"How To" - VF Engineering Rear Mount-Install Pics - Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum
Old 09-27-2004, 03:17 PM   #1
WD40
The Librarian
WD40's Avatar
Fan#: 5157
VF Engineering Rear Mount-Install Pics-SVTF
Thanks to our recent Mt Rushmore G2G (midwest forums),
and our "longest distance travelled" $25 gift certificate from FocusSport,
I've now got WAY better shifting.
The entire install took me all of 30 minutes.
Including the time to jack up the car, take pictures, and put it back down on the ground.
Without further ado, here come the pics with instructions and notes.
EDIT:
If you're doing this to a "standard" fOCUS with the MTX-75,
please refer to Frogman283's revised instructions for the bolts and plate noted in step (3).
Click Here for the MTX-75 procedure, found near the end of this write-up.
WD40 is offline
Old 09-27-2004, 03:17 PM   #2
WD40
The Librarian
WD40's Avatar
Fan#: 5157
1) Jack up the front end of the car, and support on stands.
2) Place floor jack underneath the transmission.
As seen in the picture, I used a piece of 2X4 to distribute the load more evenly.
Just take the pressure off the mount. No need to raise the transmission.
3) Remove the 3 bolts noted by the red arrows.
4) Loosen the bolt denoted by the yellow arrow, but do not remove.
WD40 is offline
Old 09-27-2004, 03:18 PM   #3
WD40
The Librarian
WD40's Avatar
Fan#: 5157
5) Pivot the gold colored plate as shown.
6) Rotate the front of the mount towards the passenger side, pull forward, and remove.
WD40 is offline
Old 09-27-2004, 03:20 PM   #4
WD40
The Librarian
WD40's Avatar
Fan#: 5157
Here’s the comparison of the stock and VF Engineering mount.
WD40 is offline
Old 09-27-2004, 03:21 PM   #5
WD40
The Librarian
WD40's Avatar
Fan#: 5157
7) Install the new motor mount just as you took the old one out by rotating it into position.
8) Install the forward most bolt into the gold plate. (Hand tighten only at this point)
9) Install the forward most motor mount bolt. (Hand tighten only at this point)
10) Using a 2X2 as shown (or equivalent),
gently pry the engine/transmission assembly forward to line up the rear motor mount bolt hole.
11) Install the rear motor bolt. (Hand tighten only)
Definition of “Hand tighten only”:
Using a ratchet and socket, snug up the bolt, but don’t torque all the way tight.
WD40 is offline
Old 09-27-2004, 03:21 PM   #6
WD40
The Librarian
WD40's Avatar
Fan#: 5157
12) Torque the 2 motor mount bolts and 2 plate bolts to 35 lbs-ft.
13) Lower the jack from underneath the transmission, and then lower the car to the ground.
14) Start car.
15) Drive car.
16) Shift from 1st to 2nd gear, and note how much better it hooks up!
WD40 is offline
Old 09-27-2004, 03:49 PM   #7
WD40
The Librarian
WD40's Avatar
Fan#: 5157
Thanks man!
Now for the "epilogue".
I am extremely pleased with this modification.
You will not believe how much tighter the shifting is.
1st to 2nd upshift is virtually seemless now. No more…..BANG.
A pleasant side effect is that downshifting is also notably tighter.
It sure showed up this weekend on the AutoCross course.
As far as NVH, what I do notice is slightly more vibration just after the engine kicks over upon startup.
More importantly, is I don't notice any increased vibrations at idle, I.E. sitting at stoplights.
Now, to go get myself the Steeda short shifter, and have the best of both worlds.
IMHO, I would not install the shifter without first doing the rear motor mount.
No matter how much you improve the shifter, the engine is still going to be moving too much.
WD40 is offline
Old 09-27-2004, 04:01 PM   #8
microtonal
FF #1 Most Wanted
microtonal's Avatar
Fan#: 470
What I Drive: 2012 GTI, 2014 Forester XT
FF Reputation: 12 microtonal Great Standing Member
Buy-Sell-Trade Rating: (7)
Nice write up and detailed pics.
So, this would also fit on a standard Zetec/Non-SVTF right?
Just reading.....
microtonal is offline
Old 09-27-2004, 04:13 PM   #9
WD40
The Librarian
WD40's Avatar
Fan#: 5157
Yep.
Same part number for all models.
http://www.focussport.com/mounts.htm
WD40 is offline
Old 09-27-2004, 11:35 PM   #10
Vassili95
Fan#: 371
FF Reputation: 1 Vassili95 Good Standing Member
I demand a sticky to ease the bookmarks..:)
Paix...
Vassili95 is offline
Similar Threads
"How To" SVTF Short Shifter Install WD40 SVT Performance (2002-2004) 209 07-07-2012 12:25 PM
Timing Belt Info Spanky6935 General Technical Chat 13 09-30-2011 11:54 PM
CFM trans mount vs. VF engineering with pics macdiesel General Technical Chat 9 07-02-2010 08:44 AM
**Vote for Focusfanatics.com Ride of the Year 2009** (PHASE 1) Chick Ford Focus - Ride of the Month 30 08-01-2009 08:46 PM
Rear Camber Bolt Install eurotrashvrt Brakes, Suspension & Body Chassis 5 06-11-2007 04:00 PM
