Issues with new 2012 Ford Focus - Page 101 - Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum
Old 06-10-2012, 12:37 AM   #1001
CoasterDan
Fan#: 86083
What I Drive: 2012 Focus SE Hatch Tuxedo Black
FF Reputation: 1 CoasterDan Good Standing Member
Addendum
I wanted to add that North County Ford in Vista, CA has been great. They're friendly, helpful and professional. In addition to doing the recall for the trans., wiper and ABS, they were able to fix a rattle in the overhead console that the other dealer I went to could not fix after two visits. The first dealer tried a band-aid approach while North County ordered and installed a new console. Problem solved.
CoasterDan is offline
Old 06-10-2012, 02:51 AM   #1002
ruby.b
Fan#: 95025
What I Drive: 2012ford focus titantuim white
FF Reputation: 1 ruby.b Good Standing Member
has anyone have a problem with the new upgrade for my sync ??I'm finding it more confusing with nav.
ruby.b is offline
Old 06-10-2012, 11:20 AM   #1003
Lscman
Fan#: 95211
What I Drive: 2007 ZX3
Points 1,224, Level 19
Points: 1,224, Level: 19 Points: 1,224, Level: 19 Points: 1,224, Level: 19
Level Up 24% Completed
FF Reputation: 9 Lscman Good Standing Member
Originally Posted by dvandy4898 View Post
..........yesterday while driving, my shoe lace got caught on brake peddle. Has anyone else ever gotten stuck on the brake peddle? Just curious. It freaked me out.
Hopefully Ford will cut their losses, buy back this car from you and send you on your way before you run over somebody and blame them. I'm sure your pants cuff will somehow engulf the throttle pedal next time or maybe your legs will become knotted trying to operate two floor pedals. That can be really complicated, especially with shoe laces the size of a cowboy's lasso.
Lscman is offline
Old 06-10-2012, 02:52 PM   #1004
ElGatto
ElGatto's Avatar
Fan#: 99202
What I Drive: 2012 Silver Focus SE, HB, sport pkg
FF Reputation: 1 ElGatto Good Standing Member
Originally Posted by whynotthinkwhynot View Post
OK, I didn't know that. You know what to do now if the owner's manual doesn't tell you how to reset it.
While you monitor the MPG press and hold the OK button on the left side of your steering wheel
ElGatto is offline
Old 06-10-2012, 05:53 PM   #1005
a_2000_se
a_2000_se's Avatar
Fan#: 62964
What I Drive: 2000 SE SOHC SPI, Compression @ 164
Points 4,699, Level 43
Points: 4,699, Level: 43 Points: 4,699, Level: 43 Points: 4,699, Level: 43
Level Up 75% Completed
Forum Activity 5%
FF Reputation: 15 a_2000_se Great Standing Member
Anyone with some time to kill and some money to throw around - or just have a car out of warranty?
Will the steering column, rack, hub, ect... from earlier models fit the 2012 with little mechanical mods (delete the CELs)?
http://www.focusfanatics.com/forum/s...teering+column
Member of the Dropped Valve Seat Club.
Replaced #4 Piston, Rings, Rod+Bearings, AERA Re-Manufactured Cylinder Head and a light Hone. Then CLEANED the hell out of everything.
60k+ miles.
a_2000_se is offline
Old 06-10-2012, 06:37 PM   #1006
whynotthinkwhynot
Captain TMI
whynotthinkwhynot's Avatar
Fan#: 18416
Points 27,933, Level 98
Level Up 59% Completed
Forum Activity 10%
The steering column wouldn't be the problem. The problem would be finding somewhere to mount a pump, tubing, and fitting the hydraulic steering gear in the car to go with a steering column. That's a lot of work. When the bugs are worked out of the electric assist, it should be fine. Everyone uses electric assist now, and everyone has problems too. Even worse for some luxury sport vehicles that have multiple assist settings. One problem I see with Ford's programming is that it seems that the electric assist is always assisting instead of cutting off once moving or sensing steering movement before assisting. At least that's what I'm reading into the way it acted on the highway- it might be designed to cut off or sense assist need, but something is screwing up keeping the assist on in problem vehicles.
Be eclectic.
You're special aren't you.
whynotthinkwhynot is online now
Old 06-10-2012, 07:40 PM   #1007
Mister F
Fan#: 98468
What I Drive: 2012 blue Focus SE hatch manual
FF Reputation: 1 Mister F Good Standing Member
Has anybody else had problems with body noise on the interior? On my SE I'm starting to notice a slight rattling from the passenger door area and the rear hatch area - kind of like some of the pieces aren't quite fitting together tightly enough causing them to vibrate against each other. It only happens when I'm going 90 km/h or faster and it's worse on rough roads. No other complaints and it's a fantastic car, but part of what impressed me about it was how solid it feels. I don't want to have it rattling and creaking already. I have about 2500 km on the car. I haven't seen anyone else mention a problem like this here but I'm wondering how a dealer would handle this complaint.
Mister F is offline
Old 06-10-2012, 08:28 PM   #1008
minitaz1
Fan#: 98652
What I Drive: 2012 Silver Ford Focus SE
FF Reputation: 1 minitaz1 Good Standing Member
Transmission Shudder
We had the same problem with the hesitation/shudder when we first took delivery of our 2012 focus, approx. 1 month after getting the car we took it into the dealership for this issue. They stated that they all did it and the had come up with a reprogram of the PCM powertrain control module. We had the PCM reprogram done at 1746 miles and it has been over 1000 miles since that repair. The problem is still there and now there is a chattering when the vehicle shifts from 1st to 2nd and 2nd to 3rd under light acceleration. Ford needs to resolve this issue now.
minitaz1 is offline
Old 06-11-2012, 06:07 PM   #1009
ElGatto
ElGatto's Avatar
Fan#: 99202
I had the rattle on the passenger side. It turned out to be the seat belt latch. A slight adjustment eliminated the problem.
ElGatto is offline
Old 06-11-2012, 11:04 PM   #1010
Mister F
Fan#: 98468
I'll keep that in mind - hopefully it's that simple. No rattling today so maybe it's fixed itself.
Mister F is offline
