Issues with new 2012 Ford Focus - Page 79 - Focus Fanatics
Go Back   Focus Fanatics > Ford Focus Third Generation > MK3 TSB, Recall & Problems Archive
Old 02-28-2012, 07:35 PM   #781
Reedleo
Fan#: 92260
What I Drive: 2012 Candy Apple Red SEL
FF Reputation: 1 Reedleo Good Standing Member
Now well over 12K miles and the transmission still clatters at the up-shifts into 2nd and 4th, and just had the "revs but no power" issue again, all after having the transmission re-programmed. I'm convinced the "revs but nor power" issue is happening when the tranny wants to downshift from 3rd to 2nd, but fails to engage. Must be a hardware problem with that clutch or associated actuators.
Reedleo is offline
Old 02-28-2012, 07:45 PM   #782
Reedleo
Fan#: 92260
r1derbike: Sounds like we have the same problem here with 2nd and 4th. The worst for mine is if I'm in 4th and approach an uphill at lower rpm, it shudders as the hill increases. If it were a manual, I'd just assume I needed to downshift before getting to that point, but the auto doesn't handle it well. Since the S/W update didn't fix it, I'm convinced there is a H/W issue on that side.
Reedleo is offline
Old 02-28-2012, 07:53 PM   #783
r1derbike
r1derbike's Avatar
Fan#: 62667
What I Drive: '12 SE Sport Hatch - Sterling Grey
FF Reputation: 4 r1derbike Good Standing Member
I'm waiting on some clutch parts for my 2nd, 4th, and 6th gear side. Shudder is getting worse upshifting into those gears. Really bad. 6th gear shudders so bad at interstate speeds with a headwind, I have to slow down.
I hope it stays together long enough to last the 10 days it's going to take to get the "emergency backordered" parts.
What a nightmare...
On the way over my small hill tonight, on my street at about 10 mph and coasting, the engine rpm soared to 4K for a bit, as if in neutral, and shuddered so violently, when it caught, it shook the whole car.
I'm wondering how long the clutch will last for the 1st, 3rd and 5th gearset, after the other side is replaced?
"We have a problem, Houston"...
You have the same issue I have, Reedleo.
2012 Focus; Maybe 3rd Time's the Charm?
r1derbike is offline
Old 02-28-2012, 07:58 PM   #784
Reedleo
Fan#: 92260
r1derbike: Can you hold it in 5th in the S mode on the highway instead of 6th? Hurts the gas mileage some, but maybe less risk of complete breakdown.
Reedleo is offline
Old 02-28-2012, 08:18 PM   #785
r1derbike
r1derbike's Avatar
Fan#: 62667
Yes I can...I already drive around the issue in 2nd and 4th by using select shift, and manually shifting around it. Not a thing I like to do, in a brand new car. Sometimes I forget, and plop it in D, and very quickly realize the consequences...
I hope they've redesigned the replacement clutch parts, or this cycle is going to repeat itself, very quickly.
Old 02-28-2012, 08:28 PM   #786
Reedleo
Fan#: 92260
No kidding; for all the effort I put into nursing this car in motion, it should have >100K miles. Hope the repair fixes it for you. If it does, let me know what they did so I can get it done too!
Reedleo is offline
Old 02-28-2012, 08:29 PM   #787
r1derbike
r1derbike's Avatar
Fan#: 62667
Originally Posted by gtncpa View Post
it is not just a river in egypt ....
lmao!
Old 02-28-2012, 08:31 PM   #788
r1derbike
r1derbike's Avatar
Fan#: 62667
I'll post!
Old 02-28-2012, 08:36 PM   #789
r1derbike
r1derbike's Avatar
Fan#: 62667
BTW! Does your car now idle roughly when on the brake at a stop? Mine is getting pretty bad, and the idle rpm hasn't changed a bit since new.
Old 02-29-2012, 12:40 PM   #790
Reedleo
Fan#: 92260
Once in a while it will idle rough. A quick shift in/out of Neutral makes it go away. Not frequent enough to make it an issue worth the time to fix for me yet.
Reedleo is offline
