PWSC with a P0133 HELP !! - Page 2 - Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum
Old 06-15-2011, 09:50 AM   #11
1turbofocus
FF Affiliate
1turbofocus's Avatar
Fan#: 1123
Points 51,797, Level 100
Points: 51,797, Level: 100 Points: 51,797, Level: 100 Points: 51,797, Level: 100
Level Up 0% Completed
Forum Activity 32%
Activity: 32% Activity: 32% Activity: 32%
Buy-Sell-Trade Rating: (28)
P1132 is slow responding o2 like we saw with the scan tool , what does the o2 log look like now
Customer Support
AIM: hpdyno
Email: hpdyno@aol.com
Phone: 704-249-3745
Site: focus-power.com
Elder 1turbofocus
1turbofocus is offline
Old 06-15-2011, 07:01 PM   #12
volcomstone1966
RIP 02 SVT 0209
volcomstone1966's Avatar
Fan#: 35104
What I Drive: 04 PWSC EAP SVT - 04 Kawasaki ZX6R
Points 16,597, Level 82
Points: 16,597, Level: 82 Points: 16,597, Level: 82 Points: 16,597, Level: 82
Level Up 50% Completed
Forum Activity 3%
FF Reputation: 15 volcomstone1966 Great Standing Member
Buy-Sell-Trade Rating: (45)
I did not data log it with the new 02 yet
04 SVT EAP #1131 -POWERWORKS-Torsen-Clutch Masters-Top Speed-Massive-Brembo-Fifteen52-Steeda-UNDER CONSTRUCTION
2K14 Turbo Veloster
04 Kawasaki ZX6R
volcomstone1966 is offline
Old 07-15-2011, 04:03 AM   #13
volcomstone1966
RIP 02 SVT 0209
Fan#: 35104
Forum Activity 3%
the new O2 has been in and data loged as workin fine
well the car is still not up and runnin right , i been busy with my other 2 SVTs
but ..
tha car now has a P0300 that is a random misfire -
P0300 - Random Misfire The random misfire DTC indicates multiple cylinders are misfiring or the PCM cannot identify which cylinder is misfiring.
Camshaft position sensor (CMP)
Low fuel: less than 1/8 tank
soo...should i replace the CMP cuz i know its not the gas
and a few other things that can make the code are EGR
stuff but i have an SVT so none of that
i stated to take some stuff apart to check wires and stuff
and on the plug that goes to the coil i found this:
now i know it needs to be fixed but is just a little wire showing
something that would make the car run the way it has been?
thanks
2K14 Turbo Veloster
04 Kawasaki ZX6R
Old 07-15-2011, 06:55 PM   #14
DareDevil03
Across the Pond
DareDevil03's Avatar
Fan#: 13938
What I Drive: 2001 Nissan Primera (UK Spec)
Points 5,115, Level 45
Points: 5,115, Level: 45 Points: 5,115, Level: 45 Points: 5,115, Level: 45
Level Up 83% Completed
Level up: 83% Level up: 83% Level up: 83%
FF Reputation: 1 DareDevil03 Good Standing Member
Buy-Sell-Trade Rating: (18)
Check the fuses. I had an O2 code for years and looked at that finally and the fuse was blown.
*EDIT* Just saw the last post. Good luck.
Proudly Serving
Ask me about UK parts.
DareDevil03 is offline
Old 07-16-2011, 01:14 AM   #15
norcalfocus01
Fan#: 55603
Buy-Sell-Trade Rating: (12)
You know my thoughts. It is enough to cause it.
norcalfocus01 is offline
Old 07-16-2011, 11:55 PM   #16
volcomstone1966
RIP 02 SVT 0209
Fan#: 35104
Forum Activity 3%
^^ok
well the ford pigtail fix is like $30
i will see if i have one on my blue cars cut up wire harness
2K14 Turbo Veloster
04 Kawasaki ZX6R
Old 07-17-2011, 10:21 PM   #17
volcomstone1966
RIP 02 SVT 0209
Fan#: 35104
Forum Activity 3%
ok well F #ck i fixed the coil wire pig tail
and replaced the cam CMP
and the car still runs like it did ...
so i got no clue what the hell is going on
2K14 Turbo Veloster
04 Kawasaki ZX6R
Old 07-18-2011, 01:15 AM   #18
DareDevil03
Across the Pond
Fan#: 13938
back to my original idea
Look at the fuses maybe?
Proudly Serving
Old 07-18-2011, 01:25 AM   #19
norcalfocus01
Fan#: 55603
How far did you chase the wires down to see if more was exposed?
Old 08-08-2011, 12:26 PM   #20
psycho401
Fan#: 50735
What I Drive: 2004, Red, Focus SVT
FF Reputation: 1 psycho401 Good Standing Member
P0133
I had the same issue with my powerworks. I bet you 10 bucks you throw in a oil catch can on you pcv you stop sucking oil through causing you O2 sensor to act up. Also a quick check pull you PCV line and I bet there is oil in there. If you dont wanna pay 70 bucks go to homedept and pick up an inline filter for 12 bucks in the air compressor section and go to auto zone and pick you up some 1/4 inch hose and connectors and cut you PCV line and install that inbetween.
http://focus.c-f-m.com/cfmoilseparat...svtengine.aspx
FYI dont listen to people that say as soon as a O2 sensor code is up buy a new sensor. There full of shit. 9 times out of 10 it isnt the sensor. You can replace the sensor a dozen times, turns the light out for a while but Like Tom said its a vac leak or somethink upstream causeing you sensor to trip out and the light will continue to come back if you dont fix the root problem. Thats why the sensor is there. But in your cause I bet its the need for the catch can. It solved my issues no p0133 and a happy filling catch can which i have to dump about every other fill up on gas. :) Enjoy the supercharger man
psycho401 is offline
