Sound System Install - Page 3 - Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum
Old 06-07-2011, 04:01 PM   #21
Wontfinishlast
Wontfinishlast's Avatar
Fan#: 65496
What I Drive: 2012 Sterling Grey Focus Hatch Ti
FF Reputation: 1 Wontfinishlast Good Standing Member
Man I'm really hoping the system is good enough where I won't be annoyed listening to it. I've put a system in every car I've had so far and I was really hoping that this sony system would be just good enough where I would be ok with leaving it where it is. The whole point of ordering this car was to get it exactly how I wanted it. Plus I figured I rarely listen to music loud any more so power wasn't an issue. Just hoping for "acceptable" accuracy. Guess we'll see in about a month when the car comes in...
2012 Ford Focus Titanium Hatchback: Sterling Grey/Machined and painted wheels/Moon roof/Titanium premium package/Winter package
Ordered 5/2/11, Built 6/15/11, Picked up 6/24/11
Wontfinishlast is offline
Old 06-10-2011, 09:31 AM   #22
HammerStriker
HammerStriker's Avatar
Fan#: 86553
What I Drive: 2012 Ignot Silver Hatchback SEL
FF Reputation: 1 HammerStriker Good Standing Member
I finally got a chance to do some measuring. The existing subwoofer box has .37 cu. ft. of sealed air space. So the existing box is not large enough to accommodate a 10" sub even though one would physically fit. I can make a box fit into the factory spot that will have .6 cu. ft. with a top mounting depth of 3.125" to accommodate most shallow mount 10” subs.
I just don’t know if all the work will be worth adding it into the factory system. So if this is gonna happen, I need to start looking into RMS ratings, signal processors, mono amps, capacitors… Oh crap, here we go again!!
HammerStriker is offline
Old 06-10-2011, 09:41 AM   #23
Stereodude
Fan#: 85623
What I Drive: 02 Maxima SE
FF Reputation: 2 Stereodude Good Standing Member
Originally Posted by Tony407 View Post
I knew I knew you from somewhere!!!! I had a 2001 Maxima and was a member of Maxima.org for several years (screen name Tony Fernandes), and I remember you from there.
I remember you there as well. Small world running into you over here. I'm waiting for an ST myself.
Stereodude is offline
Old 06-12-2011, 06:27 AM   #24
ohman11
Fan#: 86670
What I Drive: 2012 Candy red SE
FF Reputation: 1 ohman11 Good Standing Member
Can you tell me what size the door speakers are and the tweeters?
i am sorry if you posted this already...
i didnt see it if you did.Thanks!
ohman11 is offline
Old 06-14-2011, 05:21 AM   #25
Tony407
Tony407's Avatar
Fan#: 85289
What I Drive: 2012 Sterling Gray Hatch Titanium
Points 11,374, Level 70
Points: 11,374, Level: 70 Points: 11,374, Level: 70 Points: 11,374, Level: 70
Level Up 31% Completed
Level up: 31% Level up: 31% Level up: 31%
FF Reputation: 4 Tony407 Good Standing Member
The door speakers are 6.5". Not sure what the tweeters are, I didn't measure them. But if you look on JL Audio's website for the tweeters that come with the ZR-650csi set, the dimensions are pretty close. Not much bigger than 1" I would guess.
Tony
Tony407 is offline
Old 06-14-2011, 06:01 PM   #26
jmcase1234
Fan#: 86796
What I Drive: 2012 Red Focus Titanium 4 door
FF Reputation: 1 jmcase1234 Good Standing Member
Tony,
Quick question.. How do you go about removing the door panel? I have removed the tork screw on the side of the door, behind the reflector, the one in the middle of the door release lever and I have removed to plastic trim piece connected to the window controls.. Do the control's themselves need to be removed to access anything else? if So how Do I remove it? if not what else am I missing to be able to remove the panel? Thanks in Advance!
jmcase1234 is offline
Old 07-07-2011, 07:56 AM   #27
newmission
newmission's Avatar
Fan#: 84688
What I Drive: YB-MK3-MTX-SE-OG Sport-HB
FF Reputation: 5 newmission Good Standing Member
I'm interested in knowing if there are any precautions when removing the door panels as well. Anything to watch for so you don't break anything? Clips, etc..? Also, don't know if you posted or not. But did you happen to catch the max mounting depth allowed? Looking on putting in some RF Power Series and need some room!
Hatch Nation #110
Debadge-and Drive Naked
Home of the Free Blacked Out Grille Mod, and Griffin Ram Air Mod.
Get you some!
newmission is offline
Old 07-07-2011, 12:37 PM   #28
STL 314
STL 314's Avatar
Fan#: 87196
What I Drive: 2012 Ti
FF Reputation: 2 STL 314 Good Standing Member
Good stuff Tony! Eager to follow your install...
STL 314 is offline
Old 07-09-2011, 08:11 PM   #29
mattlqx
mattlqx's Avatar
Fan#: 87201
What I Drive: '12 SE 5-dr MT Yellow, '13 Boss 302
FF Reputation: 1 mattlqx Good Standing Member
Just installed F+R speakers in mine... It's pretty straight forward.
I found these instructions on another forum post. Reprinted here for permanence.
Front doors:
1. Use pick to remove screw cap cover behind door handle.
2. Unscrew (1) T-20 torx behind screw cap just removed.
3. Use PRT to unclip side trim around window switch panel.
4. Unplug window switch panel and remove.
5. Unscrew (2) T-20 torx from behind the panel just removed.
6. Unscrew (1) T-20 torx located on the side of the door panel.
7. Use PRT to unclip red reflector lens.
8. Unscrew (1) T-20 torx from behind the panel just removed.
9. Use PRT to unclip door panel, unplug and remove.
10. Unscrew (3) T-27 torx securing the speaker, unplug and
remove.
Rear Doors:
3. Use PRT to unclip window switch panel, unplug and remove.
4. Unscrew (2) T-2 0 tor x behi nd th e panel just removed.
5. Use PRT to unclip the door panel, unplug and remove.
6. Unscrew (3) 7mm bolts securing the speaker, unplug and
remove.
Kickers in the front... match the door paint. ;)
mattlqx is offline
Old 07-09-2011, 11:09 PM   #30
Tony407
Tony407's Avatar
Fan#: 85289
Awesome! You might want to think about taping those wires down so they don't rattle inside the door panel. And matching yellow? Cool!
Tony
Tony407 is offline
