'00 ZTS, ABS and Parking brake light on - Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum
Old 05-24-2011, 04:40 PM   #1
iagei
iagei's Avatar
Fan#: 73058
What I Drive: '00 ZTS Sedan 5MT Zetec
FF Reputation: 1 iagei Good Standing Member
I just bought an '00 ZTS sedan today (MTX) and the ABS and Parking brake lights are on. Seller says it's just a sensor, and I'm inclined to believe him since the car stops fine.
Low fluid? Bad ABS sensor?
iagei is offline
Old 05-24-2011, 05:28 PM   #2
B3NN3TT
B3NN3TT's Avatar
Fan#: 64245
What I Drive: 2003 CD Silver SVT
Points 1,282, Level 19
Points: 1,282, Level: 19 Points: 1,282, Level: 19 Points: 1,282, Level: 19
Level Up 82% Completed
FF Reputation: 2 B3NN3TT Good Standing Member
Check the fluid level closely. Red lights on the dashboard mean GIVE ATTENTION NOW.
The ABS light could be from a dirty or broken wheel sensor, broken reluctor ring on the axle or hub, or an electrical problem.
2003 SVT #2370 Hatch Nation #91 2000 Roush Cougar 2008 Mustang Bullitt #5389 2013 Fiat 500 Abarth
B3NN3TT is offline
Old 05-24-2011, 05:40 PM   #3
iagei
iagei's Avatar
Fan#: 73058
....are any of those hard?
I feel nothing odd in the pedal, and it stops fine. Literally, nothing in the pedal to suggest otherwise.
iagei is offline
Old 05-24-2011, 06:43 PM   #4
iagei
iagei's Avatar
Fan#: 73058
Is there any way to find out which/if what sensor failed? I can't find anyone who rents out a scan tool.
iagei is offline
Old 05-24-2011, 08:05 PM   #5
B3NN3TT
B3NN3TT's Avatar
Fan#: 64245
A lot of times you can just pop them out of the hub and visually inspect them. If they have a lot of dust or grit on them, they won't read correctly. They are magnetic, so they attract iron filings and such. Likewise the reluctor rings on the axles/hubs; they need to be clean and free of any dirt, grit, or chips in the teeth.
I would start there.
B3NN3TT is offline
Old 05-24-2011, 11:10 PM   #6
iagei
iagei's Avatar
Fan#: 73058
What do the sensors look like? (I should probably buy a Haynes manual, huh)
iagei is offline
Old 05-25-2011, 12:15 AM   #7
jetrinka
jetrinka's Avatar
Fan#: 45622
What I Drive: 88 5-speed XR4TI
FF Reputation: 180 jetrinka Excellent Standing Member jetrinka Excellent Standing Member
Buy-Sell-Trade Rating: (6)
Have you checked the fluid level yet? Low fluid can cause both a red brake light and ABS light.
jetrinka is offline
Old 05-25-2011, 10:18 AM   #8
iagei
iagei's Avatar
Fan#: 73058
Fluid level is fine......
iagei is offline
Old 05-25-2011, 10:30 AM   #9
nilskje
Fan#: 11478
What I Drive: Focus -04 5door 1,6 Ghia
Points 460, Level 9
Points: 460, Level: 9 Points: 460, Level: 9 Points: 460, Level: 9
Level Up 20% Completed
FF Reputation: 17 nilskje Great Standing Member
A disabled ABS system will also give both lights on, (disables itself when it cant find all wheelsensors, and also if it lacks +12v, chk fuses). For the sensors I strongly recommend doing a scan of the errorcodes, to make life a bit simpler. Car will stop just fine with the ABS system inop, but will not help you when its slippery and you hammer the brakes...
nilskje is offline
Old 05-25-2011, 04:40 PM   #10
B3NN3TT
B3NN3TT's Avatar
Fan#: 64245
Haynes manual would help, but you can follow the electrical wires down to the wheel hubs and locate them pretty easily. They are held in by one tiny bolt, usually.
B3NN3TT is offline
