just baught some super bright leds - Page 2 - Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum
Old 03-13-2012, 10:13 PM   #11
Webstizze
Webstizze's Avatar
Fan#: 95941
What I Drive: 2010 black focus S
FF Reputation: 1 Webstizze Good Standing Member
I like how those lights look! Was it pretty much just switch the old bulb with the led and thats it? Or was it hard to hook up.
Webstizze is offline
Old 03-13-2012, 10:33 PM   #12
DarderSauce
DarderSauce's Avatar
Fan#: 95564
What I Drive: '08 Vermillion Red 5 speed SEdan
FF Reputation: 5 DarderSauce Good Standing Member
Lightbulb
Good Gawd that looks nice, I am going to get some of those for sure! Any idea if these would fit in an 08?
Also, what other LED/light upgrades do you guys have?
Thanks I appreciate it!
If you can't wear it out, burn it off
DarderSauce is offline
Old 03-13-2012, 10:44 PM   #13
2011 SE
2011 SE's Avatar
Fan#: 80951
What I Drive: 2011 SE
FF Reputation: 8 2011 SE Good Standing Member
It's a direct replacement of the old bulbs. No wiring, no external resistors. Just plug and play!
Originally Posted by DarderSauce View Post
Good Gawd that looks nice, I am going to get some of those for sure! That website you gave goes straight to the bulbs that will fit right? Only reason I ask is because it doesn't say LED T10 Wedge Base Bulb on the website. Any idea if these would fit in an 08?
Yes, the link I put is directly to the ones I used. The map light size is the same for all 08-11 second gens, so they will fit just fine for you. Just as a confirmation, however, the bulb size you're looking for is:
WLED-xHP9-T
If those are too big, you can also get the WLED-xHP5. When I say the HP9 barely fit in the map lights, I mean I had to permanently remove the metallic reflector in order for them to fit. If you feel like cutting out a portion of the reflector, I'm sure it can still fit in there. But because I was impatient, I just took it out. As you can see, they're bright enough that you don't really need the reflector after you install them.
I previously had the HP5 bulbs in there, and those you could fit in with the reflector still in place.
2011 SE Manual - black exterior/interior
Eagle Eyes halo projectors using 55w 5000K DDMtuning HIDs
LED Conversion (license plate, map/dome lights), and LED Taillights
Autobots decal over Ford emblems
Flat black TFB Designs hood stripes
2011 SE is offline
Old 03-13-2012, 10:50 PM   #14
DarderSauce
Fan#: 95564
You do need 2 right?
And you need the WLED-xHP5: LED T10 Wedge Base Bulb and not the twist and lock socket right?
Old 03-13-2012, 10:54 PM   #15
2011 SE
2011 SE's Avatar
Fan#: 80951
Yes, you need two. One for each of the map lights. If you have a dome light in the back seat and you want to replace that bulb as well, then you would need three.
To remove all doubt, this is a picture of the 9 LED bulb you would be buying (mini wedge base, NOT twist and lock socket):
2011 SE is offline
Old 03-13-2012, 10:57 PM   #16
2011 SE
2011 SE's Avatar
Fan#: 80951
These are the HP5 bulbs:
2011 SE is offline
Old 03-13-2012, 11:01 PM   #17
2011 SE
2011 SE's Avatar
Fan#: 80951
Oh, and in case you were interested, the trunk bulb (there's only one in there) is the exact same size as well. I used to have the HP5 in white, but I moved that one to the trunk when I installed the blue LEDs. Now the trunk is very well lit. Crice installed an LED panel which plugs into the same socket size, if I recall correctly. You can buy them on ebay. Perhaps he or someone else will share a link.
Final note: make sure you test that the bulbs are installed in the correct direction (positive/negative) before you put everything back together. If you switch the light on and the LED produces no light, pull the bulb out, rotate it clockwise 180 degrees, then plug it back in. That should fix the polarity issue.
2011 SE is offline
Old 03-13-2012, 11:37 PM   #18
crice8
crice8's Avatar
Fan#: 84830
What I Drive: 2010 Sterling Gray Focus SE Sedan
Points 8,390, Level 61
Points: 8,390, Level: 61 Points: 8,390, Level: 61 Points: 8,390, Level: 61
Level Up 80% Completed
FF Reputation: 9 crice8 Good Standing Member
Buy-Sell-Trade Rating: (13)
Yes i have the panel lights in my trunk and it works very well as you can see below(=
as for the map lights and dome lights i have the high intensity blue ones but any 194 wedge style bulb will work.
Galatians 6:14
crice8 is offline
Old 03-14-2012, 09:52 AM   #19
DarderSauce
Fan#: 95564
[SPLOOSH] Gotta say I am really digging the lights fellas, Crice8 do you have a link for the panel lights that you have in your trunk?
Edit: sorry for being an un-original bastard and taking all your ideas but they're just so damn good!
Old 03-14-2012, 11:46 AM   #20
crice8
crice8's Avatar
Fan#: 84830
lol your all good man. that is what this forum is all about. sharing ideas with other focus drivers so they can use them! heres the link(=
http://www.ebay.com/itm/28-SMD-LED-B...item33709c14ee
i have ordered 3 so far! lol i think im going to put one in my dome light today
Galatians 6:14
crice8 is offline
