and they have that listed as a IAC air bypass valve gasket was cg56?
foxyl6162 is offline
Old 11-03-2011, 04:22 PM   #13
Nrdyguy
Nrdyguy's Avatar
Fan#: 64151
What I Drive: 01' White SE Wagon
FF Reputation: 1 Nrdyguy Good Standing Member
Mods need to sticky this... been searching for day for this! thanks xecutionr !!!
Nrdyguy is offline
Old 11-03-2011, 08:05 PM   #14
coldbear
Fan#: 78292
What I Drive: 2014 Race Red 6/spd. SE
Points 1,358, Level 20
Points: 1,358, Level: 20 Points: 1,358, Level: 20 Points: 1,358, Level: 20
Level Up 58% Completed
FF Reputation: 1 coldbear Good Standing Member
I know you guys think I'm FOS, butI use SeaFoam in my oil/gas ans my IAC has not stuck again. Mabye I was lucky, mabye not. All I know my high throttle started operating again when the AC pump kicked in.
coldbear is offline
Old 02-01-2012, 01:45 PM   #15
my_beautious_ZX3
Fan#: 32386
What I Drive: 2002 charcoal XZ3
Points 1,342, Level 20
Points: 1,342, Level: 20 Points: 1,342, Level: 20 Points: 1,342, Level: 20
Level Up 43% Completed
FF Reputation: 5 my_beautious_ZX3 Good Standing Member
(1/4 inch is recommended, 1/2 inch is hard to use in tight spaces)
Thanks for the great write-up!!
My 1/4-inch Craftsman ratchet was too large for the bottom IAC bolt. I used a mini combination wrench (8mm or 5/16-inch). You don't need alot of leverage - IAC bolts are only torqued hand-tight. I also found a telescoping mirror to be helpful.
Before starting, grab a handful of Q-tips -- you'll need them to help the cleaning fluid do its job.
This job is definitely do-able -- but requires PATIENCE!!
"I'm jealous of girls because they get to wear dresses." (Todd Flanders)
my_beautious_ZX3 is offline
Old 02-02-2012, 07:45 AM   #16
RallieConGoggle
RallieConGoggle's Avatar
Fan#: 50774
What I Drive: 2007 CD Silver ZX4
Points 2,010, Level 27
Points: 2,010, Level: 27 Points: 2,010, Level: 27 Points: 2,010, Level: 27
Level Up 7% Completed
FF Reputation: 9 RallieConGoggle Good Standing Member
I prefer the easy way: idle the engine and squirt the cleaner in the throttle bypass until it stalls and let it sit for an hour. I know your way is better, but my way is easy enough to do every oil change or so.
Rally with your goggles on!
2000 Pitch Black ZTS Auto (230,000+ miles)
2007 CD Silver ZX4 SES 5spd
Zetec Crew #190
RallieConGoggle is offline
Old 02-10-2012, 12:30 PM   #17
Rob axel
Fan#: 90670
What I Drive: 08 f-250 van
FF Reputation: 1 Rob axel Good Standing Member
got my IAC removed...went to look back at these pics to compare...there gone..
My iac was pretty clean...I got a replacement, just in case....the new one has a spring inside. Installed it and the motor REVed high..took a while for it to idle down....
once it calmed down it was nice and smooth..UNTIL I TOUCHED THE THROTTLE....it peaked again in gear!
Took it for a spin....it was like having the cruise control on...gonna take it off, and put the old on back and see if the new one was bad..
anyone else have this issue?..
Rob axel is offline
Old 05-03-2012, 02:31 PM   #18
ligardner
Fan#: 32567
What I Drive: 02 Focus LX; 05 Focus ZX4; 02 Wago
Points 982, Level 16
Points: 982, Level: 16 Points: 982, Level: 16 Points: 982, Level: 16
Level Up 82% Completed
FF Reputation: 1 ligardner Good Standing Member
Rob,
I'm sorry to say that I have had the same issue. Replaced the IAC with a new one but could not the gasket on. (major mistake). now when i start the car it revs way too high for like 5 minutes and then comes to a normal idle. But the thing is messed up because it accelerates on its own at 40 mph with my foot off the gas.
I will remove this IAC and put the gasket on like i should have. According to the experts/moderators on this site, a vacuum leak around the gasket can be the cause. Since all i fooled with was the IAC (plus cleaning TB) it appears the gasket (lack-of) is implicated.
I'll report back whhat happens with the new gasket.
ligardner is offline
Old 05-04-2012, 09:20 PM   #19
coldbear
Fan#: 78292
Sugestion???
Buy the unit through FMC because of the stricter standards they require the IAC manufacturer to adhere to. Fix it once and ferget it.
coldbear is offline
Old 05-31-2012, 03:01 PM   #20
Lucille92
Fan#: 99631
What I Drive: 2002 Black SE
FF Reputation: 1 Lucille92 Good Standing Member
Can the pictures from the first post be put back up? I live about 3 hours away from the car and would like to know what everything looks like before i clean or replace the IAC valve.
Lucille92 is offline
