do I need alignment after changing struts? - Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum
Old 05-30-2011, 01:00 PM   #1
tryingtoregister
Fan#: 59099
What I Drive: 2002 gray ZX3
FF Reputation: 1 tryingtoregister Good Standing Member
Hi, I just changed my struts. Do I need to take it for re-alignment?
thanks.
username came out like that after many attempts
tryingtoregister is offline
Old 05-30-2011, 01:15 PM   #2
jetrinka
jetrinka's Avatar
Fan#: 45622
What I Drive: 88 5-speed XR4TI
FF Reputation: 180 jetrinka Excellent Standing Member jetrinka Excellent Standing Member
Buy-Sell-Trade Rating: (6)
Yes its a good idea to get an alignment done.
jetrinka is offline
Old 05-30-2011, 03:24 PM   #3
forddorf
Fan#: 31248
What I Drive: 2001 malibu blue zx3 / turbo-2004
Points 925, Level 16
Points: 925, Level: 16 Points: 925, Level: 16 Points: 925, Level: 16
Level Up 25% Completed
Level up: 25% Level up: 25% Level up: 25%
FF Reputation: 3 forddorf Good Standing Member
I vote no.
forddorf is offline
Old 05-30-2011, 03:36 PM   #4
Djzx3
WRX/Focus:)
Djzx3's Avatar
Fan#: 76864
What I Drive: 04 WRB WRX / 00 se zxw
Points 14,826, Level 78
Points: 14,826, Level: 78 Points: 14,826, Level: 78 Points: 14,826, Level: 78
Level Up 94% Completed
FF Reputation: 33 Djzx3 Great Standing Member
I want to know why you think no, but I think I agree, because there is no need to remove the tie rod arm. just undo the pinch bolt, hit the knuckle down, and undo the three at top.
O and undo the sway bar link. So I vote no too, unless your lowering?
2000 SE wagon 2.0l Zetec.
HN #17
D23 crew-#1
Djzx3 is offline
Old 05-30-2011, 03:42 PM   #5
jetrinka
jetrinka's Avatar
Fan#: 45622
Changing just the struts out you are correct in the fact that nothing alignment wise is typically disturbed assuming the upper strut mount is put back in in the same position it was before. Or if you are replacing the strut mount. If the old one was damage in any way and either replaced or put in in a different way than what it was the camber numbers can change. This is especially apparent if the bushing is torn.
Lowering is a different animal. Lowering the car will change your camber numbers which will in turn change the toe of the vehicle. You can adjust toe without affecting camber/caster but you cannot adjust camber or caster without affecting the toe. Thats why when doing an alignment toe is always adjusted last.
jetrinka is offline
Old 05-31-2011, 10:27 AM   #6
tryingtoregister
Fan#: 59099
Hi, I want to thank jetrinka, forddorf, and Djzx3 for their replies.
I did not lower the car, just replaced the struts. But I replaced the whole assembly, so the mount may not be exactly the same? and thus needs re-alignment?
Thanks in advance
Old 05-31-2011, 10:36 AM   #7
ChrisRobin
ChrisRobin's Avatar
Fan#: 46204
What I Drive: 04 silver SVT Focus
Points 6,804, Level 54
Points: 6,804, Level: 54 Points: 6,804, Level: 54 Points: 6,804, Level: 54
Level Up 27% Completed
FF Reputation: 4 ChrisRobin Good Standing Member
You shouldn't need an alignment for just swapping out the same strut/spring.
Originally Posted by WRCwannabe View Post
...and then slap a supercharger on it and rape their tits off.
ChrisRobin is online now
Old 05-31-2011, 01:41 PM   #8
euro-bred
euro-bred's Avatar
Fan#: 30047
What I Drive: 04 2.3 zx3
Points 1,736, Level 24
Points: 1,736, Level: 24 Points: 1,736, Level: 24 Points: 1,736, Level: 24
Level Up 36% Completed
FF Reputation: 10 euro-bred Great Standing Member
Buy-Sell-Trade Rating: (4)
You will need an alignment, I know from experience.
As little of a change that you are doing to your suspension, the struts will not settle into the same exact position that they were in before.
Posted via FF Mobile
euro-bred is offline
Old 05-31-2011, 08:23 PM   #9
forddorf
Fan#: 31248
You should not need an alignment. You are not changing anything that changes the setting. The struts do not hold the car up the spring do that job.
forddorf is offline
Old 05-31-2011, 08:41 PM   #10
drjkel
Fan#: 34025
What I Drive: 2001 Amazon Green ZTS, 2012 SE Seda
FF Reputation: 9 drjkel Good Standing Member
Some people get lucky on just a strut change. Some don't. It's really best to check with an alignment. I wasn't lucky and it cost me a new Michelin tire. Cost of the alignment I should have had done: $79.95. Cost of purchasing, mounting and balancing the new Michelin: $120.
drjkel is offline
