2010 Focus - rattling noise in engine area/compartment? - Ford Focus Forum, Ford Focus ST Forum
Go Back   Ford Focus Forum, Ford Focus ST Forum > Ford Focus Second Generation > MK2 Focus
Old 06-06-2011, 01:06 AM   #1
sirhawkeye
Fan#: 83605
What I Drive: 2012 Focus SE Ingot Silver HB
FF Reputation: 1 sirhawkeye Good Standing Member
Just curious, but every once in a while, when accelerating in my car, I can hear what sounds like a small rattling noise, mainly when accelerating at lower speads, like from a stop sign. I don't really hear it if I accelerate moderately fast, but if I do a nice smooth gradual acceleration, I can sometimes hear it.
My first thought is that maybe the car is not putting out enough torque or I'm at one of those speeds where the car is getting ready to shift to the next gear. It's kind of like a growling/rattling noise, but noting intense or loud. Just can kind of hear it.
I checked all of the fluids and they check out OK (clean and full), and the car still shifts OK. No odd engine noises (other than what I'm describing), and it doesn't always make this noise... just periodically when accelerating.
I'm the only owner of the car (bought it new) and it's got about 4k on it now (it's a 2010). I also have the automatic trans if that matters any. Nose will stop immediately after I take my off of the gas, too. But if I push back on the gas, most of the time, it goes away. Could it be a vibration of some sort or am I looking at a more serious problem (car is still under warranty of course).
Does anyone else experience this? Also, I do note that it does occur most during first and second, and really don't hear it beyond that, so i don't really hear it beyond about 30 mph.
sirhawkeye is offline
Old 06-06-2011, 08:33 PM   #2
hammy627
Fan#: 86517
What I Drive: 2010 Classic Silver SE Sedan
Points 47, Level 1
Points: 47, Level: 1 Points: 47, Level: 1 Points: 47, Level: 1
Level Up 94% Completed
FF Reputation: 1 hammy627 Good Standing Member
try to find out if it only happens at a certain engine rpm. It can also be something under the car like an exhaust heat shield that sounds like it is coming from the front. Either way, Ford should fix it before your warranty runs out. It is a great car and you deserve to be happy with it.
hammy627 is offline
Old 06-06-2011, 09:24 PM   #3
redSVT_03
redSVT_03's Avatar
Fan#: 78206
What I Drive: 2003 red SVTF
Points 2,457, Level 30
Points: 2,457, Level: 30 Points: 2,457, Level: 30 Points: 2,457, Level: 30
Level Up 5% Completed
FF Reputation: 4 redSVT_03 Good Standing Member
Buy-Sell-Trade Rating: (4)
You drive a focus I think everyone experiences these sounds. It is almost definitely one of your heat shields. I had same problem jacked the car up to find the damn winter salt hat corroded the aluminum around the bolts and the whole shield dropped on my exhaust
redSVT_03 is offline
Old 06-19-2011, 05:47 PM   #4
Miller88
Fan#: 73790
What I Drive: 2011 Focus SE 5 Speed
Points 1,520, Level 22
Points: 1,520, Level: 22 Points: 1,520, Level: 22 Points: 1,520, Level: 22
Level Up 20% Completed
Forum Activity 9%
FF Reputation: 5 Miller88 Good Standing Member
My focus has done this since brand new. Ford heat shields don't last long.
Miller88 is offline
Old 06-19-2011, 06:58 PM   #5
Gabe2010SE
Gabe2010SE's Avatar
Fan#: 70327
What I Drive: '13 Mustang 5.0L 6spd, '10 Focus SE
Points 2,976, Level 33
Points: 2,976, Level: 33 Points: 2,976, Level: 33 Points: 2,976, Level: 33
Level Up 51% Completed
Level up: 51% Level up: 51% Level up: 51%
FF Reputation: 2 Gabe2010SE Good Standing Member
If you're using crap gasoline it may be pinging/knocking, especially if you only hear it on hard acceleration.
Otherwise, you may be hearing injector-tick, which is normal.
There is a Technical Service Bulletin for ticking sound at idle, and the tech has to add a soft cover over the fuel rail, to quiet the injectors down.
I had it done on mine even though I didn't really hear anything ...
See the pic below for the cover I'm talking about ... if your car already has it, then nevermind
'13 Mustang GT SterlingGray, 6-spd man, Recaros, Track Pack. Ordered 6.6.12, born 7.25.12, mine 8.11.12. 2.3L Whipple & a few other things. 591 RWHP, 505 RWTQ
Gabe2010SE is offline
Old 06-20-2011, 11:33 AM   #6
david_king021
Fan#: 86943
What I Drive: 2008 white SE
FF Reputation: 1 david_king021 Good Standing Member
I had kinda the same noises coming from my 08' and after messin around alot i found that it was the ram air box vibrating against the inner fender haha scared me a little tho
david_king021 is offline
Old 06-20-2011, 12:05 PM   #7
red2009se
Guest
Fan#: 79513
What I Drive: car
FF Reputation: 1 red2009se Good Standing Member
Well, I'll take the Duratec's ticking over the SPI's various thumps, grinds, and whacking sounds. I had a 2000 Escort SPI and it was a true "four banger".
red2009se is offline
Old 07-04-2011, 10:13 AM   #8
LS14EVR
Fan#: 74361
What I Drive: 2010 Sangria Red Metallic SES
FF Reputation: 2 LS14EVR Good Standing Member
I drive a stick and if I do a slow start under low rpm, like 1000 and under, I get that same rattle. I'm about 100% sure it's a heat shield. I'm at 30K miles on my 2010 and it will be going in at 35 or so to have everything looked over and hopefully at that time get that fixed. It's not a pinging. I run good gas and fill up every 3 days. So it's fresh too. It's just something vibrating.
LS14EVR is offline
Old 07-04-2011, 11:05 AM   #9
2011 SE
2011 SE's Avatar
Fan#: 80951
What I Drive: 2011 SE
FF Reputation: 8 2011 SE Good Standing Member
Agreed, I have a 2011 (manual) with 18k miles and I get the same. When it dips to about 500 RPM is the worst. But what can I say, I like the growl.
2011 SE Manual - black exterior/interior
Eagle Eyes halo projectors using 55w 5000K DDMtuning HIDs
LED Conversion (license plate, map/dome lights), and LED Taillights
Autobots decal over Ford emblems
Flat black TFB Designs hood stripes
2011 SE is offline
Old 07-08-2011, 10:06 PM   #10
greeniiis10859
Fan#: 66231
What I Drive: 2010 Neutral Natural SE Sedan
FF Reputation: 1 greeniiis10859 Good Standing Member
2010 Focus SE Automatic - 13K miles on it and I'm just noticing the rattling ... My 08 did the same thing but had other problems with the front end. when I took my 08 to the dealer they always said it was nothing ...it wouldn't happen for about a month or so then would start back up. I traded my 08 in for my 10 and later found out about a bulletin on the front ends making some serious noise for all of second generation Focus. I don't visit the dealer much anymore... since I have access to a shop and can do the work myself...
greeniiis10859 is offline
