2002 Zetec engine miss - help - Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum
Old 06-06-2011, 09:14 PM   #1
jezzowhat
Fan#: 86525
What I Drive: 2002 black zts
FF Reputation: 1 jezzowhat Good Standing Member
Hi,
My name is Teresa and I am new to the forum and am hoping someone can help me. I have a 2002 Ford Focus that has randomly had an engine miss at all speeds which is progressively getting worse. It used to come and go but the engine is doing it constantly for the last couple of days. The spark plugs have been changed yesterday but did not help. I am not sure what to check next, the alternator is putting out 15v to the battery. The wierdest thing is if I push the OD button [auto trans] the engine missfire goes away almost completely but the car still has no power. The engine is a Zetec 16 valve.Any help would be appreciated.
Thanx in advance.
jezzowhat is offline
Old 06-06-2011, 10:05 PM   #2
viney266
viney266's Avatar
Fan#: 93
What I Drive: focus ztw ,zx3,mustang, motorcycles
Points 236,661, Level 100
Points: 236,661, Level: 100 Points: 236,661, Level: 100 Points: 236,661, Level: 100
Level Up 0% Completed
Forum Activity 3%
FF Reputation: 112 viney266 Excellent Standing Member viney266 Excellent Standing Member
Buy-Sell-Trade Rating: (4)
Hi!...Welcome to the forum. I"ll bet you just need to finish the job. Are those the original spark plug wires?
1.) replace spark plug wires and boots
2.) Inspect the wires going to the coil itself. They can fray or be damaged. Its common
3.) if after these 2, do the fuel filter as well, if its been more than 30K miles...
BUT, I"ll betcha its the spark plug wires.
Speed is only a matter of money; how fast do you want to go?
viney266 is offline
Old 06-06-2011, 10:08 PM   #3
BC_ZX3
DTC P0606
BC_ZX3's Avatar
Fan#: 48751
Points 2,074, Level 27
Points: 2,074, Level: 27 Points: 2,074, Level: 27 Points: 2,074, Level: 27
Level Up 50% Completed
Forum Activity 5%
If the plugs are correctly gapped and the spark plug wire boots snug, work backwards from the plug. (btw, examining the plugs when they were replaced may have given you a clue as to which cylinder was misfiring, if it was only one.) Check plug wires (chafing), coil itself (for cracked plastic insulation), coil electrical connector (for broken/loose wires).
Edit: viney266 beat me to it.
BC_ZX3 is offline
Old 06-06-2011, 11:37 PM   #4
Vexorg
Vexorg's Avatar
Fan#: 85499
What I Drive: 2001 Zx3 ChromeGold
FF Reputation: 3 Vexorg Good Standing Member
Did someone install the dreaded evil Bosch spark plugs?
Vexorg is offline
Old 06-07-2011, 01:25 AM   #5
kevinjohnson3216
Fan#: 86247
What I Drive: 2003 Sonic Blue ZX3
FF Reputation: 3 kevinjohnson3216 Good Standing Member
Check if all plugs are firing.
Start your motor.
One by one, starting from plug #1, pop the wire off the plug.
A difference in the motor idle = good.
No difference = no spark.
Inspect the plug with no difference. Sand it, re-gap it, replace.
Check to see if it's sparking now.
If not, inspect the wire up to the distributer.
Just follow the plug wires around, inspect for shorts.
Good luck.
kevinjohnson3216 is offline
Old 06-07-2011, 06:04 PM   #6
jezzowhat
Fan#: 86525
Thanx for the tips, I will try them this weekend. Why would the OD button have anything to do with this - the engine miss goes away when it is pressed? Computer or tranny sensor problem?
Thanx again
Old 06-08-2011, 02:19 AM   #7
Vexorg
Vexorg's Avatar
Fan#: 85499
If its not shifting into O/D, it means the motor runs at a higher RPM while driving... misfires happen more at low RPMs.
Vexorg is offline
Old 06-08-2011, 11:58 AM   #8
sjfishon
sjfishon's Avatar
Fan#: 79619
What I Drive: 01 black se wagon/14 white se sedan
Points 684, Level 13
Points: 684, Level: 13 Points: 684, Level: 13 Points: 684, Level: 13
Level Up 68% Completed
Forum Activity 7%
FF Reputation: 7 sjfishon Good Standing Member
Is it ok for the first few min. when you start it?, if so, i would think fuel filter;;;;;;either way,if the filter has not been changed, change it.
sjfishon is offline
Old 06-08-2011, 01:23 PM   #9
jezzowhat
Fan#: 86525
Hi, the engine misses right at startup, just sitting and idling but it smooths out when the OD button is pushed.
Old 06-08-2011, 02:03 PM   #10
sjfishon
sjfishon's Avatar
Fan#: 79619
Forum Activity 7%
is it showing check engine lite?
sjfishon is offline
