trunk release - Page 3 - Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum
Old 08-23-2012, 11:50 AM   #21
hotleadsingerguy
hotleadsingerguy's Avatar
Fan#: 86687
What I Drive: 2012 Black Titanium 5-Door
FF Reputation: 5 hotleadsingerguy Good Standing Member
The rubber button above the license plate works with the IA system, so if you have the FOB on you just using the button will open the trunk, no matter if the doors are unlocked or not. I can't say anything about it other than using the IA system.
Outside of that, there's absolutely no trunk release from within the car.
hotleadsingerguy is offline
Old 08-23-2012, 11:57 AM   #22
TboneZX3
Ford Fiend
TboneZX3's Avatar
Fan#: 90494
Points 1,277, Level 19
Level Up 77% Completed
On the non-IA systems, the hatch release will not work unless the passenger doors & hatch are unlocked. There is also a hatch release button on the key/remote to unlock and pop the hatch if you push it twice.
Hatch Nation #90
TboneZX3 is offline
Old 08-23-2012, 12:08 PM   #23
Tiger-Heli
Fan#: 12379
What I Drive: 2002 French Blue SE Sedan
Points 904, Level 16
Points: 904, Level: 16 Points: 904, Level: 16 Points: 904, Level: 16
Level Up 4% Completed
Forum Activity 9%
FF Reputation: 4 Tiger-Heli Good Standing Member
On the 2012 - apparently there is on the 2013 - unless the Owner's manual and the graphics on the headlight switches are lying...
Tiger-Heli is online now
Old 08-23-2012, 12:26 PM   #24
TboneZX3
Ford Fiend
TboneZX3's Avatar
Fan#: 90494
Yes, that is interesting... Thanks for the pic above.
Hatch Nation #90
TboneZX3 is offline
Old 08-23-2012, 12:38 PM   #25
BetaDnB
Drum n Bass Lover
BetaDnB's Avatar
Fan#: 87466
What I Drive: 2012 Silver SE Sport
Points 2,291, Level 28
Points: 2,291, Level: 28 Points: 2,291, Level: 28 Points: 2,291, Level: 28
Level Up 94% Completed
Forum Activity 3%
FF Reputation: 13 BetaDnB Great Standing Member
Interesting indeed. I wonder if we'd be able to simply switch that control unit piece to have the luxury of the release button.
Sedan Revolution #249 - 2012 SE Sport - ╠╬╝ - Ingot Silver - 201A - K&N w/ snorkel delete - Blox Type R Knob
BetaDnB is online now
Old 08-23-2012, 01:08 PM   #26
Tiger-Heli
Fan#: 12379
Forum Activity 9%
http://www.focusfanatics.com/forum/s...=290882&page=2
Highly doubtful - the same switches were used for fog lights in the 2012 and swapping the switches DID NOT enable the fog lights, even though the wiring out of the BCM was there.
I suspect at MINIMUM you would have to swap the switch and have the dealer flash the appropriate section of the as-built codes from a 2013 similar car.
More likely the BCM's are probably different and you'd have to swap in a 2013 BCM - and I'm not sure that would even work.
Sorry for the bad news.
Other possibility would be the BCM always had wiring for the switch and circuitry for it and you just have to install the switch to get it to work like you said.
(Ford does some odd things sometimes - you have to re-wire the entire car to add factory fog lights (and then you still can't use the factory switches), but installing cruise control is just a matter of swapping the steering wheels so you have the correct activation switches - go figure!!!)
Good news is there likely isn't any additional wiring to run - if it does work.
Old 08-23-2012, 03:02 PM   #27
TboneZX3
Ford Fiend
TboneZX3's Avatar
Fan#: 90494
Oh well. Though I thought I would miss the interior release when I bought the car, I don't. After all, whenever I want to get in the hatch, I'm standing right there where I can hit the button on the hatch itself.
Hatch Nation #90
TboneZX3 is offline
Old 08-23-2012, 04:15 PM   #28
BetaDnB
Drum n Bass Lover
BetaDnB's Avatar
Fan#: 87466
Forum Activity 3%
After reading through the OEM fog light installation on an S model, I'm going to go ahead and say it won't be worth the time and effort to have the new trunk release button. The two releases I have are good enough for me.
Old 08-23-2012, 05:54 PM   #29
thelaw65
Fan#: 102812
What I Drive: 2012 Black Focus
FF Reputation: 1 thelaw65 Good Standing Member
Auto lights work with a switch swap on the S. So it is possible. But since it's new to the 13 models I'm gonna say it won't work.
thelaw65 is offline
Old 08-24-2012, 09:09 AM   #30
Tiger-Heli
Fan#: 12379
Forum Activity 9%
Unless/Until someone tries it, there's no way to tell.
The headlight switch sends Pulse-code modulated signals to the BCM. It's possible the 2012 BCM had all the circuitry and Ford just left out the switch to save cost - but not likely.
