Daytime running lights (DRL) - Page 18 - Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum
Old 04-27-2013, 08:05 AM   #171
dbsimms63
Fan#: 110359
What I Drive: 2013 Performance Blue Titanium 5dr
Points 1,715, Level 24
Points: 1,715, Level: 24 Points: 1,715, Level: 24 Points: 1,715, Level: 24
Level Up 15% Completed
Forum Activity 2%
FF Reputation: 2 dbsimms63 Good Standing Member
Originally Posted by newmission View Post
Thanks to Shade-10's suggestion! I used the switched female terminal located in the fusebox by the battery. Crimped on a standard size spade lug and plugged it in! Simple as pie.
So here's mine! Hasn't anyone else thought of these? I came across some prepackaged side pointing SMD LEDs at Wallyworld, and the wheels started to spin. So I dug some up on eBay for fractions of the price. What do you think?
They just stick on, and run the length of your headlight.
Once the headlight is installed, no one even know they are there!
Look pretty good with the headlights on too.
That's a good work around. How did you attached them to the bottom of the headlight? Got a link to the Ebay seller?
dbsimms63 is offline
Old 04-27-2013, 12:45 PM   #172
dbsimms63
Fan#: 110359
Forum Activity 2%
Would it happen to be like these: http://www.ebay.com/itm/220800067664...664%26_rdc%3D1
Old 04-27-2013, 02:03 PM   #173
reh8388
Fan#: 104886
What I Drive: 2013 Ford Focus Titanium 4dr
Points 230, Level 4
Points: 230, Level: 4 Points: 230, Level: 4 Points: 230, Level: 4
Level Up 60% Completed
FF Reputation: 1 reh8388 Good Standing Member
How about an evening no headlights sexy shot?
Looks awesome. Would it be possible to get a similar photo but during the day. I want to get an idea of how bright they are at distance in the daylight.
reh8388 is offline
Old 04-27-2013, 04:26 PM   #174
newmission
newmission's Avatar
Fan#: 84688
What I Drive: YB-MK3-MTX-SE-OG Sport-HB
FF Reputation: 5 newmission Good Standing Member
Originally Posted by dbsimms63 View Post
No. The ones I purchased were from a US seller and were 60 side mounting SMD LEDs on 24". I went back to look for more, and they were sold out already. But I'm sure they are similar.
I'll try to grab a shot soon. They aren't super bright in direct daylight since there is no reflector assembly. But I didn't want anything bulky to begin with. So they fit the bill.
Hatch Nation #110
Debadge-and Drive Naked
Home of the Free Blacked Out Grille Mod, and Griffin Ram Air Mod.
Get you some!
newmission is offline
Old 04-27-2013, 04:27 PM   #175
newmission
newmission's Avatar
Fan#: 84688
They just stick right on with some double sided 3M tape that was already applied.
Hatch Nation #110
Get you some!
Old 04-27-2013, 08:32 PM   #176
dbsimms63
Fan#: 110359
Forum Activity 2%
Yeah I didn't know how to make heads or tails out of the description, just that they are 47.2", can be cut at every 3rd LED, use 12v, and have self adhesive applied. Didn't know what they meant by 60LEDs SMD 335 Side-emitting LED Flexible Strip? Does it sound similar to what you used? These are $21, how much did you pay?
Old 04-27-2013, 09:59 PM   #177
newmission
newmission's Avatar
Fan#: 84688
You want a 24 inch section. You will only use about 20". However here is the clincher. The reason you want two 24 inch pieces is that they will be wired on both ends. Now think left and right headlight assemblies. You need to cut one to be a left hand wired strip, and the other a right hand wired strip. Make sense? I actually have two 4 inch strips leftover that I was thinking about wiring up inside the cargo area. Or inside of a door jam pointing towards the ground when the door is opened. etc etc....
I paid $17 shipped for two 24 inch 60 LED strips. Make sure the LEDs are close together. Unless you want a more separated look.
Have fun!
Hatch Nation #110
Get you some!
Old 05-01-2013, 12:34 PM   #178
jdubhack
I WILL correct you.
jdubhack's Avatar
Fan#: 103056
What I Drive: 2014 SGM Fusion Ti
Points 9,323, Level 64
Points: 9,323, Level: 64 Points: 9,323, Level: 64 Points: 9,323, Level: 64
Level Up 91% Completed
FF Reputation: 37 jdubhack Great Standing Member
Buy-Sell-Trade Rating: (12)
A write-up for ST3 reproduction headlights including DRLs:
http://www.focusfanatics.com/forum/s...=1#post4708552
<>< Gal. 6:14
April 2013 HOTM
2013 Ford Fun Weekend: Show Class Winner
jdubhack is offline
Old 09-07-2013, 01:45 AM   #179
joe8282
joe8282's Avatar
Fan#: 117806
What I Drive: 2014 Ruby Red Tinted Clearcoat SE
Points 257, Level 5
Points: 257, Level: 5 Points: 257, Level: 5 Points: 257, Level: 5
Level Up 14% Completed
FF Reputation: 2 joe8282 Good Standing Member
Drl
Just recently had PIAA DRL LEDs installed on my daughter's SE 2014 Focus. I bought them from CarToys and very satisfied how they turned out. Since she has the headllight switch on auto they come on when she turns the car on. When it starts to get dark and the headlights come on the DRL turn off. Also had the headlight blubs replaced with PIAA Xtreme white plus. Next the fog lamps.
joe8282 is offline
Old 09-07-2013, 09:51 AM   #180
Gi_Jo_Nathan
Gi_Jo_Nathan's Avatar
Fan#: 98931
What I Drive: 2012 Sonic Blue 5Door MTX
Points 368, Level 7
Points: 368, Level: 7 Points: 368, Level: 7 Points: 368, Level: 7
Level Up 36% Completed
FF Reputation: 3 Gi_Jo_Nathan Good Standing Member
Nice. I like that they work like they're supposed to.
Did you install them or someone else?
Jonathan
12 SE HB MTX, IE Tuned, Snorkel DLT, Green Filter(Gray), custom 2.5" cat-back w/borla, Steeda RSB & Short Shift Bracket, JBR Solid Shifter Bushing's, MS3 RMM w/Corksport Inserts, Ti Heads, Redline Tuning Hood Struts, De-chromed
Gi_Jo_Nathan is offline
