How to: USB2 add media (2012 focus) - Page 3 - Ford Focus Forum, Ford Focus ST Forum
Go Back   Ford Focus Forum, Ford Focus ST Forum > Ford Focus Tech Discussions > Car Audio, SYNC, MyFord Touch & Electronics
Old 11-13-2011, 09:23 PM   #21
voipguy
Fan#: 85222
What I Drive: 2012 S.Grey SE Spt,4dr,Wint,MR,6sp
FF Reputation: 1 voipguy Good Standing Member
I did this mod tonight and here are my thoughts.
1. Use a flat blade screw driver to take the flap off the side panel.
2. Getting that round pin out wasn't easy, had to work it loose and carefully pull at the panel the way described, make sure you remove the front floor mat.
3. I ordered the monoprice adaptor as mentioned earlier but it would not fit so I had to shave it down, then I was able to get into the connector. I'm thinking about using a Standard USB mini 5pin male to Male USB cable and getting one of these:
http://www.amazon.com/USB-Female-Ada...1230113&sr=8-2
This way it will fit better & we can try to connect a USB Memory stick into the adapter as well as an I-pod, will let you know if it works better!
voipguy is offline
Old 04-03-2012, 04:18 PM   #22
PrideSax711
PrideSax711's Avatar
Fan#: 97050
What I Drive: 2012 Ingot Silver SE
FF Reputation: 1 PrideSax711 Good Standing Member
I know this is an old post, but if I were to do this and simply plug a 32gb flash drive into the USB2 port, would it play? I would like to just open it up, put in the loaded flash drive, and forget about it.
2012 Ingot Silver Focus SE with SFE package. 203A package.
PrideSax711 is offline
Old 04-03-2012, 11:17 PM   #23
voipguy
Fan#: 85222
Yes you can connect a usb memory stick, you need to use the correct cables. I used a Standard USB mini 5pin male to Male USB cable and a female to female usb adapter and then connected another usb male to female connecter, then the usb stick plugs into the usb female end.
Works good for me.
voipguy is offline
Old 04-03-2012, 11:28 PM   #24
PrideSax711
Fan#: 97050
Works good for me.
Cool, how does Sync decide which USB port to use?
Old 04-04-2012, 01:03 AM   #25
PrideSax711
Fan#: 97050
Works good for me.
I'm going to try this option. One question though, why do you need a USB male to USB female connector after the female to female?
Old 04-04-2012, 09:18 AM   #26
voipguy
Fan#: 85222
My usb stick fit better that way, it needs to make a good connection.
Depending on your memory stick, make sure the usb end fits in good.
voipguy is offline
Old 05-20-2012, 09:31 AM   #27
valmundo
Fan#: 89368
What I Drive: 2012 Focus SE & 2013 ST2
Points 3,703, Level 38
Points: 3,703, Level: 38 Points: 3,703, Level: 38 Points: 3,703, Level: 38
Level Up 36% Completed
FF Reputation: 11 valmundo Great Standing Member
I just did this upgrade this weekend. Now I have the option of plugging in my ipod classic (120Gig) to sync via an ipod cable located in my glove compartment or inside the arm rest. If my phone is low on power it is nice to know that I can still use my ipod (USB2) while my phone gets charged via the USB1 port. Thanks for the info and instructions.
valmundo is offline
Old 06-22-2012, 02:08 PM   #28
Megalomantic
Megalomantic's Avatar
Fan#: 99398
What I Drive: 2012 Tux Black Focus SE Sport Sedan
FF Reputation: 1 Megalomantic Good Standing Member
I was wondering if anyone ever tried going back and forth between USB and USB2 once they've done this with two different media devices? I've noticed that it will only recognize one or the other. I've read on other ford forums that this is because of a powering issue but I find that hard to believe because it still charges my iphone quickly even if its not the active media device.
Megalomantic is offline
Old 06-26-2012, 02:53 PM   #29
voipguy
Fan#: 85222
I can switch between 2 usb memory sticks, one on USB and one on USB2.
If it doesn't work make sure you have a good connection that seems to be the key to getting it to work reliably.
voipguy is offline
Old 06-28-2012, 07:09 PM   #30
bdashrad
bdashrad's Avatar
Fan#: 48741
What I Drive: 2012 Silver SEL Hatch - 06.06.2011
FF Reputation: 1 bdashrad Good Standing Member
just did this, pretty easy project and i love having 2 usb inputs now!
bdashrad is offline
