2003 focus crank/ no start - Ford Focus Forum, Ford Focus ST Forum
Go Back   Ford Focus Forum, Ford Focus ST Forum > Ford Focus Tech Discussions > General Technical Chat
Old 06-10-2011, 09:52 AM   #1
jnaut
jnaut's Avatar
Fan#: 86651
What I Drive: 2009 370z
FF Reputation: 1 jnaut Good Standing Member
Exclamation 2003 focus crank/ no start
Hello everybody, i can on here as i am trying to fix my friends car. He has an 03' focus 2.0 auto. Ill give u the run down, it cranks fine, fuel pump is working, it has spark also it has injector plus but here it where it gets odd as the injector pluse is strong for the first couple revolutions then it fades to dim but never stops. t-belt isn't broken also pulged in the scanned check to see if i am losing crank rpms but nope its around 230 cranking rpm.
thanks again all for your help , jason.
jnaut is offline
Old 06-10-2011, 10:35 AM   #2
afgray327
Fan#: 85184
What I Drive: 2004 Black focus ZX5 SVT
FF Reputation: 2 afgray327 Good Standing Member
pressure regulator, fuel filter maybe?
afgray327 is offline
Old 06-10-2011, 11:18 AM   #3
Serenity181
Serenity181's Avatar
Fan#: 85053
What I Drive: 2003, Silver ZX3
FF Reputation: 3 Serenity181 Good Standing Member
put throttle about 2/3 ways in crank and crank and crank and crank
make sure its not flooded out, also pull a couple plugs and see if there are fuel on the end. Sounds like a flooded motor to me. (I just went through this on mine) What kind of plugs is he running?
Serenity181 is offline
Old 06-10-2011, 12:43 PM   #4
Vexorg
Vexorg's Avatar
Fan#: 85499
What I Drive: 2001 Zx3 ChromeGold
FF Reputation: 3 Vexorg Good Standing Member
Flooded perhaps. Try the starting fluid trick.. that'll tell you if it's getting fuel or not... Spray the Starting fluid in the air intake while cranking the car.. does it try? If it runs on starting fluid for a few seconds, then pukes out, it's an easy one.. No fuel.
Vexorg is offline
Old 06-10-2011, 12:43 PM   #5
jnaut
jnaut's Avatar
Fan#: 86651
plugs are new (ap 5144), very little fuel on them. the only issue i come with the injector pulse is strong at first then gets weaker as u continue to crank. crank trigger must be working as i am reading rpm signal with scanner.
jnaut is offline
Old 06-10-2011, 02:05 PM   #6
Serenity181
Fan#: 85053
2/3 throttle crank and crank, still thinking its flooded. id crank for a bit and try dry plugs if you have them. Nothing indicates it being delivery espically if there is a small amount of fuel on the plug. Also check wires and distributorship. But sound likes flooding to me.. and the more you crank weaker it will get, your draining the battery :)
Old 06-10-2011, 02:36 PM   #7
Vexorg
Vexorg's Avatar
Fan#: 85499
I'd love to tell you what we used to do to lawnmowers when they'd flood, but some genius would try it... and burn they eyebrows off.
oh what the hell. I suggest this only for a flooded 1 cyl lawnmower motor...
Get a blow torch.. take out the plug out.. put the flame by the hole.. turn over motor at a moderate speed and watch it shoot flames... put in spark plug, don't choke.. just start it... Runs now. Don't do this to your car...
Vexorg is offline
Old 06-10-2011, 03:00 PM   #8
jnaut
jnaut's Avatar
Fan#: 86651
Its not flooded forsure as very little fuel is on the plugs, plus i did pull them all and cleaned 'em off.
is there an easy way to check fuel pressure and what psi should it be at?
thanks again for your help.
jnaut is offline
Focus Fanatics Ford Focus Forum offers many fun ways for you to engage with other Ford Focus Owners from across the world. Whether it be about the aftermarket performance modifications, technical how-to's, European tuned suspension or awesome fuel economy similar to the Cadillac ATS-V, Ford Fusion and Acura TLX. You can find all Ford Focus and Focus ST related information here. Join our Ford Focus discussion forums and chat with local Focus enthusiasts in your area.
