Go Back   Focus Fanatics > Model Specific Discussions > MK3 Focus
Old 11-17-2011, 10:40 AM   #31
fortresspainting
Fan#: 91881
What I Drive: 2012 Race Red SEL
FF Reputation: 1 fortresspainting Good Standing Member
Different module
Originally Posted by RallyGuy66 View Post
Have dealer hook up ids and activate modual. Some fords you can do this, not sure on focus. worth a try
Somethings not adding up here: two Ford dealers have been unable to activate the DRLs. They claim the US made 2012 Focus has a different module that cannot be programmed for DRL.
It's all become very confusing. I find it hard to believe Ford could be bothered to put different modules in Canadian cars than for the rest of the world. Especially on this car which they are trying to bill as an international platform.
I wonder if anyone has a 2012 Focus and taken to have the DRLs turned on - perhaps there is someone who knows how they did it.
fortresspainting is offline
Old 11-17-2011, 01:32 PM   #32
fatfocus
fatfocus's Avatar
Fan#: 90985
What I Drive: 2012 Frosted Glass SEL Sedan
FF Reputation: 1 fatfocus Good Standing Member
Originally Posted by cobie56 View Post
I'm not sure why the dealer said they weren't avail. I had the dealer activate mine tho i'm not sure they did it correctly... The h'lights do go on but so do all the other lights, side marker, licence plate, tail lights, etc.
Is this normal??!! It doesn't seem right to me.
I live very close to canada and the canadian fords (all of them) have DRLs by law and ONLY the h'lights are on... no other lights.
Any opinions? thnx
Drive up to the Great White North, find a Ford store, buy the parts, find a Canadian who is smart enough to own a Focus.......buy them a beer or lunch, see where the parts go. I'm sure the stuff is all ready to be install, just need a module...
Now: 2012 SEL Sedan, with Selectshift Transmission, 17" Polished Aluminum Rims, K&N Air Filter
Previously: 2000 White ZTS, 15" Painted Aluminium Rims
www.focuscanada.net member
fatfocus is offline
Old 11-17-2011, 01:51 PM   #33
Macsleuth
Fan#: 90432
What I Drive: 2012 Stirling Grey Focus Titanium
FF Reputation: 1 Macsleuth Good Standing Member
beer and poutine and I'm good to go eh!
Macsleuth is offline
Old 11-17-2011, 01:55 PM   #34
cobie56
Fan#: 84403
What I Drive: '01 ZX3, '07 Civic '12 SEL
Surry's not all that far from the border.. just cross over to a u.s. ford dealer and have them do it..
cobie56 is offline
Old 11-17-2011, 02:07 PM   #35
e350 coupe
Fan#: 84808
What I Drive: 2010 E-350 Coupe/2012 Titanium Htbk
FF Reputation: 5 e350 coupe Good Standing Member
Wow he's trying to activate DRL's and I am trying to deactivate mine
e350 coupe is offline
Old 11-17-2011, 02:12 PM   #36
DarinS
Fan#: 88257
What I Drive: 2012 Titanium hatch, BMW E30 335iC
FF Reputation: 1 DarinS Good Standing Member
Any chance something like the Phillips LED DRL system would void the factory warranty?
DarinS is offline
Old 11-17-2011, 08:29 PM   #37
bkoester
Fan#: 53453
What I Drive: 2012 Race Red SEL Sedan
FF Reputation: 1 bkoester Good Standing Member
Originally Posted by fortresspainting View Post
I just purchased a US 2012 Focus and imported it to Canada. Federal law up here requires daytime running lights or you cannot register/insure the car.
I knew this beforehand, so I asked the dealer to look at the car and see if they could activate the DRL - they were unable to do so. No exact reason was given except that they contacted Ford and were told it was not possible.
I imported the car and took it to my dealer for the same reason - activate the DRLs: they initially claimed it was a setting in the car's computer and it would be no problem.
They tried for about an hour to figure it out - called Ford - and were told the software set-up was different on US cars and DRLs could not be activated.
Now, I am forced to go with an aftermarket option.
None too happy about this. Anyone out there have a similar experience. I am not convinced that they cannot be activated. This is primarily because I don't feel I've been given a reasonable explanation as to why they cannot turn them on.
Hard to believe as DRLs are a fleet option in the US.
2012 Race Red SEL Sedan with MFT
Picked up 10-13-11
bkoester is offline
Old 12-03-2011, 04:49 PM   #38
fortresspainting
Fan#: 91881
The final answer on this (from Ford) is that the module for DRLs was not put into my car. Apparently, it is put into other cars (such as the Focus SE - mine is the Focus SEL). I was told the module may become available in 9 months or so.
I was able to purchase an aftermarket device. This particular module had instructions to connect into the low-beam lamp wire, high-beam lamp wire, and parking light lamp wire on one side of the car. I took the lamp assembly off and could see that this was not going to be so simple as the unit was designed for lamps that are combination high/low beam units.
I decided I did not want to touch the high-beam lamp on this car at all: so, I wired the low beam into the low beam on the left side, the parking lamp wire I extended to the low beam on the right, tested it, and it works. In terms of power, I ran a power and ground wire as described and used a piggy-back fuse link wire off the fuel-relay fuse for the accessory power feed. This meant there was no splicing required.
Now, this was enough to get me past the government inspection and I received the RIV sticker which says my car is up to Canadian standards (i.e. DRLs required by law).
This is a brief description of the fix - if anyone wants more detail, I'd be happy to provide that.
Old 12-03-2011, 05:17 PM   #39
e350 coupe
Fan#: 84808
I sent you a pm
Old 12-31-2011, 06:20 PM   #40
Mayonaze
Fan#: 92949
What I Drive: 2012 Frosted Glass SEL HBack DCT
FF Reputation: 1 Mayonaze Good Standing Member
There is a company called Echo Master that just released an LED DRL kit for the 2012 Focus. I went to their website and it says that they're already shipping. I sent them an email to find out where to purchase them. They also have step by step instructions with pictures on how to install. Look pretty easy but I do not know how much the kit costs.
Mayonaze is offline
