How to: Clean a Zetec IAC - Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum
Old 07-12-2011, 11:25 AM   #1
xecutionr
Haterz gonna Hate
xecutionr's Avatar
Fan#: 55434
What I Drive: 2003 Frost Silver zx3
Points 15,154, Level 79
Points: 15,154, Level: 79 Points: 15,154, Level: 79 Points: 15,154, Level: 79
Level Up 61% Completed
Level up: 61% Level up: 61% Level up: 61%
FF Reputation: 18 xecutionr Great Standing Member
Buy-Sell-Trade Rating: (11)
This thread is to help everyone with that nasty idle problem with higher mileage Zetecs.
Tools needed:
2 Jack stands
1 Jack]
flat head screw driver
8mm socket with ratchet
(1/4 inch is recommended, 1/2 inch is hard to use in tight spaces)
Carb/Choke Cleaner (semi large can depends on how much buildup there is)
Step 1: raise and support focus with jack stands
Step 2: get your flat head screw driver and take off the intake tube on the throttle body so you can gain access to the IAC when you take it off from underneath
Step 3: get under the car with your 8mm socket ratchet and start feeling up in behind the starter on the intake manifold there should be two bolts loosen them up and then take them out with your hand, they are easy to take out. The IAC Looks like this on the intake manifold, the silver cylinder looking thing.
here is a pic of the IAC location from under the car you can tell its really hidden away
Step 4: once the IAC bolts are out it should be sitting in there because of the tight space, it wont fall out because there is a wire connected to it. get back on topside of the car and grab this wire that my index finger is pointing/laying on and that is the wire you can use to pull the IAC out..
dont jerk manuver the IAC around from atop so that it can easily be pulled out.
Step 5: grab your carb cleaner and go to town on inside of the IAC valve
BEFORE
AFTER
Step 6: let the IAC valve dry in the sun or just air dry until no cleaner comes out of it. then reinstall!
Hope this helps everyone that has this problem!
Zetec Crew #343
1979 Ford F-150 Custom 200,000 and counting
2003 Ford Focus Zx3 - 130,000 and counting (DD)
xecutionr is offline
Old 07-12-2011, 11:49 AM   #2
xxMichaelAnthony
xxMichaelAnthony's Avatar
Fan#: 58459
What I Drive: 2001 CD Silver ZX3
Points 15,532, Level 80
Points: 15,532, Level: 80 Points: 15,532, Level: 80 Points: 15,532, Level: 80
Level Up 37% Completed
Level up: 37% Level up: 37% Level up: 37%
Forum Activity 2%
FF Reputation: 20 xxMichaelAnthony Great Standing Member
Use THROTTLE BODY cleaner. Most cars have a teflon or similar coating inside metal intake parts. Carb and break clean will take it right off and it will start to pit like a son of a bitch. I found this out when I cleaned the IAC and throttle body in my Ranger. Had to buy a new throttle body and IAC. The butter fly in my throttle body seized up and the IAC seized also. Better safe then sorry.
http://effyeahfordcars.tumblr.com
[HOONIGAN]
iTroll
xxMichaelAnthony is offline
Old 07-12-2011, 11:55 AM   #3
xecutionr
Haterz gonna Hate
xecutionr's Avatar
Fan#: 55434
Originally Posted by xxMichaelAnthony View Post
Use THROTTLE BODY cleaner. Most cars have a teflon or similar coating inside metal intake parts. Carb and break clean will take it right off and it will start to pit like a son of a bitch. I found this out when I cleaned the IAC and throttle body in my Ranger. Had to buy a new throttle body and IAC. The buffer fly in my throttle body seized up and the IAC seized also. Better safe then sorry.
It can cause pitting, but most likely wont.. the carb cleaner is more harsh on the sensors around the TB because it is formulated to remove heavy varnishes found in carburetors. so that means it should be 100% okay to sue on the IAC since it is a valve. dozens of people have used carb cleaner on it it just is stronger than the Throttle body cleaner
Zetec Crew #343
Old 07-12-2011, 12:22 PM   #4
woodyg
Fan#: 86430
What I Drive: 2002 ZX3,Zetec, Black, AC, Moonroof
FF Reputation: 1 woodyg Good Standing Member
good write up.......I agree with the TB cleaner.....On my Ford Rangers sites they suggest just cleaning...on my Saab forums they suggest to clean and oil it with engine oil........I am not sure what is the correct way?
2002 Focus ZX3, Zetec 2.0, Auto, 106k. RECENT WORK= 5w-20 , Coil, T-stat housing and flush, Autolite APP5364, new steering Rack, full tuneup, tranny filter swap and fluid exchange. SOLD(Grandma gave my kid her Camry. I really liked the zx3 )
woodyg is offline
Old 07-13-2011, 01:21 PM   #5
xecutionr
Haterz gonna Hate
xecutionr's Avatar
Fan#: 55434
bump let's get this thing int he HOW to section. there is no how to on this and alot of people dont know how to do this...
Zetec Crew #343
Old 07-13-2011, 07:53 PM   #6
1stTimeFocus00
Fan#: 44202
What I Drive: 2000 InfaRed Zx3
FF Reputation: 27 1stTimeFocus00 Great Standing Member
Buy-Sell-Trade Rating: (9)
Agreed, I wish i would of had these pictures last summer...couldn't find the damn thing.
Zetec Crew #152
United States Army
1stTimeFocus00 is offline
Old 07-13-2011, 09:13 PM   #7
JDsFocus
Guest
Fan#:
Posts: n/a
Great write up - this should be Stickied!!
Old 07-13-2011, 10:53 PM   #8
xecutionr
Haterz gonna Hate
xecutionr's Avatar
Fan#: 55434
thanks guys!
Zetec Crew #343
Old 07-15-2011, 01:24 PM   #9
xecutionr
Haterz gonna Hate
xecutionr's Avatar
Fan#: 55434
bump, lets get this stickied
Zetec Crew #343
Old 07-30-2011, 11:22 PM   #10
faliol
Fan#: 23038
FF Reputation: 1 faliol Good Standing Member
Can the IAC be cleaned with CRS MAF cleaner?
faliol is offline
