2012 Focus Hitch is available - Page 9 - Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum
Old 05-28-2012, 03:15 PM   #81
cchaos
Fan#: 86214
What I Drive: 2012 Red Candy Focus Titanium
FF Reputation: 1 cchaos Good Standing Member
So I just installed the hidden hitch this weekend. Everything went fine until it came to the carriage bolts that need to be fished through -- the bolt heads do not fit through the access hole (similar to the previous poster). I had no problem fishing the wire through otherwise. Other than that, the hitch is installed and seems very sturdy. It was able to support my weight with no problem. But I'm not sure if it's safe to use without the horizontal carriage bolts.
cchaos is offline
Old 05-28-2012, 06:20 PM   #82
cchaos
Fan#: 86214
I removed the hitch and still was unable to fit the carriage bolts through the access hole. I'm still not sure how others got theirs to fit (aside from grinding the heads off).
So, I went to a hardware store and picked up some 3/8"x1.5" carriage bolts/washers/nuts. I was able to fit these bolts through the access hole and use them to tighten the sides of the hitch. These are slightly smaller than the bolts that came with the kit, but at least they fit, and I feel more comfortable using them than nothing at all on the sides.
Other than the carriage bolt issue, I do like the hitch, and like others have said it leaves plenty of clearance. Even with my Thule bike hitch installed, there is enough clearance to backup from my driveway to the street without nicking the ground, something my previous vehicle had a problem with.
cchaos is offline
Old 05-28-2012, 07:27 PM   #83
reker
Fan#: 98977
What I Drive: 2012, Sterling Grey, Hatchback
FF Reputation: 1 reker Good Standing Member
I finally installed my hitch today. I had to modify it a bit to accommodate my Kuat rack. Also had problems with the carriage bolts not fitting through the frame holes. Just grind off a little on each side and they go right through.
I needed a hitch that would work with a 2" receiver and since they don't make a class III for a focus I made my own.
I then powder coated it the same color as the car.
Installed and works great!
reker is offline
Old 05-28-2012, 11:50 PM   #84
NickCornell
NickCornell's Avatar
Fan#: 97233
What I Drive: 2012 Race red Focus SEL
Points 13,914, Level 76
Points: 13,914, Level: 76 Points: 13,914, Level: 76 Points: 13,914, Level: 76
Level Up 66% Completed
Forum Activity 3%
FF Reputation: 12 NickCornell Great Standing Member
Originally Posted by Faygo Focus View Post
Bikes on hitch, camping gear on roof, people and personal effects inside.
The end.
Check.mate. Agreed, I'm a camper and I live by this
NickCornell is offline
Old 08-12-2012, 05:49 PM   #85
baxdaddy
baxdaddy's Avatar
Fan#: 97890
What I Drive: bluecandy SEL 5dr Poppa Smurf
FF Reputation: 1 baxdaddy Good Standing Member
anybody had an issue with bolts coming loose (as stated by tech support) because you chose not to cut the heat shield? Installing in the A.M. and was curious as to necessity to cut. TIA.
baxdaddy is offline
Old 08-12-2012, 09:01 PM   #86
got3fords
Fan#: 93395
What I Drive: 2012 Sterling Gray SE Sport HB 203A
FF Reputation: 1 got3fords Good Standing Member
Its really no big deal to cut it. But I can understand not wanting to. Personally, if they really feel there is a possibility of it coming loose, just cut it. Just need a decent pair of tin snips or shears. Plus it keeps it up just that much higher for a nice finish.
got3fords is offline
Old 08-12-2012, 09:36 PM   #87
segen77
Fan#: 102160
What I Drive: 2012 Silver Titanium Hatchback
Points 711, Level 14
Points: 711, Level: 14 Points: 711, Level: 14 Points: 711, Level: 14
Level Up 11% Completed
FF Reputation: 1 segen77 Good Standing Member
I really like the MOD for a 2". This is exactly what I need to do for my bike rack. I don't like the idea of an extension adapter because I would worry it would hit the ground anytime I went into a driveway.
Anyone that has an adapter feel free to chime in.
Thanks
segen77 is offline
Old 08-13-2012, 02:17 PM   #88
baxdaddy
baxdaddy's Avatar
Fan#: 97890
Hitch is on, things of note:
1. I too had to grind down heads of carriage bolts to fit through frame
2. I didn't get the wire in my hardware bag...typical for me, seems I am always short a piece
3. Used wax string and safety wire to get bolt and spacer routed through frame
4. I too had a space between frame and hitch flange/plate, getting access to torque wrench before I tighten down any further
5. Noticed the entire hitch can mount more forward or more to the rear depending on personal preference. I went more to the rear to keep stuff off my bumper. Hitch still not out past bumper.
6. I chose not to cut heat shield, the muffler is mounted with it still on there and the screws for the hitch are a bit longer, I don't see them coming loose, YMMV
7. I put my carriage bolts through the frame first, seemed easier with less stuff in the way, plus i had to deal with not having the wires for them
8. I had the back on jack stands but I think it wouldn't be hard to do flat, IMHO
9. NOw I just have to decide what rack to get. Need a 2 but with the grandkids might want to consider a 4 bike.
Hidden hitch purchased through hitchanything.com
baxdaddy is offline
Old 08-13-2012, 06:54 PM   #89
got3fords
Fan#: 93395
I don't understand this, how hard would it be for the mfg to provide bolts that go right in? Not everybody has access to grinder.
This really boggles my mind. How can they make something that far off?
I did mine without jacks. Just backed up to the edge of the driveway.
See above comments.
Old 08-14-2012, 12:55 PM   #90
biglar412
Fan#: 99568
What I Drive: 2012 Blue Candy SE Hatch
Points 23, Level 1
Points: 23, Level: 1 Points: 23, Level: 1 Points: 23, Level: 1
Level Up 45% Completed
Level up: 45% Level up: 45% Level up: 45%
FF Reputation: 1 biglar412 Good Standing Member
Installed a Draw-Tite hitch. Did not use the carriage bolts or blocks that came with the hitch. Bought bolts with smaller heads and used a washer at the head end, then used the washer and nut that came with the hitch on the outside of the bolt. I did not cut the head shield. Going to use the hitch for a 4 bike rack.
biglar412 is offline
