Speaker wire Routing: Amp to Doors ???? - Page 2 - Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum
Old 10-01-2004, 12:41 PM   #11
carrierx
Fan#: 11957
FF Reputation: 1 carrierx Good Standing Member
Oh ok,, i just realized what was being said. That sucks.
When i get around to doing this,, ill make my decision then.
Yet another challenge...
carrierx is offline
Old 10-01-2004, 07:32 PM   #12
Toolman00
Toolman00's Avatar
Fan#: 2744
What I Drive: 2000 Ford Expedition XLT 4x4
FF Reputation: 3 Toolman00 Good Standing Member
I ran wires to the front speakers. I drilled a new hole on my driver side (used a grommet that came with the wiring) and used the rubber grommet on the door. It was kind of hard routing the wire, but it works... now I need to get cover it with some wire loom.
The passenger side was a little different. I used the rubber grommet on the door and used the plastic cap to get it inside. Still need to cover it, but it works.
Have no problems with the power wire and speaker wire running parallel too!
Only thing I regret is not knowing my back seat cushions folded forward exposing the bottom... would have made it easier running RCA's!
Give the toughest job to the laziest man and he'll find the easiest way to get it done.
Toolman00 is offline
Old 10-04-2004, 09:40 PM   #13
sublime053
Fan#: 10417
What I Drive: '04 ZX5
FF Reputation: 1 sublime053 Good Standing Member
Another option that you could do.. is if you have the amp in your trunk/hatch, just get long speaker wire (whichever guage you prefer) and then just run it from there, under the carpet, to the dash, then just splice it into the harness... that would probably be the easiest way to do it without having to take all the speakers out and trying to fit speaker wire through the doors and what not. Just have something around the wires to keep them together, like the sticky velcro stuff that ford has already put in there.
sublime053 is offline
Old 10-04-2004, 09:45 PM   #14
d3bilhan
Fan#: 12408
What I Drive: 2002 Silver ZX5
FF Reputation: 1 d3bilhan Good Standing Member
Have run wires inside of a piece of vacumn hose for the gap from the frame to the door.
Support Our Troops!
Drive like you mean it!
[img]
d3bilhan is offline
Old 10-04-2004, 11:16 PM   #15
SQFocusZTS
Fan#: 4729
What I Drive: 2000 Focus ZTS
FF Reputation: 2 SQFocusZTS Good Standing Member
the boots i used look factory. ribbed rubber boots... I honestly can't remember where i got them. I did a dogpile for 'rubber door boots' one day. it took a while for me to find a place online, but they will get repeat business from me (that is, if i can find their address or my invoice)
-john
SQF
John
SQFocusZTS
Certified MASTER Installer
one of 72 in the world...
SQFocusZTS is offline
Old 10-06-2004, 07:39 PM   #16
intuneauto
Fan#: 13992
What I Drive: 2001 focus se sedan
FF Reputation: 1 intuneauto Good Standing Member
running wires into doors
hey heres a easy trick,all you need to do is go to a salvage yard and grab a couple of door boots from other focus or probes 93 or newer,gut the insides and you can run your new wires thru there,the stock wires use standard eletronic male/female disconects that you can get at radioshack if you want to keep it as stock,but what i have done is just removed the center section and ran wires thru them,just make sure you make the connections the same.as far as running wire from the rear to the front i would never use the rear speaker wires as a way to the front,any decent stereo shop will have in bulk spool whats called SPEEDWIRE,its a fully jacketed amp connection with 4 channels already color coded,its only 3/4 around and if you remove your front seats and center console "should only take 20mins"you can run this wire all the way down the center to the hu and make your conections there for the fronts and the rears if you wanted to use the stock door wires,if not you can run off from there to the fronts and at the center of the car bewteen the rear doors you can split off to them
hey i worked for west coast customs and i want to pimp my own ride.Whos with me ?
intuneauto is offline
Old 10-06-2004, 09:25 PM   #17
SQFocusZTS
Fan#: 4729
well crap. why don't you just run speaker wire from the amplifier to where the deck is... connect the speaker wire to a reverse Ford harness, and connect the harness into the factory wiring. thats going to be the EASIEST way to get an externally amplified signal into the doors. The downside is that the signal wires (the oem speaker wires) are no more than 18awg.
-john
SQF
John
SQFocusZTS
Similar Threads
Car Audio and the Ford Focus SquillyB Car Audio, SYNC, MyFord Touch & Electronics 20 05-31-2010 11:38 AM
How To: Install Door Pocket LEDs evanjfrancis MK1 Interior Mods & Upgrades 10 09-12-2009 12:05 AM
HOW-TO: Getting that Stock Audiophile HU to turn on sub amp joshuass Car Audio, SYNC, MyFord Touch & Electronics 3 07-12-2007 01:42 AM
How-To: St-170 headlight wiring instructions focus4dr General Technical Chat 1 12-30-2004 03:00 PM
Sound System Question (Advice) Chelica Car Audio, SYNC, MyFord Touch & Electronics 16 05-23-2004 02:04 PM
