2012 focus select shift - Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum
Old 07-04-2011, 09:42 PM   #1
2012TI
Fan#: 87295
What I Drive: 12 titanium blue candy, 2001 SVT co
FF Reputation: 1 2012TI Good Standing Member
Question if you put the new focus in sport mode (s) on the gear selector stick, what is this doing other than allowing you to shift the trans when you want to (witch is very nice by the way no complaints on that) does this change the shift points for the trans if you let it shift on its own or is it just for shifting on your own?
Thanks
2012TI is offline
Old 07-04-2011, 10:23 PM   #2
halfmoonclip
Fan#: 87235
What I Drive: '12 Ingot Silver SEL
FF Reputation: 1 halfmoonclip Good Standing Member
If I recall correctly from a test drive, the 's' will hold it in gear to redline unless you manually bump it up to the next gear. Also, it will shift to the next gear when redline is reached; it won't hold it in the lower gear.
Moon
halfmoonclip is offline
Old 07-05-2011, 12:28 AM   #3
DrkKnight614
GO Green
DrkKnight614's Avatar
Fan#: 14522
Points 26,111, Level 96
Points: 26,111, Level: 96 Points: 26,111, Level: 96 Points: 26,111, Level: 96
Level Up 77% Completed
FF Reputation: 47 DrkKnight614 Great Standing Member
Posted via FF Mobile It does change the shifts compared to D.
DrkKnight614 is offline
Old 07-05-2011, 12:46 AM   #4
entity
Fan#: 85163
What I Drive: 2012 Focus Titanium
FF Reputation: 1 entity Good Standing Member
I haven't experimented yet, but I think it is as follows.
When in 'S' mode, the transmission will hold gears longer when accelerating, and downshift quicker when braking. It will only redline a gear if the pedal is floored or if you initiated manual shifting with the rocker switch and haven't upshift. It will not let you stall out. Once you initiate manual shifting with the rocker switch (and transmission in 'S'), you have to shift back to 'D' to stop the manual override.
If I'm wrong, please correct me!
entity is offline
Old 07-05-2011, 07:47 AM   #5
TitaniumFred
TitaniumFred's Avatar
Fan#: 86524
What I Drive: 2012 Silver Titanium HB
FF Reputation: 1 TitaniumFred Good Standing Member
From my experience, it behaves as follows:
  • Will not switch to the 6th gear
  • Computer changes to a more aggressive shifting mode as others have described above
  • If you shift with the buttons, you can not go back to computer shifting unless you move the gear shift lever back into D first
  • Computer will try to anticipate your acceleration demands and hold RPMs accordingly
  • Computer will use engine braking (downshifts) when you apply the brakes
TitaniumFred is offline
Old 07-05-2011, 10:14 AM   #6
halfmoonclip
Fan#: 87235
That would make sense from my test drive; I recall it holding to redline when I really caned it, but it shifted less aggressively otherwise.
Moon
