Hill Start Assist on 2012 Focus? - Page 5 - Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum
Old 06-05-2012, 08:15 AM   #41
kam327
-----<M>-----
kam327's Avatar
Fan#: 94700
What I Drive: '14 Ruby Ti w/ Handling Pkg
Points 7,615, Level 58
Points: 7,615, Level: 58 Points: 7,615, Level: 58 Points: 7,615, Level: 58
Level Up 33% Completed
Forum Activity 3%
FF Reputation: 13 kam327 Great Standing Member
Originally Posted by asting View Post
It can be turned off. In fact, you have to activate it by holding the brake as you shift into first (with clutch in).
What car are you talking about?
kam327 is offline
Old 06-05-2012, 09:52 AM   #42
lscrx
Fan#: 41668
What I Drive: 2012 Focus SE hatch 5mt
FF Reputation: 2 lscrx Good Standing Member
In the European models it's a feature under the "driver assist" menu, and it works fine with the 6 speed manual... although I found it a bit slow to release if you're used to being really quick with the clutch on inclines.
Posted via FF Mobile
lscrx is offline
Old 06-05-2012, 11:18 AM   #43
asting
Fan#: 98342
What I Drive: 2012, Tux Blk Met Focus 5d Sport
Points 509, Level 10
Points: 509, Level: 10 Points: 509, Level: 10 Points: 509, Level: 10
Level Up 18% Completed
FF Reputation: 1 asting Good Standing Member
Sorry I'm a little confused. I'll be pulling out my manual when I get back.
asting is offline
Old 06-05-2012, 11:24 AM   #44
kam327
-----<M>-----
kam327's Avatar
Fan#: 94700
Forum Activity 3%
I think it will tell you that HSA automatically activates with application of the brake on a slope of greater than 4 degrees or so. I guess there is a procedure for deactivating it but it's not as easy as the push of a button like I was alluding to earlier.
The manual does say something like the brake must be fully depressed or something, but that's subjective. HSA comes on frequently for me and I'm just using the brakes like I normally do.
kam327 is offline
Old 06-05-2012, 11:26 AM   #45
asting
Fan#: 98342
Yeah must of my confusion stems from mt availability, as the manual.reads like it should be there.
asting is offline
Old 06-05-2012, 11:26 AM   #46
kam327
-----<M>-----
kam327's Avatar
Fan#: 94700
Forum Activity 3%
Here's the actual text:
Using hill start assist
The system is activated automatically when the vehicle is stopped on a
slope greater than four degrees. Hill start assist operates with the vehicle
facing downhill if reverse gear is selected.
Activating hill start assist
1. Press the brake pedal to bring the vehicle to a complete standstill.
Keep the brake pedal pressed.
2. If the sensors detect that the vehicle is on a slope, the system will be
activated automatically.
3. When you remove your foot from the brake pedal, the vehicle will
remain on the slope without rolling away for approximately two to three
seconds. This hold time will automatically be extended if you are in the
process of driving off.
4. Drive off in the normal manner. The brakes will be released automatically.
Note: If the engine is revved excessively, hill start assist will be deactivated.
Deactivating hill start assist
To deactivate hill start assist, perform one of the following:
Apply the parking brake.
Drive off uphill without re-applying the brake.
Wait for two to three seconds until the system deactivates
automatically.
For automatic transmissions: If hill start assist is active in D (Drive),
select R (Reverse). If hill start assist is active in R (Reverse), select N
(Neutral).
For manual transmissions: If a forward gear was selected when the
system became active, select reverse gear. If reverse gear was selected
when the system became active, select a forward gear.
Note: If a malfunction is detected in the system, hill start assist will be
deactivated and a warning message will appear in the instrument cluster.
Refer to System warnings and status messages in the Instrument
Cluster chapter for hill start assist messages.
kam327 is offline
Old 06-05-2012, 12:02 PM   #47
AJ_BS
Fan#: 95722
What I Drive: 2012
FF Reputation: 1 AJ_BS Good Standing Member
Preload the clutch, problem solved. Hand brake is for people who shouldn't drive a manual.
AJ_BS is offline
Old 06-05-2012, 12:05 PM   #48
Bimmer-Bob
Fan#: 98064
What I Drive: 2010 BMW 128i; 2012 Focus SE Sport
FF Reputation: 3 Bimmer-Bob Good Standing Member
I love all the people here who think they can dictate who should or shouldn't be driving a manual. Get over yourselves already.
Bimmer-Bob is offline
Old 06-05-2012, 12:08 PM   #49
AJ_BS
Fan#: 95722
What I Drive: 2012
It's my opinion, why do you think anybody should care about yours?
AJ_BS is offline
Old 06-05-2012, 12:12 PM   #50
Bimmer-Bob
Fan#: 98064
Because this is a thread for people sharing information about the availabilty of a specific feature on the car. Your opinion about who should or shouldn't be driving a manual doesn't add to the dis ussion in any meaningful way.
