#581 | ||||
#582 | ||||
Same problem here.
Hello everyone,
I am having the same issue that everyone is. I have a 2012 titanium hatchback with close to 38K miles (long commutes to San Diego). Last Friday I noticed the car would shutter when I stepped on the gas from a dead stop. It was looked at today by Rancho Ford in Temecula. They tech agreed that there is a problem, so they flashed the transmission module, that didn't help. The service advisor told me that Ford's next step is to replace some actuators in the transmission, those are on order right now. They should be in next week. I'll post to let you know if this helped after they replace the actuators. |
#583 | ||||
I want to escalate both of your cases to your regional customer service managers. Send me a PM with your VIN, dealer, mileage, daytime phone number, and full name; I'll get your information into your CSM's hands and ensure someone contacts you quickly. Let me know if you have any other questions. Thanks! Crystal
FORD SERVICE p: 800.392.FORD t: @FordService @FordFocus @Ford f: facebook.com/FordFocus facebook.com/Ford |
#584 | ||||
I rented a 2013 Focus for work - it only had 6 miles on it when I got it! Anyway, I've noticed some differences and I'll report back with my findings (transmission and cosmetic) later today. ^_^
2012 FF Ti HB Kona Blue, Built 5/24/2011, 401A + Ti Handling Package, Parking Technology Package, Winter Package, Moonroof, and MFT w/NAV at 3.5.1 53k miles and counting... |
#585 | ||||
Hello I am also experiencing the same problem with my 2012 Focus. The car has always had a slightly rough shift (makes my wife slightly nauseous). I've brought this issue up every time I have had the car in for maintenance and each time received the same reply from the service rep, "That's just the way that new trans works, you'll get use to it." I assumed they new what they were talking about an took their word. I also brought up the funky smell that was coming from the AC unit periodically. They said that was normal as well.
Over the summer I had the focus in fro the recall on the transmission programming and something else. Brought up the AC issue again and they insisted it was normal. In October of this year I started to experience a loud grinding noise every time I turned left. Concerned I took my car back in and brought up the AC smell as an issue (again). This time around it turns out their was a service bulletin out for bad front springs and they investigated the AC unit to find that the drain plugs were never removed hence the wet dog smell I had been complaining about for several months. After picking my car up the smell was gone and the severe grinding noise from turning was gone. However in it's place I started to experience and high pitch squeaking noise coming from the front end and a new grinding noise when the car shifts from 1st to 2nd gear. I took the car back in and the service tech noted that the springs weren't properly seated which caused the squeaking noise. After keeping my car for several days they diagnosed the grinding noise as (I kid you not) CD's in the glove box banging around. I argued with the manager and he said he was unable to replicate the noise but when he took out the CDs the noise was gone. Frustrated and in need of my car I accepted this and left. After filling out the Service Experience Survey detailing my unhappiness the service manager called me back and asked me to bring in the car. I did and took him for a test drive at which point he heard the noise and insisted he could fix it (in a two weeks when the trans guy wasn't busy). November 19th I took the car in again for the SAME problem and the service manager said he would reset the program and this should fix the rough shifting and eliminate any grinding as "the trans learns from your driving" After picking it up and immediately hearing the same grinding noise I spoke with the service manager again. He told me the noise is normal and will get better as I continue to drive. I called and talked with him again today as the noise is getting significantly worse and he told me, "There's nothing Ford will allow us to do, your car is up to date" I'm really concerned that this is an issue as a grinding trans usually mean an expensive fix down the road. With the car under warranty I want to have the issue corrected but so far my dealership is telling me there's nothing wrong. I didn't have this problem until they updated the program and replaced the defective springs. |
#586 | ||||
According to another thread the sound is most likely caused by cheap ball bearings or some such. As long as there is no abnormalities with the clutch and no oil is leaking through to the transmission, don't fret. It sucks, but we'll all just have to live with it.
2012 Ford Focus 5dr Hatchback Metallic Black SEL 301A |
#587 | ||||
Here's my horror story... (And soory for my english I'll do my best)
This summer I bought a 2012 Ford Focus Titanium slightly used with about 36000Kilometers on it that's about 22000 miles.. The first couple weeks the car seems fine a bit sluggish but I already knew about this car having a new kind of automatic\standard transmission so I drive it as is and after a couple days I start getting used to it . Hot summer temperatures roll in and so it begins...The tranny seems to be getting worse especially in traffic it starts shuddering badly and being more unresponsive so I start looking for answers and I find this website. Going threw a few threads I find that there is an update so I give the dealer a call and the technical adviser tells me to come in and that they will flash it so I leave them the car and pick it up a couple hours later .. Great !! I'm all happy thinking that they've resolved the problems but on my way home 1st and 2nd gear starts grinding BADLY as if you were driving a standard and you shifted into the wrong gear. I give them a call, they tell me to give it about a 1000KMS as the tranny as to get used to the way you drive... ok .. After a couple months of *waiting* for the transmission to get to know me lol I give them a call explaining how sick and tired I am of driving this car it has gotten so bad my girlfriend won't even hop in this car (true story) I bring it back they tell me that there's oil inbetween the engine and transmission and to leave them the car for a week for them to change the clutch, seals, motor and actuators a week later they call me and I go pick up the car. The mechanic tells me that its still shaking badly but the hotline told him to give it time.. again... and guess what? It's now worse than ever.. I asked the service manager if Ford would consider giving me what the car is worth and take it back if they can't fix the problem and he laughed Anyways now its in for the fourth time. Sad thing is that I'm 22 and have been a Ford guy my entire life. I have a 1997 Ford Thunderbird, bought a brand new Ford Ranger last year from Ford, bought a 2008 Ford Focus also from the dealer and now this.. This one will be my last Ford EVER unless Ford does something for me very soon. http://www.youtube.com/watch?v=ugwty...ature=youtu.be (listen at 5:6 sec then 9:10 and then again at 14:15) And this was before it got REALLY BAD lol |
#588 | ||||
My latest issue - there is a pretty odd rattling of the valves sound when it shifts from 1st to 2nd. Dealer looked at it and later the tranny guy says another Focus was in for some work and he said it also does the same thing. But I don't remember this noise happening in the last year of ownership and the new ones on the lot sure as heck don't do it.
And with all the latest updates installed I was thinking that this car seems slower than it used to be. So I try accelerating from a dead stop.. and around 11 seconds later I hit 60mph. Specs on this car say 0-60 should be just under 8 seconds. Hmmm... |
#589 | ||||
#590 | ||||
I have a same issue for a while now. Weird part though is why MPG going south, no clutches slipping, maybe shift schedule is off a little, but for some unknown reason we are loosing mpg, I can't get above 32-33 hwy.
| Thread Tools | |
| Display Modes | |
