rear door won't lock - Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum
Old 06-01-2011, 02:22 AM   #1
bxfocus
Fan#: 86329
What I Drive: 2007 grey sedan se
FF Reputation: 1 bxfocus Good Standing Member
hey guys one of my rear doors (driver side) won't lock anymore. cant move the lock at all either. has this happened to anyone else? anyone know what it might be? I wanted to get some info on what it might be before I take apart the door or bring it to a mechanic. I drive a 07 se sedan. any input would be much appreciated.
bxfocus is offline
Old 06-01-2011, 02:24 AM   #2
mikebontoft
Aurelius Pardus
mikebontoft's Avatar
Fan#: 58647
Points 23,642, Level 94
Points: 23,642, Level: 94 Points: 23,642, Level: 94 Points: 23,642, Level: 94
Level Up 30% Completed
Forum Activity 16%
Activity: 16% Activity: 16% Activity: 16%
sounds like the lock mechanism is bound up. Can it shut and open fine, and you just can't lock it?
mikebontoft is offline
Old 06-01-2011, 02:35 AM   #3
bxfocus
Fan#: 86329
yeah opens and closes fine. just wont lock
bxfocus is offline
Old 06-02-2011, 11:54 AM   #4
07FociSES
07FociSES's Avatar
Fan#: 64860
What I Drive: 2005 Acura EL Premium
FF Reputation: 1 07FociSES Good Standing Member
I had the same thing happen to my car, ford replaced it under warranty. It had something to do with the power locks they told me? Even though I couldn't physically lock it by hand either. If I find the work order I'll let you know whT they replaced.
2007 Ford Focus ZX4 SES (Sold)
2005 Acura EL Premium <3
07FociSES is offline
Old 06-02-2011, 12:39 PM   #5
Sean05
Sean05's Avatar
Fan#: 62491
What I Drive: 13' ST2
Points 1,615, Level 23
Points: 1,615, Level: 23 Points: 1,615, Level: 23 Points: 1,615, Level: 23
Level Up 15% Completed
FF Reputation: 5 Sean05 Good Standing Member
Buy-Sell-Trade Rating: (4)
This exactly happened to me before too. I bought a replacement from the dealer I was working at,
but after a while of spraying with grease. It fixed itself and I returned the part. Try to keep all your doors lubed up (don't use wd-40). Hope it works that part wasn't cheap. Just give it some time if you
Can wait and spray the living $ out of it.
After asking a friend with 07 sedan if he wanted to race " I'm gonna loose! Mines not a zx4!! "
Sean05 is offline
Old 06-02-2011, 10:22 PM   #6
bxfocus
Fan#: 86329
thanks. im going out tomorrow and buying some mechanics grease. hopefully it will work because the last thing i need is to replace an expensive part.
bxfocus is offline
Old 06-04-2011, 10:01 PM   #7
katrmarie
Fan#: 86445
What I Drive: 2007 green zx4
FF Reputation: 1 katrmarie Good Standing Member
same problem
Ok, as of 20 minutes ago, I'm experiencing the exact same problem. As I can't even manually lock the rear door on the driver's side, I did spray with wd-40 as I had it with me.
Does not seem to have worked and I noticed in the post above it said not to use that. If someone could tell me specifically what kind of grease to go get and if i need to take any of the door apart to apply it, I would greatly appreciate it.
katrmarie is offline
Old 06-05-2011, 02:17 PM   #8
Mr.Bergner
coffee, have some
Mr.Bergner's Avatar
Fan#: 32799
What I Drive: 2004 TW Blue ZX3
Points 6,353, Level 52
Points: 6,353, Level: 52 Points: 6,353, Level: 52 Points: 6,353, Level: 52
Level Up 2% Completed
FF Reputation: 53 Mr.Bergner Excellent Standing Member
Buy-Sell-Trade Rating: (12)
I believe lithum grease is what you need.
2004 ZX3 MTX - Twighlight Blue_____________________________________________________________________________ _ _ _ _ _ _
Mr.Bergner is offline
Old 06-07-2011, 07:52 AM   #9
jcjhl69
jcjhl69's Avatar
Fan#: 81550
What I Drive: 2006 Red SES ZX4
FF Reputation: 2 jcjhl69 Good Standing Member
I also have this issue with my 06. Ford issued a recall about this for the 05's but none others. It really makes me mad that they will not expand this recall.
Sedan Revolution Member # 116
2006 Ford Focus ZX4 SES
2009 Ford Flex SEL
jcjhl69 is offline
Old 06-08-2011, 08:01 PM   #10
andysouza3235
andysouza3235's Avatar
Fan#: 78989
What I Drive: 2005 Black ZX4 ST
Points 648, Level 12
Points: 648, Level: 12 Points: 648, Level: 12 Points: 648, Level: 12
Level Up 96% Completed
FF Reputation: 1 andysouza3235 Good Standing Member
That same thing happened to me not too long ago. I took the lock apart and it looked fine and wasn't stuck. I noticed, however, that the gears weren't quite in range for it to work. (Its one of those things that's too hard to explain without showing you.) Anyways, I think its kinda like how they have the reset procedure to recalibrate the sunroof because after a while it gets out of whack. After a long time of accumulated errors it just isn't in the right place anymore. So I just played around with it to find where I thought the gears should be and put it back together. Its been probably 6 months and it hasn't happened since.
andysouza3235 is offline
