I cant get my analog outs working with the Xcal - Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum
Old 06-20-2011, 06:45 PM   #1
BowerR64
BowerR64's Avatar
Fan#: 78699
What I Drive: 2007 ZX3 SE
Points 12,323, Level 72
Points: 12,323, Level: 72 Points: 12,323, Level: 72 Points: 12,323, Level: 72
Level Up 69% Completed
Forum Activity 5%
FF Reputation: 12 BowerR64 Great Standing Member
I had it working a coupe months ago but i was just reading it from the tailpipe not mounted in the exhaust. I forgot what i did to get it working.
What should i get from the wideband to the SCT? is it 5V?
When i setup the wideband it shows the "LC1" on the monitor but its just stuck at "7" it doesnt seem to move.
The innovate software has a setting you can change the analog outputs i think it changes the voltages also. Should they be on "lamda" or "AF/R"
It's not important to win, it's important to make the other guy lose.
BowerR64 is offline
Old 06-20-2011, 09:01 PM   #2
BowerR64
BowerR64's Avatar
Fan#: 78699
Forum Activity 5%
Got it figured out finally, i guess it was a bad connection. Now i have to let it sit over night and clear out so i can recalibrate the wideband.
BowerR64 is offline
Old 06-23-2011, 10:08 PM   #3
BowerR64
BowerR64's Avatar
Fan#: 78699
Forum Activity 5%
Well i guess it wasnt the connection problem its the livelink or something. I can log threw the SCT using the datalogging section but i cant datalog threw livelink. I cant get the wideband to show up as an item to log in the data logging list. I know its working though because it works finerew the SCT datalogging.
BowerR64 is offline
Old 06-24-2011, 02:30 AM   #4
PSUrivie
PSUrivie's Avatar
Fan#: 67329
What I Drive: Boostin in the Mid-A
Points 7,191, Level 56
Points: 7,191, Level: 56 Points: 7,191, Level: 56 Points: 7,191, Level: 56
Level Up 21% Completed
FF Reputation: 15 PSUrivie Great Standing Member
Buy-Sell-Trade Rating: (10)
you can't data log your a/f through livelink? There is no Analog 1 or 2 in your PID list?
FSWerks stg2 w/ water/meth; Cossie intake.
PSUrivie is offline
Old 06-24-2011, 02:35 AM   #5
BowerR64
BowerR64's Avatar
Fan#: 78699
Forum Activity 5%
There is but it doesnt seem to read right. If i check the box next to the analog 2 the guage needle appears to be moving right but i think the display is set wrong or set to volts?
I think when my incar gauge reads 14.7 the livelink says somthing like 2?
BowerR64 is offline
Old 06-24-2011, 07:40 AM   #6
Blivit
Blivit's Avatar
Fan#: 51292
What I Drive: 2013 ST
Points 2,359, Level 29
Points: 2,359, Level: 29 Points: 2,359, Level: 29 Points: 2,359, Level: 29
Level Up 40% Completed
FF Reputation: 118 Blivit Excellent Standing Member Blivit Excellent Standing Member
Did you apply the correct analog equation to the signal in livelink? If not then all it is displaying is the voltage. Commands->analog equations.
Blivit is offline
Old 06-24-2011, 09:11 AM   #7
1turbofocus
FF Affiliate
1turbofocus's Avatar
Fan#: 1123
Points 52,526, Level 100
Points: 52,526, Level: 100 Points: 52,526, Level: 100 Points: 52,526, Level: 100
Level Up 0% Completed
Forum Activity 63%
Activity: 63% Activity: 63% Activity: 63%
Buy-Sell-Trade Rating: (28)
Bower have you gone in your live link to commands , then on the right in the box chose the wide band you have then apply channels and got something like this "(v*2)+10"
Then make sure your gauge and log air fuel is the same if not you will need to make some adjustements to the equation
Customer Support
AIM: hpdyno
Email: hpdyno@aol.com
Phone: 704-249-3745
Site: focus-power.com
Elder 1turbofocus
1turbofocus is offline
Old 06-24-2011, 12:49 PM   #8
BowerR64
BowerR64's Avatar
Fan#: 78699
Forum Activity 5%
i think i was looking for something else.
When you log using the SCT and then upload it to livelink it adds a new line and says "LC1" i was looking for that for some reason not looking at the "analog 1-4" as being the inputs from the wideband.
I think i figured it out now but i havnt set the correct analog equation.
Can i remove analog 1-3 and 4 and maybe rename the analog 2 to LC1?
BowerR64 is offline
Old 06-24-2011, 02:24 PM   #9
PSUrivie
PSUrivie's Avatar
Fan#: 67329
It depends what channel you hooked your firewire up to. Which channel are you using (1 or 2)???
PSUrivie is offline
Old 06-24-2011, 09:37 PM   #10
BowerR64
BowerR64's Avatar
Fan#: 78699
Forum Activity 5%
I got it finally you guys just have to beat it into my head i guess.
For some reason livelink was locking up and not showing the live data as i was logging with the laptop. You can see the digital gauges and the data lines and stuff, it wasnt showing that. Then when it did work i was thinking "LC-1" would show up at the bottom like it does when you log threw the SCT.
I forgot about the 1-4 analog lines up top.
I didnt know you had to change anything in live link to get it to display properly. I just figured that duratec data log list had all the settings.
It seems to be working correctly now.
Thanks for all the help!
Now to see if Tom can do anything with the datalog
BowerR64 is offline
