2012 Focus Transmission Shaking - Page 56 - Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum
Old 11-19-2012, 09:57 PM   #551
suss6052
suss6052's Avatar
Fan#: 95752
Points 10,050, Level 66
Points: 10,050, Level: 66 Points: 10,050, Level: 66 Points: 10,050, Level: 66
Level Up 50% Completed
Forum Activity 24%
Originally Posted by Ysteven View Post
PratoN
, you better move quickly then. You 11k away from picking up the tab. Good luck. Keep us posted, I gave up repairing it. They took mine for two weeks, no loaner. So I end up using my H2 where spend tons on gas fill up. So I desided will drive till it fall of the engine or have free time to bring it back. I will try different dealer soon though.
He has the 125k mile extended warranty, but he also has the $125 deductible even if they don't find anything wrong. So even though it should be covered Ford has been less than forthcoming with fixing the car or even determining that there is an actual physical mechanical problem in his case. Sounds like there might be bad seals and oil contamination, but they don't want to fix it period. That seems par for the course apparently. Not good.
suss6052 is online now
Old 11-19-2012, 09:58 PM   #552
Ysteven
Fan#: 101029
What I Drive: 2012 oxford white sel, H2, F-150
FF Reputation: 1 Ysteven Good Standing Member
Redngreedy, if we talking about same thing that leaked. I doubt you had a leak there, maybe it's made up receipt. How it CANNOT leak if trans and engine connection not tight.
If iam not mistaken its just bolt on attachment without gasket.
I did have a similar leak on old 03focus when pump seal broke, oil everywhere. DCT trans different but doubt it's totally different attachment.
Ysteven is offline
Old 11-19-2012, 10:00 PM   #553
Ysteven
Fan#: 101029
,,,, good warranty. I might extend my warranty if will not find solution soon.
Ysteven is offline
Old 11-19-2012, 10:06 PM   #554
Ysteven
Fan#: 101029
How many seals are there,.? Thought its 2on axles and 1on clutch assembly .
Any of those will give you VISIUAL symptoms. Unless I'm wrong.
It's not hydraulic trans to have pressure tight components.
Ysteven is offline
Old 11-19-2012, 10:14 PM   #555
suss6052
suss6052's Avatar
Fan#: 95752
Forum Activity 24%
There is a seal on the transmission shaft/ case facing the bell housing/ clutch area that has been known to have issues to the point of there being a TSB being issued about it. NO it would not necessarily give visual symptoms if the leak is sufficiently slow and contained within the housing. That's the problem, they want to see an external leak to find evidence of an internal leak.
There have also been rear main seal leakage issues on a few cars which has also destroyed the clutch pack.
I don't know how many seals there are precisely as I didn't work on the gearbox and I haven't been pouring through the service manuals at the moment, but I do know there is a TSB about at least one particular seal leak.
Old 11-19-2012, 10:18 PM   #556
Ysteven
Fan#: 101029
I see what you mean.
Is there way to look on it if I pull starter out. Go in with flash light or I have inspection snake camera? I would give it a shot to do so on these long upcoming weekends. Of course if you guys say if its possible to find out without pulling trans of the engine.
Ysteven is offline
Old 11-19-2012, 10:33 PM   #557
Ysteven
Fan#: 101029
What about vacuum or pressure test,.? By using vent as your port!! Sounds crazy but that might work, axles are accessible and if nothing on them then it's internal bleeding.
Ysteven is offline
Old 11-20-2012, 07:42 AM   #558
redngreedy
Fan#: 86983
What I Drive: 12' Tuxedo Black Titanium
Points 93, Level 1
Points: 93, Level: 1 Points: 93, Level: 1 Points: 93, Level: 1
Level Up 86% Completed
FF Reputation: 1 redngreedy Good Standing Member
There were 3 seals changed on mine. I can scan the ticket and post if you'd like to see all the parts that were used.
redngreedy is offline
Old 11-20-2012, 10:17 AM   #559
PratoN
PratoN's Avatar
Fan#: 88058
Points 3,018, Level 33
Points: 3,018, Level: 33 Points: 3,018, Level: 33 Points: 3,018, Level: 33
Level Up 79% Completed
Forum Activity 12%
According to the TSB it's 2 halfshaft seal kits, an input shaft seal (inner) and an input shaft seal (outer).
I don't think that they'll necessarily give you visual symptoms as it doesn't take much oil to affect the clutches and there is also a seal on the outside of the bell housing. So there could be a oil just sitting in the bell housing and not leaking, like the OP states in this thread:
http://www.focusfanatics.com/forum/showthread.php?t=302606
So, no - it's not hydraulic tight - but it's also not under hydraulic pressure.
PratoN is offline
Old 11-20-2012, 10:34 AM   #560
FordService
Official Ford Rep
FordService's Avatar
Fan#: 79824
What I Drive: Ford Focus
Points 3,379, Level 36
Points: 3,379, Level: 36 Points: 3,379, Level: 36 Points: 3,379, Level: 36
Level Up 20% Completed
Forum Activity 22%
Activity: 22% Activity: 22% Activity: 22%
Originally Posted by redngreedy View Post
Just got my car back after being in for 5 days. There was a bell housing leak, at least that's what it says. They replaced "various nuts and bolts" along with the seals and clutches.
Before I had this done, if I let off of the brake the car would lurch forward making it a pain in the ass for traffic jams or a drive thru. Now I must give the car gas to make it move, only downfall to this so far is when the clutch engages it literally BOLTS forward. Not sure how this will pan out after the the "break in".
I can tell the trans is a lot better far as shifting at higher rpms. I'll update as improvements/problems come up.
Thanks for the update, redngreedy. I'm glad to hear that your transmission is behaving itself! If you need anything from me, I'm just a PM away.
Thanks again,
Crystal
FORD SERVICE
p: 800.392.FORD
FordService is offline
