2006 Ford Focus Problems - Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum
Old 07-02-2011, 03:31 PM   #1
smilintodd
Fan#: 83867
What I Drive: 2006 Ford Focus ZX4 SES
FF Reputation: 1 smilintodd Good Standing Member
Hey guys, my wifes 2006 Focus had a hit and run the other day and now we are having problems with it. It just got backed into and just made a small dent in the trunk(though person who saw it happen said it was enough force to move the vehicle)
On the way driving home it died, and I managed to limp it home. First thought it was bad gas, so siphoned gas out and tried pure gas(no ethanol) that didnt work. Also replaced fuel filter, and I can hear the fuel pump come on so i think that is ok.
I can start the car and it will idle for a few seconds and die, and I can consistently do that, it doesnt do it once and then not start again. I can also start it and pedal the gas a little, have it reved up to 3000 rpms and it will run like that for maybe 15 seconds and then it tries to stall out.
My dad drove it and had the check engine light come on and got a P2195 and P2196 code to show, but after resetting it the light doesnt come back on.
I don't know where to go from here, not sure if I need to be replacing o2 sensors, and don't want to invest in them if thats not the problem.
Thanks in advance for any help
Todd
smilintodd is offline
Old 07-02-2011, 04:10 PM   #2
A.D.D. Focus
Fan#: 80847
What I Drive: 2006 Blue ZX4 SE SAP
FF Reputation: 1 A.D.D. Focus Good Standing Member
This probably isn't the solution but I'm curious if the fuel cut off switch was switched. Would it cause problems like this? Or would it simply not run?
A.D.D. Focus is offline
Old 07-02-2011, 04:11 PM   #3
smilintodd
Fan#: 83867
Well I read about, it says that in an accident it could bump that switch. If so you just need to hit the reset button, so I did. No real difference.
Old 07-02-2011, 09:25 PM   #4
nightshifter999
nightshifter999's Avatar
Fan#: 54744
What I Drive: 2003 GREY ZX3 FOCUS
FF Reputation: 1 nightshifter999 Good Standing Member
My focus is showing the P2195 code for the O2 sensor and a P0171 for sytem lean sensor1. It was showing one for the EGR, but i cleaned it and it is working for now. Any guess on whats going on?
nightshifter999 is offline
Old 07-02-2011, 11:34 PM   #5
smilintodd
Fan#: 83867
Whats the EGR? I got it work to what seems to be fine now. Not sure if its a combination of cleaning the mass air flow sensor or taking the negative terminal off the battery for a while. I did the battery earlier and it didnt seem to do anything.
Old 07-08-2011, 10:32 PM   #6
nightshifter999
Fan#: 54744
Usually it takes a couple cycles for the code to show back up. Hope yours stays off. I went to get parts for mine today. Took it to get it diagnosed and it took the guy 2min. to locate a vacuum leak on the back of the motor behind/below the throttlebody. I gotta fine those at the dealer tomorrow and hopefully i can have it purring once again!
Old 07-08-2011, 10:48 PM   #7
DEMENTED SVTF
PARTS HUNTER
DEMENTED SVTF's Avatar
Fan#: 71669
What I Drive: 2013 F150 FX2 5.0 SUPERCAB
FF Reputation: 9 DEMENTED SVTF Good Standing Member
Buy-Sell-Trade Rating: (18)
U might have more help if u posted in the technical chat rather than visual mod section
2013 F-150 FX2 SUPERCAB 5.0 BRIGHT RED. HIDS, NAVIGATION
LEATHER, SONY 700WATT SYSTEM, 9.8 1/8 mile for now stock
DEMENTED SVTF is offline
