Keyless entry keypad? - Page 6 - Ford Focus Forum, Ford Focus ST Forum
Go Back   Ford Focus Forum, Ford Focus ST Forum > Ford Focus Third Generation > MK3 Focus
Old 03-21-2014, 08:34 PM   #51
jet_mech_tech
jet_mech_tech's Avatar
Fan#: 107534
What I Drive: 2013 Focus Titanium (Black)
Points 58, Level 1
Points: 58, Level: 1 Points: 58, Level: 1 Points: 58, Level: 1
Level Up 16% Completed
Level up: 16% Level up: 16% Level up: 16%
FF Reputation: 1 jet_mech_tech Good Standing Member
What about this for people with IA.
What about this for the people with IA.
1.Program the keypad (if you even can) first. <<not sure if this is even possible with push button start and IA fob.>>
2.Then place your fob in a foil bag (we have them at work for avionics in a plane) / that will block the IA signal. Place keys in a hidden place (like glove box/center console.
3. When you leave/approach car use keypad. Then pull fob out of bag. Drive away.
I only throw this out there as i do mountain biking and don't want to be carrying my keys around the forest.
jet_mech_tech is offline
Old 05-09-2014, 11:45 AM   #52
DiscBreaks
Fan#: 162186
What I Drive: 2014 Sterling Gray SE Sport
FF Reputation: 1 DiscBreaks Good Standing Member
Originally Posted by wavsine View Post
Try this. Turn the key from the OFF position to RUN (not START) position eight times within 10 seconds with the eighth turn ending in the RUN position.
Contrary to the instructions, the locks may not cycle to confirm programming mode.
http://www.partscheap.com/v/vspfiles...fordkeypad.pdf
I just got a keypad for my 2014 SE. At first I could not get it programmed following the directions that came with the keypad and later the directions wavsine posted.
I was able to get it programmed by turning the key eight times and ending in the OFF position.
The locks did not cycle, but I got chimes when it entered programming mode and each time I pressed a button on my keys or the keypad.
I hope this saves someone else the frustration.
DiscBreaks is offline
Old 05-09-2014, 12:21 PM   #53
peppersmum
Fan#: 98989
What I Drive: 2012 Focus Hatchback SE Red Candy
Points 43, Level 1
Points: 43, Level: 1 Points: 43, Level: 1 Points: 43, Level: 1
Level Up 86% Completed
FF Reputation: 1 peppersmum Good Standing Member
Keyless key pad
The problem I'm having is when I program one remote then my other one doesn't work. I programmed it and then the first one doesn't work. How to get them both programmed and working!
peppersmum is offline
Old 05-09-2014, 12:33 PM   #54
SilverPony2001
SilverPony2001's Avatar
Fan#: 27073
What I Drive: 2013 SGM Sedan SE
Points 5,896, Level 49
Points: 5,896, Level: 49 Points: 5,896, Level: 49 Points: 5,896, Level: 49
Level Up 73% Completed
Level up: 73% Level up: 73% Level up: 73%
Forum Activity 10%
FF Reputation: 9 SilverPony2001 Good Standing Member
You have to program all of them at the same time.
SilverPony2001 is offline
Old 05-09-2014, 01:56 PM   #55
Kjanracing
Kjanracing's Avatar
Fan#: 135409
What I Drive: 2014 Ruby Red SE hatch with DCT
Points 462, Level 9
Points: 462, Level: 9 Points: 462, Level: 9 Points: 462, Level: 9
Level Up 24% Completed
FF Reputation: 2 Kjanracing Good Standing Member
I ended up having the dealer program mine. I just couldn't get it to go into programming mode. I did try the 8 cycles. anyway, done. I mounted the remote under the tail gate lip, to the left of the latch/light. If I'm not going to carry my keys, that is always the first door I'm in and out of.
K&N drop in. Ceramic Smervic bearing retrofit. DCT Phase Detractor delete. Injected Tune. Back Joy seat cushion.
Kjanracing is offline
Old 05-09-2014, 02:45 PM   #56
DiscBreaks
Fan#: 162186
Pepper, the instructions linked above are accurate on that point. You need to hit a button on one remote and then a button on the next remote within 10 seconds, hearing a sound each time for as many remotes as you have. It might be possible to do that too fast also. Wait one or two seconds between each remote and make sure you hear the sound.
That's where I was thinking about putting mine. Also considering the underside of the driver side mirror just to be a little closer to the door. Glad you got it worked out.
Old 05-09-2014, 03:46 PM   #57
peppersmum
Fan#: 98989
Points 43, Level 1
Thanks all, will be trying it again next week when I have time.
Old 06-01-2014, 07:22 AM   #58
Pennut
Pennut's Avatar
Fan#: 91326
What I Drive: 2012 Sterling Grey SE Hatchback
Points 1,386, Level 20
Points: 1,386, Level: 20 Points: 1,386, Level: 20 Points: 1,386, Level: 20
Forum Activity 3%
FF Reputation: 4 Pennut Good Standing Member
So I finally decided where to put my keypad. I went through the trouble of sanding it and painting it body color, but when I put it above the drivers side door handle, it stuck out like a wart as some people have called it. And since it won't fit in the gas cap compartment, I stuck it under the license plate cut out (facing downwards of course). There's a perfectly flat area there and it's hardly noticeable when looking at it from behind if you paint it body color. It's a little more inconvenient perhaps compared to mounting it above the door handle because you have to bend down and look underneath to punch in the numbers, but for me anyways, it's just a back up if I was to lock my keys in my car by accident (I did that once on a road trip last year :( ) or if I was at the beach perhaps. Plus I doubt potential vandals would notice it there.
Programming was super easy. Just have to have both sets of car keys. I only ever used my one set of keys so the other new one was locked in my safe. Found out that the new key set wasn't even programmed! So when I was doing the steps I programmed the other set of keys at the same time during the set up process. Took me maybe 5 minutes for set up/programming.
It's not really that noticeable as in the first picture. That is light hitting at an angle creating a reflection, as you can see in this enlarged picture:
Only bright sunlight hitting at an angle is there a reflection. Most of the time there is no reflection. At a slightly higher angle, cant really see the keypad at all:
Pennut is offline
Old 06-01-2014, 09:09 PM   #59
DiscBreaks
Fan#: 162186
Nice, Pennut!
Thats the same place I have mine, albeit on a sedan. I use mine pretty often, so it was easy enough to learn to feel the buttons and press the code without looking at the keypad.
Old 06-01-2014, 09:13 PM   #60
DiscBreaks
Fan#: 162186
Do you think you could post a picture of the keypad itself? I'm curious to see what it looks like painted to match the car.
Focus Fanatics Ford Focus Forum offers many fun ways for you to engage with other Ford Focus Owners from across the world. Whether it be about the aftermarket performance modifications, technical how-to's, European tuned suspension or awesome fuel economy similar to the Cadillac ATS-V, Ford Fusion and Acura TLX. You can find all Ford Focus and Focus ST related information here. Join our Ford Focus discussion forums and chat with local Focus enthusiasts in your area.
