Adding backup camera - Page 16 - Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum
Old 05-17-2013, 11:38 PM   #151
babaei
Fan#: 113602
What I Drive: 2013 Tuxedo Black Focus SE Sedan
Points 235, Level 4
Points: 235, Level: 4 Points: 235, Level: 4 Points: 235, Level: 4
Level Up 70% Completed
FF Reputation: 1 babaei Good Standing Member
For those interested, this is what the wiring for my (sedan) camera looks like under the trunk lid:
babaei is offline
Old 05-18-2013, 08:05 PM   #152
Mrlandy
Fan#: 99623
What I Drive: 2012 focus titanium hatch
Points 28, Level 1
Points: 28, Level: 1 Points: 28, Level: 1 Points: 28, Level: 1
Level Up 56% Completed
FF Reputation: 3 Mrlandy Good Standing Member
I thought about the OEM emblem camera: http://www.rydeenmobile.com/press/SimpleCameraKits.html The emblem camera would probably work well on the sedan.
Mrlandy is offline
Old 05-20-2013, 05:21 PM   #153
aperson9923
aperson9923's Avatar
Fan#: 90061
What I Drive: 2012 SGM Ti Hatch
Points 1,812, Level 25
Points: 1,812, Level: 25 Points: 1,812, Level: 25 Points: 1,812, Level: 25
Level Up 12% Completed
FF Reputation: 1 aperson9923 Good Standing Member
Can anyone explain to me how you would wire the camera into the rear brake light?
2012 Sterling Grey Metallic Ford Focus Titanium Hatch
401A, Navi, MFT, Rain Sensing Wipers
Built: 11/28/11 Arrived: 12/16/11 (4 Miles)
Mods: Tint 20/5, LockPick & Backup Camera, K&N Drop In
aperson9923 is offline
Old 05-20-2013, 06:25 PM   #154
I Bleed Ford Blue
I Bleed Ford Blue's Avatar
Fan#: 94113
What I Drive: 2013 F150 FX4
FF Reputation: 8 I Bleed Ford Blue Good Standing Member
To get power for the camera, but it unnecessary on our MK3 focii. There is a fuse panel in the hatch area/trunk, just pop in an add a circuit fuse tap to a switched power circuit and your golden.
13 Blue Flame F150 FX4 402A on 20's loaded
13 Frosted Glass Escape Ti 401A loaded
13 Performance Blue SE 201A
14 Dark Side Fusion SE 200A
L-CCC #18/HOIA #37
I Bleed Ford Blue is offline
Old 05-20-2013, 06:38 PM   #155
aperson9923
Fan#: 90061
Do you have any fuses to suggest? :)
Old 05-20-2013, 07:00 PM   #156
Mrlandy
Fan#: 99623
Points 28, Level 1
rear backup light
I tapped into the backup light. 2 thumb screws and the taillights pop right out. Camera only comes onin reverse. The reverse lights have plenty of juice to power the camera ibought. Attach 2 wires, power and ground. Solder connections and coat connections with silicone since there is a large void behind the taillights the connections will be exposed to weather.
Mrlandy is offline
Old 05-20-2013, 07:09 PM   #157
aperson9923
Fan#: 90061
Originally Posted by Mrlandy View Post
I tapped into the backup light. 2 thumb screws and the taillights pop right out. Camera only comes onin reverse. The reverse lights have plenty of juice to power the camera ibought. Attach 2 wires, power and ground. Solder connections and coat connections with silicone since there is a large void behind the taillights since the connections will be exposed to weather.
My question to you is if you are using the Lockpick and you want to view the camera while driving, will comnecting it to thw brake light allow you to do that?
Old 05-20-2013, 09:03 PM   #158
I Bleed Ford Blue
Fan#: 94113
My question to you is if you are using the Lockpick and you want to view the camera while driving, will connecting it to the reverse light allow you to do that?
No, you need power that is on whenever the key is on to do that.
L-CCC #18/HOIA #37
Old 05-20-2013, 11:18 PM   #159
aperson9923
Fan#: 90061
So i should add a circuit to the fuse box in the trunk for a "key on/off" fuse. Ill let you all know what fuse i decide to use!
Old 05-21-2013, 12:13 AM   #160
I Bleed Ford Blue
Fan#: 94113
Yep, that's what I would do.
L-CCC #18/HOIA #37
