Battery light still on after new battery/alternator? - Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum
Old 06-22-2011, 11:12 PM   #1
BurnsRubber
BurnsRubber's Avatar
Fan#: 57974
What I Drive: '02 Sonic Blue SVTF
Points 1,383, Level 20
Points: 1,383, Level: 20 Points: 1,383, Level: 20 Points: 1,383, Level: 20
Level Up 83% Completed
Level up: 83% Level up: 83% Level up: 83%
FF Reputation: 1 BurnsRubber Good Standing Member
Monday on my way home from work in the 100deg heat (first of the year) and the AC on full blast (obviously) the red battery light on the dash lights up. My first thought was alternator is going bad. I replaced the battery, just to elimunate it, also figuring it would be good PM anyway since it was 6 years old. On way into work the following morning, no light. OK. On my way home (103deg heat) the light comes on.
So today I take a day off work to replace the alternator. The handheld diagnostic at the part store said (low charging voltage). So I buy a new alternator from Napa. Rebuilt units have died on me. Alternator goes in (what a PITA!) I was expecting the light to go away. First drive out, AC full blast, it goes on. What gives?
I've read through many forum post on this. Seems there are a few other things to trouble shoot: cables, connectors, fuseable link (where is that?) I looked at the alternator wiring and connectors while replacing the alternator, no obvious problems. Battery terminals are clean. So what should I look at next? No symptoms with the car other than this idiot light.
2002 Sonic Blue SVTF w/EAP Wheels
Tom's tune
Centric Rotors (120.61071 & 120.61074) & Hawk HPS Pads
CFM STS, disabled clutch pedal sensor, removed shift linkage counter weight
BF Goodrich g-Force Super Sport A/S 225/45
BurnsRubber is offline
Old 06-23-2011, 01:01 AM   #2
viney266
viney266's Avatar
Fan#: 93
What I Drive: focus ztw ,zx3,mustang, motorcycles
Points 238,851, Level 100
Points: 238,851, Level: 100 Points: 238,851, Level: 100 Points: 238,851, Level: 100
Level Up 0% Completed
FF Reputation: 112 viney266 Excellent Standing Member viney266 Excellent Standing Member
Buy-Sell-Trade Rating: (4)
Did you put a new belt on?..I would replace the belt if you haven't
Speed is only a matter of money; how fast do you want to go?
viney266 is offline
Old 06-23-2011, 01:05 AM   #3
jetrinka
jetrinka's Avatar
Fan#: 45622
What I Drive: 88 5-speed XR4TI
FF Reputation: 180 jetrinka Excellent Standing Member jetrinka Excellent Standing Member
Buy-Sell-Trade Rating: (6)
Do you have a way to measure the charging voltage at the battery? If so, measure the voltage at the battery while running and then measure from the positive lead on the alternator to battery ground. These two numbers should be very close to each other.
Most of the time a battery light indicates a problem with the internal regulator on the alternator itself. Check the main charging fuse as well.
jetrinka is offline
Old 06-23-2011, 01:06 AM   #4
Svt5.0
Fan#: 78677
What I Drive: 03 Svt Focus
FF Reputation: 1 Svt5.0 Good Standing Member
whats the voltage output of the new alt you just put in? I have seen many bad units out of the box
Svt5.0 is offline
Old 06-23-2011, 01:20 AM   #5
mikebontoft
Aurelius Pardus
mikebontoft's Avatar
Fan#: 58647
Points 23,707, Level 94
Points: 23,707, Level: 94 Points: 23,707, Level: 94 Points: 23,707, Level: 94
Level Up 36% Completed
Forum Activity 13%
isnt there some common pigtail issue or something? sorry I don't know more about that but I remember something like that.
mikebontoft is online now
Old 06-23-2011, 01:22 AM   #6
jetrinka
jetrinka's Avatar
Fan#: 45622
Supposedly the pigtail right off the alternator lead sometimes fries.
jetrinka is offline
Old 06-23-2011, 01:23 AM   #7
mikebontoft
Aurelius Pardus
Fan#: 58647
Forum Activity 13%
ok yeah that's what I was thinking of
Old 06-23-2011, 02:27 AM   #8
sparky34kv
Fan#: 63383
What I Drive: 2004 Blue ZTW Wagon, 2.3 L Duratec
Points 365, Level 7
Points: 365, Level: 7 Points: 365, Level: 7 Points: 365, Level: 7
Level Up 30% Completed
FF Reputation: 1 sparky34kv Good Standing Member
Had you charged the battery before running the car with the new alternator? If not, you may have had too much load on it with running the engine and charging the battery, which burns out the regulator in the alternator.
sparky34kv is offline
Old 06-23-2011, 07:07 AM   #9
whynotthinkwhynot
Captain TMI
whynotthinkwhynot's Avatar
Fan#: 18416
Points 27,933, Level 98
Level Up 59% Completed
Forum Activity 10%
Use the electronic odometer trick to see if the PCM is picking up voltage. Follow the directions in the How-To archive, and look for the display to read [bat 12.1]. If you see [bat 0] that might explain some things.
Physical inspection of the plug-in connector is the best way though, and most likely where the problem is.
Be eclectic.
You're special aren't you.
whynotthinkwhynot is offline
Old 06-23-2011, 10:19 AM   #10
BurnsRubber
Fan#: 57974
How do I display voltage on the odometer? I found this: http://www.focushacks.com/?modid=37&...gnostic%20Mode
But could not get it to display a voltage.
Belt looked OK. It could be slipping with the AC on? Should have replaced it. Will look at connectors cables. How do I check generator voltage?
Got to drive it to work right now. Hope I don't get stranded...
Tom's tune
