ECU Tuning Chat Discuss performance tuning options for your Ford Focus.
#1 | ||||
SCT x3 Tune errors! HELP!
SCT X3 Error Codes: 1039, 1009, 1016
I bought my pre-loaded SCT x3 flasher about a week ago and when I tried connecting it to the computer, it wouldn't connect even with drivers working and everything. I checked the versions of the firmware and tunes and stuff, all up to date. When I go to tune the car, it "uploads" a tune, after thats done, it says something about storage. After that, it says it's downloading the tune, then it downloads a tune? i then get the error code 1039 and says failed to tune and if i can't start the car then i have to return it to stock. After that message, i get the error code 1009 and it says that there is no tune changes written. When i go to return it to stock, it finishes but gives me an error 1016 and says program tune failed. It's only after the second try to put in the stock file that it works. Anybody experience this? can anybody help? SCT is closed for the memorial weekend and isn't open till tues.
SoCal Crew #221 Fiesta SE Oxford White |
Remove Advertisements |
Fan#: 1
#2 | ||||
FF Affiliate
Contacting SCT is going to be your best bet
Focus-Power: Your #1 Source for Ford Focus Speed, Tuning & Performance! Customer Support AIM: hpdyno Email: tom@focus-power.com Phone: 704-249-3745 Site: focus-power.com Elder 1turbofocus |
#3 | ||||
The error is 1034 download failed, not 1039.
List the firmware and tune revision that is currently on your device as read from the device info screen on the device. You have an SVT which has always been problematic flashing. Some vehicles are worse than others. Some never have a problem while others do. |
#4 | ||||
I had a similar problem when I 1st got my xcal2. You might try this. Wet a qtip with isopropol(sp?) alcohol and gently clean the contacts on your tuner. Just a little bit to get any protectant off the contacts. Don't go nuts. A small eraser also works. Luck!
Steeda SRI w/CAI intake. Trubendz SS 2.5" . FR Susp/Struts. Tune by Tom (FocusPower). Rota Grids. SAP rear spoiler. Custom front air dam, rocker panel bits and Rear valance. Last of the Hatches #28 |
#5 | ||||
Dang...thanks for the replies. I don't if I should try again because it usually fails the first time trying to bring it back to stock and what if I can't get it back to stock another time? Is it the car or the device?
Posted via FF Mobile |
#6 | ||||
Well. Don't know. there is a coating on electrical connectors (usually) to prevent corrosion while there on the shelf. It is very light and is supposed to scrape off on insertion. Sometimes it doesn't quite scrape off well enough. That is what happened to me. Little alcohol cleans it right off though.
#7 | ||||
**UPDATE**
I was able to connect the device to an older computer with a Windows XP operating system and turns out there are TWO drivers that are supposed to be installed. My laptop (which runs Windows 7) didn't have one. I called SCT and they told me that it somehow "glitched" and didn't install one of the drivers. I reinstalled everything and now it works. For those who have trouble connecting the device to their computer, the names of the drivers are SCT Driver V10.11 (or whatever the latest version is I assume) and X3PDEVICE (or whatever device you have, I assume). I got the car tuned with the pre-loaded strategy tune, but I'm not liking it, contemplating a custom tune. Thanks for the input everyone!
#8 | ||||
FF Affiliate
A custom tune is always best , I never send out the scal with the pre loaded tunes always custom tuning and with FREE updates
#9 | ||||
I've returned the car to stock, after trying to 20 times...and I'm not exaggerating. It kept failing and giving me a error code 1016. I'm really considering a custom tune but I'm having such a hard time with this device it's a bit daunting.
#10 | ||||
What firmware revision is currently on your device?
| Thread Tools | |
| Display Modes | |
