#31 | ||||
It's peace of mind for me to change my oil every 3,000 miles & I do it myself......some
people make their bed everyday.....I don't. To each his own.
2012 Sterling Gray/Titanium/Sport Handling Pkg/NAV/Winter Pkg/Rapid Spec/Remote Start/K&N Order Date: May 23, 2011 Born Date: June 20, 2011 Delivery Date: June 29, 2011 |
#32 | ||||
As far as the reset default it has to be at least what they expect the maximum oil change interval could be. Why the chose 20,000 miles; could be they expect better oil in the future that will allow for longer drain intervals and it would be an easier software update if they didn't have to change that constant. I doubt it was sloppy programing. |
#33 | ||||
#34 | ||||
How tough is the filter/oil plug to access? My bride's Panzer has a bellypan that is an SOB to remove if the car isn't on a lift, so I finally said the hell with it and let the dealer do it.
She had a Pontiac Bonneville years ago with a filter that you could see with the hood up, but you couldn't actually touch it enough to remove it without taking off a wheel. Anyway, I'd rather do my own changes; any problems getting at things? Moon |
#35 | ||||
The filter is at the front/center of the car. It is in a great spot and hangs completely down.....not sideways or at an angle. Easy to spin off and it isn't touching anything else so oil doesn't run down the side of the block/pan. I like it since it allows you to fill the filter with oil completely before spinning it on allowing for a non "dry start." The plug is in the center pointing towards the rear of the car. 15mm wrench will get it off. Both filter and plug are in great spots to allow a clean easy change with little clean up. Ford designed this one right.
#36 | ||||
Titanium, thnx for the comeback and explanation. I'll have a look at it when my car arrives; the older I get, the less patience I have with boolchit jobs, so I may just let the dealer change it. I used to change oil at 1K (!) and 3K miles, and always changed a new car's oil after 1K. I just won't do that anymore, and it really isn't necessary. My long suffering TJ Jeep gets changed once a year these days since the old girl doesn't see a lot of miles (at 17 mpg....).
As far as the speculation about the oil change monitor, my current Fit has such thing, and I'm sure it is a computer-generated WAG using number of starts/run time and whatever other input all the little 0s and 1s can generate. It is helpful, since you don't have to keep track. My kid's Caliber has two trip odometers, and she zeros the one when I change her oil; when it hits 7K she says '....Daaaaaad...". Of course, being old school, I put a label under the hood too.... Moon |
#37 | ||||
have to wonder how that under-body fabric cover will last to a WI winter. i'm sure by next spring it will be nasty, torn and need to be removed anyway.
#39 | ||||
Took mine to the dealer today for regular maintenance at 4,500 miles (slightly early) and they had no clue about any oil monitor. They actually asked me if it had one. They had two guys tinkering around the menus trying to figure it out & concluded that my car had no oil monitoring system - neither one you could look up in the menu comp or one they could operate with their equipment. They said if a lights comes on to bring it back.
#40 | ||||
This video shows how to reset it (starts around 2:00).
http://owner.ford.com/servlet/Conten...rd&model=Focus |
| Thread Tools | |
| Display Modes | |
