Go Back   Focus Fanatics > Ford Focus Tech Discussions > DURATEC Performance (2003-2011)
DURATEC Performance (2003-2011) The place to chat about any Duratec 23, 23E, and 20 engine performance, tuning and exhaust related upgrades.
Old 01-05-2013, 11:48 AM   #71
crice8
crice8's Avatar
Fan#: 84830
What I Drive: 2010 Sterling Gray Focus SE Sedan
FF Reputation: 10 crice8 Great Standing Member
Buy-Sell-Trade Rating: (13)
Wait i think I remember now. Its been almost 2 years so bear with me on this. See the little silver clamp looking thing at the base of the hose there. You will need to take a flat head screwdriver and place it inside that and bend it out some. It is ok to bend it. You will not break it. Then this will release that hose.
Current Performance Mods: FSWerks CAI, Custom 2.5 inch Exhaust, SCT xcal 3 with Custom 93octane Tune, Rota SlipStream 13lb wheels, FSWerks 4-1 Race Header,High-Performance Tires,FSwerks Stress Bars, FRPP Suspension
crice8 is offline
Old 01-06-2013, 11:01 AM   #72
TMDJ5
Fan#: 107386
What I Drive: 2011 Black Ford Focus SE 2.0
FF Reputation: 1 TMDJ5 Good Standing Member
Does that hose have a purpose on this install? Like, will it eventually connect somewhere again?
Stupid question I know but I'm just trying to get some things cleared up before I get to deep into the install and have to turn back. Thank you though, seriously. Big help.
Oh and one more question? Do you remember how you got the 4 bottom bolts out of the underside of the air box? Directions say get under the car but I read somewhere that it'd be easier to just take of the drivers side wheel and go in through the wheel well.
TMDJ5 is offline
Old 01-06-2013, 01:16 PM   #73
TMDJ5
Fan#: 107386
And yes, it is the Pzev.
TMDJ5 is offline
Old 01-07-2013, 05:18 AM   #74
06_infrared_zx4
Teddy_Ruxbin
06_infrared_zx4's Avatar
Fan#: 91369
What I Drive: 2006 Infra-Red ZX4 SES
FF Reputation: 4 06_infrared_zx4 Good Standing Member
My car was also pzev. To remove the lower air box I jacked up the car, took off the left front wheel, removed the fender liner and lower splash shield. Was still a bitch to get it out, I really don't think there is another way to do it without getting under the car.
Ted
I lessthanthree you bastards
06_infrared_zx4 is online now
Old 01-07-2013, 10:33 AM   #75
crice8
crice8's Avatar
Fan#: 84830
When I removed mine I never jacked the car up nor did I remove the wheel....
crice8 is offline
Old 01-07-2013, 11:23 AM   #76
dooor
Fan#: 51395
What I Drive: 2007 se stick
FF Reputation: 1 dooor Good Standing Member
The 2007 I drive is a PZEV. It has both a tube from the valve cover, crankcase ventilation, and a tube that is an EGR supply, exhaust gas recirculation. Both tubes connect to the rubber connector that is upstream
from the throttle blade. That is one of the pieces that the CAI replaces. Just phoned FSWERKS. They said that both tubes connect to the new CAI tube. I want to do this mod and am trying to learn to avoid problems. When I raced dirt tracks we used the outerware filter cover. They help keep the filter dry from occasional splashes, but the big thing is protection from flying debris. NO, I don't sell any of this stuff.
dooor is offline
Old 01-08-2013, 06:40 PM   #77
TMDJ5
Fan#: 107386
Do you remember how you got the bottom bolts out? Did you just wedge yourself under the car?
That's what I do when I'm changing the oil. It's super tight but I can fit. I know that I'm not gonna have to go back under there once the stock one is out. So if I can just muscle myself under there real quick without having to take the wheel and fender cover off it'd save a lot of hassle and time.
TMDJ5 is offline
Old 01-08-2013, 06:52 PM   #78
crice8
crice8's Avatar
Fan#: 84830
I think I just felt up under it for the bolts and did it by touch
crice8 is offline
Old 01-09-2013, 04:48 PM   #79
TMDJ5
Fan#: 107386
Alright... It's installed. Ran into a few snags but eventually worked out.
My only concerns is that the intake doesn't hang completely vertical. The filter isn't perfectly aligned with the t/b, it's kind of closer to the front of the car. It's just look like its asking for trouble, also the hoses feel really tight.
Also, there's a weird hissing noise when I hit the gas. Sounds almost like a NOS injection. Does that mean a leak somewhere or has anybody had that kind of experience?
TMDJ5 is offline
Old 01-09-2013, 04:58 PM   #80
crice8
crice8's Avatar
Fan#: 84830
Yes that means there is a leak there more than likely. You need to find it so your cars MAF reads right and runs properly. Can you post a pic of the way its positioned? it should look like this>
crice8 is offline
