Transmission Leak ? - Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum
Old 07-07-2011, 03:51 PM   #1
arrora_1234
Fan#: 87539
What I Drive: 2000
FF Reputation: 1 arrora_1234 Good Standing Member
Transmission Leak ?
I saw little bit oily (Black Colour) at the bottom of my Transmission (I hope) as shown in the picture. No dipping and no problem in driving, but I am worried that it is an early sign of an imminent failure. Car model-
Ford Focus SE Wagon 2000
125,000 KM
Transmission Fluid was changed with Motorcraft Markon-V 3 years ago along with filter at 80K KM. I always do oil change with Castrol 5W30 @5K and in winter I put Castrol Full synthetic 5W30.
Is this my transmission leaking or engine oil leaking? The colour of the oil is black and areas is just wet, no dipping. It is been like this for last 2 months.
I will greatly appreciate any expert suggestion to fix it.
AR
arrora_1234 is offline
Old 07-07-2011, 05:53 PM   #2
bflesher
Fan#: 84132
What I Drive: 2002 sangria red zx3, 02 yellow zx3
Points 135, Level 2
Points: 135, Level: 2 Points: 135, Level: 2 Points: 135, Level: 2
Level Up 70% Completed
FF Reputation: 1 bflesher Good Standing Member
As long as the fluid levels okay I would not worry to much.
bflesher is offline
Old 07-08-2011, 12:18 AM   #3
arrora_1234
Fan#: 87539
What I Drive: 2000
Look at the picture I just uploaded. I am really worried. Is it a transmission fluid or engine oil leak ? It is black and oily...so definitely not coolent.
Old 07-08-2011, 01:49 AM   #4
Grumpy
Fan#: 43791
What I Drive: 2005 Sonic Blue ZX3
FF Reputation: 28 Grumpy Great Standing Member
For pete's sake.......you've got to help yourself on this. It appears that the leak could be originating from above. I don't think it's tranny fluid, mind you. Have you at least opened the hood and checked yourself for leaks from the camshaft cover etc. Check the simple things first. This is difficult to troubleshoot simply from a photo. It's a very slow leak whatever it is. Clean it all off and after a few days check for signs of "fresh" fluid. This is a SPI, correct?
Grumpy is offline
Old 07-08-2011, 03:49 AM   #5
Diesel
Diesel's Avatar
Fan#: 86584
What I Drive: 99 zx2, 04 focus wife's car
Points 1,749, Level 24
Points: 1,749, Level: 24 Points: 1,749, Level: 24 Points: 1,749, Level: 24
Level Up 49% Completed
FF Reputation: 2 Diesel Good Standing Member
it's oil leak. it's probally comming from the upper base pan/windeage tray there is a gasket between it and the rear main seal that leaks on these.
Rims, fog light conversion, Interrior lighting recolor from starfuryt
Diesel is offline
Old 07-08-2011, 05:44 AM   #6
bflesher
Fan#: 84132
Points 135, Level 2
I would file that in the "not a problem" file. If fluid levels are fine then don't worry.
bflesher is offline
Old 07-08-2011, 08:49 AM   #7
woodyg
Fan#: 86430
What I Drive: 2002 ZX3,Zetec, Black, AC, Moonroof
FF Reputation: 1 woodyg Good Standing Member
there was more grease on my burger I ate last night.......that being said.....I agree with the idea of doing some looking of your own...I keep all my vehicles engine compartments and suspensions clean......that way if there is a leak starting I can tell where it is coming from...I think your tstat housing is right above that "leak".....they fail and leak a little coolant and along with a leaky VC gasket and maybe some from the rear main-seal.....could be contributing to it.............clean it all up first..
did you buy the car new?
some people have had very good luck with a Auto-rx treatment.........do some research about auto-rx
2002 Focus ZX3, Zetec 2.0, Auto, 106k. RECENT WORK= 5w-20 , Coil, T-stat housing and flush, Autolite APP5364, new steering Rack, full tuneup, tranny filter swap and fluid exchange. SOLD(Grandma gave my kid her Camry. I really liked the zx3 )
woodyg is offline
Old 07-08-2011, 10:00 AM   #8
arrora_1234
Fan#: 87539
What I Drive: 2000
Thank you all for overwhelming suggestions. I will clean the area this weekend and try to locate the origin of the leak and report you back. Yes... it is SPI engine and I been driving this car for last 3 years.
RA
Old 04-21-2014, 09:39 PM   #9
Medicus
Fan#: 157842
What I Drive: 2002 Ford Focus ZTS
FF Reputation: 1 Medicus Good Standing Member
Any updates on what was going on with your transmission. Mine is leaking from the same spot. Mine was a lot cleaner but I was able to tell it was coming out of a small opening in the transmission and under where your picture was taken there is like a vent hole that its leaking from also. It leaks about a quarter size a day without even driving it. I also just changed the fluid so it was up to full not over.
Medicus is offline
Old 04-21-2014, 11:27 PM   #10
elsolo
elsolo's Avatar
Fan#: 96835
Points 2,576, Level 30
Points: 2,576, Level: 30 Points: 2,576, Level: 30 Points: 2,576, Level: 30
Level Up 84% Completed
Forum Activity 8%
That's most likely a small seepage leak coming from the rear main seal. Not concerning unless it starts losing enough fluid between oil changes to need to add more, or the small spots on your driveway are a concern.
2.3, home fabbed Mustang GT brakes, SVT suspension
67 Chevelle SS-496, owned since 1991
elsolo is offline
