Question about Titanium Handling Package - Page 3 - Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum
Old 05-24-2011, 11:50 AM   #21
chrisdh79
Fan#: 85037
What I Drive: 2012 Ford Focus Titanium Sedan
FF Reputation: 1 chrisdh79 Good Standing Member
I have a titanium with handling package. The 18" wheels look great, and the very tight suspension makes making turns at high speed a breeze. I never test drove a car without the sport suspension, and honestly I wouldnt want to try now, after experiencing what I own.
chrisdh79 is offline
Old 05-25-2011, 09:44 AM   #22
cappa
cappa's Avatar
Fan#: 85229
What I Drive: 2000 VW Golf / 2012 Ford Focus Ti
FF Reputation: 1 cappa Good Standing Member
thank you for the list timinac
cappa is offline
Old 05-25-2011, 03:00 PM   #23
timinac
Fan#: 84542
What I Drive: 2013 Focus ST3 Performance Blue
FF Reputation: 1 timinac Good Standing Member
No problem. I hope it helps someone in some way. Anyway, I found it interesting and more than a little surprising (assuming I didn't miss something on the Etis lists). I expected the SE and SEL to use the same suspension, but I previously thought the S also used the same springs and shocks. Instead, the S uses different springs. I completely did not expect the SE Sport to use a mix of the S and SE/SEL springs, and expected the SE Sport and the Titanium to use the same parts. Instead, the Titanium uses the same springs as the SE/SEL with only the shocks being different. I also expected the Titanium with the 18" wheel package to use unique shocks and springs, not use SE/SEL rear springs. Fordparts.com shows "MD" rear springs listed, but for some reason Etis doesn't show them being used. Who knows?
timinac is offline
Old 06-04-2012, 09:29 AM   #24
cappa
cappa's Avatar
Fan#: 85229
Originally Posted by Tony407 View Post
Look at what you get for a mere $600:
Sport tuned suspension.
18-inch wheels.
Michelin Pilot Sport PS3 tires.
The value is INCREDIBLE. On Tirerack, the tires alone are about $300 each.
One thing I noticed is that the recommended tire pressure for the PS3s is 39 psi. 39 PSI!!! I could feel every bump in the road. I've got them at 32 psi now and I'm much happier.
Tony
my tpms sensor went off this morning... the ones on the right were at 30 psi and the ones on the left were at 20 psi. I put air in them and put it at 45 psi(max tire is 50 psi) will this be an issue anyone thinks?
cappa is offline
Old 06-04-2012, 10:00 AM   #25
lscrx
Fan#: 41668
What I Drive: 2012 Focus SE hatch 5mt
FF Reputation: 2 lscrx Good Standing Member
Why would you overinflate your tires like that?
Posted via FF Mobile
lscrx is offline
Old 06-04-2012, 10:06 AM   #26
raptor1956
Fan#: 97725
What I Drive: 2012, Sonic Blue, Focus Titanium
Points 4,286, Level 41
Points: 4,286, Level: 41 Points: 4,286, Level: 41 Points: 4,286, Level: 41
Level Up 68% Completed
Forum Activity 4%
FF Reputation: 1 raptor1956 Good Standing Member
18-inch wheels.
Tony
Yeah, the price you pay for the handling package is very tempting, but as you correctly point out the tires alone are in the $300/ea range so when you have to replace them...
It was for that reason more than any other that I changed my order to delete the handling package. Between the much higher replacement costs for the tires and the lower mpg the cost, figured over 100,000 miles, would be several thousand more for the 18's over 17's and that's if your're careful and don't f'up your rims...
Brian
raptor1956 is offline
Old 06-04-2012, 10:43 AM   #27
DrkKnight614
GO Green
DrkKnight614's Avatar
Fan#: 14522
Points 25,851, Level 96
Points: 25,851, Level: 96 Points: 25,851, Level: 96 Points: 25,851, Level: 96
Level Up 51% Completed
Level up: 51% Level up: 51% Level up: 51%
FF Reputation: 47 DrkKnight614 Great Standing Member
Posted via FF Mobile You go by what is the recommended tire inflation, which should be in your manual and on the door frame sticker. I doubt it is 45, sounds way over inflated. Check what its supposed to be and deflate immediatly before you mess up your tires. Your pretty much riding on the center of your tires now and the outsides arent even touching the ground.
DrkKnight614 is offline
Old 06-04-2012, 10:57 AM   #28
jvillareal78
jvillareal78's Avatar
Fan#: 95766
What I Drive: 2012 White Platinum Titanium HB
FF Reputation: 1 jvillareal78 Good Standing Member
You should always use the tire pressure indicated on the door or manual for that specific car. The pressure indicated on the tire itself is the max that tire should ever be at.
jvillareal78 is offline
Old 06-04-2012, 03:22 PM   #29
dyn085
That Guy
dyn085's Avatar
Fan#: 98047
What I Drive: 2014 FiST/FoST
Points 25,182, Level 95
Points: 25,182, Level: 95 Points: 25,182, Level: 95 Points: 25,182, Level: 95
Level Up 84% Completed
Forum Activity 4%
Tire inflation is another crazy argument. I keep mine at 3 over all of the time. Makes the ride more firm and has a positive (negligible) difference on mileage. Numerous threads on it.
A for the handling package, I have it on my Ti. I also had a SEL for a month. The difference is substantial. The SEL was way more comfortable, yet stable. The Ti is very firm. I keep the PS3's at 42. I don't know just how bad/many potholes you have, but I would use extreme caution. There is a section of road that just got re-worked on my commute that sounds like I am running over a 4" curb head on. I actually have to slow down for it. And there are also mixed reviews on their road noise. Mine are loud, but only above 65. But I absolutely love how the car rides with the handling package.
One final note, the PS3's will probably only last for about 30k. Something to keep in mind for over $1k tires.
dyn085 is offline
Old 06-04-2012, 04:34 PM   #30
raptor1956
Fan#: 97725
Forum Activity 4%
I think I'd lower the tire pressure a tad from 42 down to, say, 38. Actually, I think if I were running 18's at 235 wide I'd be closer to 35. There would be a small difference in mileage but it would be a more comfortable ride with nearly optimal handling. It might also make those expansion grooves a little less bone shaking...
Brian
