Squeaks, creaks, and rattles - Page 7 - Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum
Old 12-05-2011, 10:34 AM   #61
PratoN
PratoN's Avatar
Fan#: 88058
Points 3,090, Level 34
Points: 3,090, Level: 34 Points: 3,090, Level: 34 Points: 3,090, Level: 34
Level Up 27% Completed
Forum Activity 4%
FF Reputation: 15 PratoN Great Standing Member
I had them fix my rattles, but when I got my new headliner, a new one surfaced somewhere near my left ear (super-annoying). Noticeable when driving - worse with music. I'm not sure if it's the passenger door or coming from the B pillar cover.
PratoN is online now
Old 12-05-2011, 12:14 PM   #62
chum567
Fan#: 86507
What I Drive: 2012 Sterling Gray Focus SEL
FF Reputation: 1 chum567 Good Standing Member
Anyone have a rattling/squealing noise coming from their left driver side vent. I'm almost positive its coming from the vent and not the steering wheel but I'm not 100%. Its very annoying and when I took it to the dealer they said they could not replicate sound but it only does it when you are driving. Doesn't matter if air is on or not but I hear it everyday when i drive so I was surprised they couldn't replicate. I will take it back this weekend and do a ride along. But has anyone else had this issue?
chum567 is offline
Old 12-05-2011, 12:55 PM   #63
entity
Fan#: 85163
What I Drive: 2012 Focus Titanium
FF Reputation: 1 entity Good Standing Member
Your issue sounds like mine. When it happens, apply pressure to the top of the gauge cluster housing furthest to the left. I found that the source of my squeak, even though I thought it had something to do with the vent. It goes in tomorrow and the service manager said he would take care of it.
entity is offline
Old 12-05-2011, 02:23 PM   #64
chum567
Fan#: 86507
Thanks! i will try that on my way home from work
chum567 is offline
Old 12-11-2011, 08:11 AM   #65
JesseE1981
Fan#: 88551
What I Drive: 2012 Sterling Grey Focus Hatchback
FF Reputation: 1 JesseE1981 Good Standing Member
I have a rattle sound just in front of the moon roof on the passenger side. I've read through this thread, and people keep mentioning failed glue. Well, I opened my moon roof so I could stick my head up and look between the roof of the car and the headliner, and I don't have glue along the front edge. What I have are two heavy duty "velcro" pieces on each side (thick plastic velcro). The sound I hear when I push my headliner up, is the velcro pieces sticking tighter tighter. When I let go of the headliner, the sound I hear is the velcro pieces coming apart a little. It seems as though the interlocking pieces of the velcro won't "mash" together as tight as what it seems they should, and the end result is a rattle. I thought I could use some double-sided tape to hole it up better just so the rattle goes away, but there really isn't any where to put siad tape. I'd rather find a solution of my own, but I'm not sure what I could wedge in there to keep it from moving. I know a trip to the dealer is going to result in a non-fix on their end.
JesseE1981 is offline
Old 12-12-2011, 09:18 AM   #66
chum567
Fan#: 86507
did you get this fixed? You were right thats the same thing on mine.
chum567 is offline
Old 12-12-2011, 08:51 PM   #67
JesseE1981
Fan#: 88551
Does anyone else have the velcro holding the headliner area in front of the moonroof not holding together tightly? Almost positive this is the cause of the rattles I am hearing in my headliner.
Old 12-12-2011, 09:22 PM   #68
flingwing1969
flingwing1969's Avatar
Fan#: 91700
What I Drive: 2012 white platinum Forcus SEL 303A
Points 1,131, Level 18
Points: 1,131, Level: 18 Points: 1,131, Level: 18 Points: 1,131, Level: 18
Level Up 31% Completed
Level up: 31% Level up: 31% Level up: 31%
FF Reputation: 2 flingwing1969 Good Standing Member
Based on the description previously posted (I haven't seen it myself), what Ford uses to attach the headliner is a 3-M product called Dual Lock.
It is intended to serve the same purpose as Velcro, but supposedly has 5-times the holding power. It does not use the hook and loop connection that Velcro does, emulating a burr sticking to wool pants, but instead uses little posts on both sides, that fit together neatly. The adhesive on the strips is very strong.
I've used it with great success on other projects, but there is a slight bit of movement between the posts on each piece and I suppose this could result in a slight bit of noise. I personally have no headliner noise anywhere, including around the moon roof.
2012 Focus SEL 303A, moon roof, etc
2012 Yamaha TW200 Dual Sport
1975 Jeep CJ -built
1974 Dodge W300 Power Wagon dump truck
2002 Kubota B-21 tractor-loader-backhoe
flingwing1969 is offline
Old 12-12-2011, 09:31 PM   #69
JesseE1981
Fan#: 88551
That looks exactly like what I see. The problem seems to be that those individual posts are not holding tight . They still hold together, but the not tight enough. So I can push my headliner up, here the sound of them sticking together tighter, but as soon as I let up, I can hear the posts slide back apart. This is something that JUST started less than 2 weeks ago, so I'm not sure what has changed, other than the the temperature outside has gotten a bit colder.
Old 12-12-2011, 09:49 PM   #70
flingwing1969
Fan#: 91700
Might be time for a dealer field trip. I suppose one could cut a strip of foam tubing, called caulking backer rod,that is thicker than the space between the headliner and the roof and put it into the space to keep tension on the 3-M connections. This would prevent any slight rattling. If the connectors are actually parting due to the weight of the headliner, I suppose more connector material would be in order. Here is a photo of the backer rod I'm talking about, it comes in various diameters and is available in big-box home centers.
1975 Jeep CJ -built
