Power source... which fuses do you use? - Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum
Old 09-25-2004, 01:12 AM   #1
rompin2.0focus
Fan#: 7208
Points 3,161, Level 34
Points: 3,161, Level: 34 Points: 3,161, Level: 34 Points: 3,161, Level: 34
Level Up 74% Completed
FF Reputation: 1 rompin2.0focus Good Standing Member
For all of you that have gauges, lights in your vents, stereo systems, and etc.., where do you get your power from?
Do you use the fuses from the fuse box, and which ones? or do you have an auxilary fuse block that you use? IN SHORT, WHERE DO YOU GET YOUR POWER FROM WITH ALL THESE THINGS HOOKED UP, WITHOUT DRAINING THE BATTERY OR OVERLOADING FUSES?
rompin2.0focus is offline
Old 09-25-2004, 01:21 AM   #2
JensDOHC
JensDOHC's Avatar
Fan#: 12883
What I Drive: 2001 sedan bumble bee!!!
FF Reputation: 1 JensDOHC Good Standing Member
most neon lighting doesnt use THAT much power..youd be surprised...
as for stereo systems...deep cycle batteries are good. if not a second battery. yes, with high wattage goin fuse holders for ANL fuses are helpful..with 100-300 amp fuses. my friend for example has 4 fuse holders..each hold 2 fuses..and he is using 250 amp fuses.(of course hes got 2 3600 watt high current amps running) line drivers help. bigger alternators. there are lots of ways to squeeze more power out.
Strictly Focused-PA!
:insert humorous and witty saying or quote here:
JensDOHC is offline
Old 09-25-2004, 02:09 AM   #3
rompin2.0focus
Fan#: 7208
I'm not really wanting much, just to hook up a couple gauges, some neons inside the car in the footwells, and some security things. What do you suggest?
Old 09-25-2004, 02:34 AM   #4
JensDOHC
JensDOHC's Avatar
Fan#: 12883
i would say you would be fine with just your battery..but if you are really worried about it..get a deep cycle battery..like an optima. they have a reserve power source. though..unless you are running all this stuff without your car being on and charging...you really shouldnt have a problem
JensDOHC is offline
Old 09-25-2004, 09:40 AM   #5
FocuzdZX5
FocuzdZX5's Avatar
Fan#: 7906
What I Drive: '01 CD Silver ZX3(mine) '04 Light Tundra ZX5(wifes)
FF Reputation: 1 FocuzdZX5 Good Standing Member
Just go thru the fuse box. If you have a multimeter check the empty slots and see if any are hot. then buy some of and mabe these , if there is no fuse on what your adding. Just plug into the empty hot slot and run a ground.
I wouldn't worry about draining the battery, unless you are going to have everything on at once with the car off. Nothing you mentioned should put put too much a draw on it unless something is wrong.
Current Mods - NONE -
Had - AEM cai, Eibach Dampers/Sportline springs, FC Knobs, 98 Edition Euro Bumper, FC TB, FS strut bar, FC wire cover, FR plug wires, Eibach Sways(frt/rr), FC header, bosal flex, Borla 2.5 cat back.
Long tyme no post!
origanal FF #: 2221
e-mail frostyj@cox.net
FocuzdZX5 is offline
Old 09-25-2004, 12:38 PM   #6
rompin2.0focus
Fan#: 7208
alright, thanks fellas
Old 09-25-2004, 12:46 PM   #7
rompin2.0focus
Fan#: 7208
oh i forgot something
FocuzdZX5 what if the empty slots aren't hot, then what do I use?
Old 09-25-2004, 03:40 PM   #8
focus4dr
focus4dr's Avatar
Fan#: 8489
What I Drive: 2004 Torch Red Mustang GT (40th Annaversery Edition)
FF Reputation: 1 focus4dr Good Standing Member
Buy-Sell-Trade Rating: (4)
I found something at PEP Boys.. its a fuse block that holds only 5 fuses, you could mount that someplace under your hood for extra fuses if needed... hook the power up to one side, and run a jumper to the rest of them... then as you need something, pop a fuse in and run a wire for it.
2004 Ford Mustang GT Torch Red
Mods:
Steeda: 2.25" stainless steel exhaust, UDP's, Dragon plenum, and CAI.
focus4dr is offline
Old 09-25-2004, 03:46 PM   #9
sitlet
Fan#: 970
What I Drive: 2001 Focus ZX3
FF Reputation: 1 sitlet Good Standing Member
go to autozone or another parts store and get a couple "ATO add-a-circuit". you remove an existing fuse, plug this in, then add two fuses, one for the fuse you took out, and one for the new accessory. this is the best way to do it.
sitlet is offline
Old 09-25-2004, 06:31 PM   #10
rompin2.0focus
Fan#: 7208
these are very inconvient for multiple hookups though... they won't work for all the things I want to hook up, plus they get in the way of other fuses i need to use... just my opinion - don't work for me
Similar Threads
Power Mirrors On a Non Power Mirror Fo-Mo-focus norcalfocus01 MK1 Interior Mods & Upgrades 4 09-07-2009 11:46 AM
))imprint(( Sk3letor Car Audio, SYNC, MyFord Touch & Electronics 4 06-22-2009 11:25 PM
Reoccurring Power steering issues (advice, anyone?) Aqua12632 General Technical Chat 4 12-13-2006 05:21 PM
New Volkswagen Rabbit!! nomoreavril Ford Focus & General Car Chat 30 06-29-2006 12:55 PM
Need an inside switched power source onebluemcm MK1 Interior Mods & Upgrades 4 11-30-2004 11:19 PM
