Go Back   Focus Fanatics > Model Specific Discussions > MK3 Focus
Old 05-25-2011, 05:53 PM   #21
DanGG
Fan#: 86035
What I Drive: 1998 tan chevy Prizm
FF Reputation: 1 DanGG Good Standing Member
The SJB is the Smart Junction Box.
DanGG is offline
Old 05-25-2011, 07:09 PM   #22
Tony407
Tony407's Avatar
Fan#: 85289
What I Drive: 2012 Sterling Gray Hatch Titanium
FF Reputation: 4 Tony407 Good Standing Member
Originally Posted by DanGG View Post
Great! Where do you get them? How hard are they to install?
carbulbsdirect.com They're in Europe, but the shipping was surprisingly fast - and free I might add.
Install wasn't too bad, but I wouldn't call it easy. Time consuming is more like it. But only because I had to keep trimming the plastic in the grill until they fit "just right". And the bracket they are supposed to be mounted in wouldn't fit so I used 3M double sided tape on both the top and bottom of the housing so they wouldn't go anywhere. Wiring was easy, although I haven't hooked up the wire to switch them off when the lights come on yet, but I can't imagine it will be that hard.
The easiest place to have installed them would have been right below the blue Ford oval, spaced as far apart as possible. But I didn't like the way they looked there. But the install would have been about a quarter of the time.
Tony
Tony407 is offline
Old 06-12-2011, 08:51 PM   #23
cobie56
Fan#: 84403
What I Drive: '01 ZX3, '07 Civic '12 SEL
DRLs ARE available on foci and most other fords.. I had the dealer turn my on at delivery. Ford's owner's manual says they work at 'reduced light' but to me they seem full power.
anyone w/ another opinion?
cobie56 is offline
Old 06-12-2011, 08:58 PM   #24
Josh321
Fan#: 85263
What I Drive: 2012 Focus Titanium 5-door
FF Reputation: 1 Josh321 Good Standing Member
What do you mean "turn them on"? What did they do to activate them? Did your car have them listed as an option on the window sticker? They are listed as an option on the full options list, so I tried to order them, but I was told they were only available for fleet orders.
Josh321 is offline
Old 07-10-2011, 07:51 PM   #25
cobie56
Fan#: 84403
I'm not sure why the dealer said they weren't avail. I had the dealer activate mine tho i'm not sure they did it correctly... The h'lights do go on but so do all the other lights, side marker, licence plate, tail lights, etc.
Is this normal??!! It doesn't seem right to me.
I live very close to canada and the canadian fords (all of them) have DRLs by law and ONLY the h'lights are on... no other lights.
Any opinions? thnx
cobie56 is offline
Old 07-10-2011, 09:23 PM   #26
Josh321
Fan#: 85263
Any opinions? thnx
I asked for my dealer to "activate" them, and this was exactly the result. I later learned that all of the interior lights (switch backlights, essentially) are always lit, but my when my dealer supposedly turned on the DRL's, I had all exterior lights on at all times--and I couldn't turn the fog lights on or the headlights off (as long as the engine was running). NOT DRL's.
I later installed the Philips DRL's and have been very happy with them.
Josh321 is offline
Old 07-11-2011, 07:48 PM   #27
cobie56
Fan#: 84403
the owner's manual (and other sources )say that the DRLs can be activated
which i had done but nowhere does it say all my lights are on all the time..which doesn't seem correct.
All my exterior lights are on , including the license plate light, when the car is running.
Whats really odd is that fords in canada where DRLs are mandatory and standard have ONLY the headlights on... no other lights.
As well, the manual says the lights are on at reduced power however when, in the dark, i switch from DRLs to reg. headlights i see no difference so i say the DRL headlights are on full power all the time.
To my thinking DRLs should be headlights only not the other lights...What's ur opinion or experience?
cobie56 is offline
Old 11-17-2011, 07:43 AM   #28
fortresspainting
Fan#: 91881
What I Drive: 2012 Race Red SEL
FF Reputation: 1 fortresspainting Good Standing Member
I just purchased a US 2012 Focus and imported it to Canada. Federal law up here requires daytime running lights or you cannot register/insure the car.
I knew this beforehand, so I asked the dealer to look at the car and see if they could activate the DRL - they were unable to do so. No exact reason was given except that they contacted Ford and were told it was not possible.
I imported the car and took it to my dealer for the same reason - activate the DRLs: they initially claimed it was a setting in the car's computer and it would be no problem.
They tried for about an hour to figure it out - called Ford - and were told the software set-up was different on US cars and DRLs could not be activated.
Now, I am forced to go with an aftermarket option.
None too happy about this. Anyone out there have a similar experience. I am not convinced that they cannot be activated. This is primarily because I don't feel I've been given a reasonable explanation as to why they cannot turn them on.
fortresspainting is offline
Old 11-17-2011, 08:39 AM   #29
e350 coupe
Fan#: 84808
What I Drive: 2010 E-350 Coupe/2012 Titanium Htbk
FF Reputation: 5 e350 coupe Good Standing Member
What dealer are you going to. It has been done by other forum members in the US. I would try a different dealer such as WhiteRock Ford.
If you got to the "DRL site" even they state the 2012 DRL is computer programable for on or off
http://www.lightsout.org/disable.html#Ford
Ford
2012+ models. It appears that DRLs are a configurable option on the vehicle's computer. A Ford dealer should be able to connect to the OBD port on the vehicle and disable the DRLs. The aftermarket may also have tuners that can connect to the computer with the ability to disable DRLs.
e350 coupe is offline
Old 11-17-2011, 08:50 AM   #30
RallyGuy66
Fan#: 91825
What I Drive: 2012, Race Red Focus Se Sport 5spd
FF Reputation: 1 RallyGuy66 Good Standing Member
Have dealer hook up ids and activate modual. Some fords you can do this, not sure on focus. worth a try
RallyGuy66 is offline
