2012 Mudflaps - aftermarket? - Page 2 - Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum
Old 06-06-2011, 09:30 PM   #11
2012silversel
2012silversel's Avatar
Fan#: 83969
What I Drive: 2014 C-Max Energi, Sterling Gray
Points 1,963, Level 26
Points: 1,963, Level: 26 Points: 1,963, Level: 26 Points: 1,963, Level: 26
Level Up 63% Completed
FF Reputation: 1 2012silversel Good Standing Member
I posted pics in the Gallery showing my splash guards. They are located under: North American Models, 2012 5-Door, 2012 Splash Guards.
2014 C-Max Energi
302A Package
Sterling Gray
2012silversel is offline
Old 06-07-2011, 01:35 AM   #12
Ohuigin
Ohuigin's Avatar
Fan#: 83056
What I Drive: 2012 Grey Metallic Titanium Hatch
FF Reputation: 3 Ohuigin Good Standing Member
For the life of me i can't find these pics. Can you post a link to the thread please?
Thanks!
-B
2012 S. G. Metallic Titanium Hatch - Born on 5/10/11
Options / Customizations:
-Handling Package
-Debadged
Ohuigin is offline
Old 06-07-2011, 06:39 AM   #13
2012silversel
Fan#: 83969
Thanks!
-B
They are still pending approval in the gallery. I'm not allowed to post attachments to my posts. Help me out, how do you attach pics directly to a post?
2014 C-Max Energi
302A Package
Sterling Gray
Old 06-07-2011, 01:40 PM   #14
Ohuigin
Ohuigin's Avatar
Fan#: 83056
The easiest way to do it is create a free photobucket account here:http://photobucket.com/
Then upload photos to that website. Once the image is uploaded, simply copy the IMG code and paste in into your FF reply.
Let me know if you need more help.
-B
-Handling Package
-Debadged
Ohuigin is offline
Old 06-07-2011, 02:57 PM   #15
BabyDavid
Fan#: 85554
What I Drive: Kona Blue Hatchback 2012
FF Reputation: 1 BabyDavid Good Standing Member
The OEM's may be a little more pricey but they fit good, all the holes line up so no drilling and install very easily. I ordered mine through www.fordparts.com and the total before tax was $74.98 for a front and rear set. Plus, they don't look like an after thought, they look like they belong on the car.
Well I think these would be the way to go too. I only said they were pricey because the Exterior Protection Package costs $245!
Would you please post up the parts# you bought for your 5-door. Are they the same as the ones shown for the Exterior Protection Package?
Furthermore, I just got back from a road trip in a different hatchback. My buddy's hatch didn't have protection whereas mine has OEM splash gaurds. The side of his car was splattered with tar and mud whilst mine had a distinct line where the grit had been blocked.
BabyDavid is offline
Old 06-07-2011, 08:52 PM   #16
2012silversel
Fan#: 83969
Let's see if this works. Here are three shots of the splash guards. Now, how do I post them as pics and not links?
http://www.flickr.com/photos/18305761@N00/5806198227/
http://www.flickr.com/photos/18305761@N00/5806198191/
http://www.flickr.com/photos/18305761@N00/5806762078/
2014 C-Max Energi
302A Package
Sterling Gray
Old 06-08-2011, 08:10 AM   #17
2012silversel
Fan#: 83969
Let's see how this works...
2014 C-Max Energi
302A Package
Sterling Gray
Old 06-09-2011, 02:05 AM   #18
Ohuigin
Ohuigin's Avatar
Fan#: 83056
You got it Silver! These actually look ok! Don't seem to mess up the flow of the lines at all. Darnit! Gotta save up some $$ now!!!
-B
-Handling Package
-Debadged
Ohuigin is offline
Old 06-09-2011, 12:07 PM   #19
kilcher
kilcher's Avatar
Fan#: 85597
What I Drive: 2012 SE Hatch (red)
FF Reputation: 1 kilcher Good Standing Member
Those look real nice! I've never done these before, if I buy the OEM mudflaps do they just screw into pre-existing holes?
kilcher is offline
Old 06-09-2011, 01:44 PM   #20
2012silversel
Fan#: 83969
Installation is really easy. You remove the existing plugs and install plastic pop rivets that get hammered in. All the holes match up, one hole needs to be drilled.
Edit: Installation steps:
Fronts:
Remove tire
The instructions will show which rivets to use in which holes
Pry out 3 wheel well liner plugs and anchors and the plug and anchor under the car holding the front of the plastic scuff guard (I also tightened 3 Torx screws supporting the wheel well liner with a 5/32 allen wrench)
Fit guard and install top plastic pop rivet, hammer in the rivet to hold the guard in place. Install the other two rivets. You may have to support the wheel well liner when hammering the rivets, there's some bounce back
Install pop rivet under the car
Drill a 15/64 (6mm) hole through the existing inner most hole on the guard and install the final rivet. My cordless drill did not fit between the brake disk and the wheel well liner so I had to drill at an angle, seems OK though. A small right angle drill will work great.
Rears:
Remover tire
Remove two Torx screws with a 5/32 allen
Slip screw clip on to soft felt liner material lining it up with the existing hole
Fit guard and install Torx screws and screw into screw clip
Install pinch clip at the tab and push like hell or hammer into place
Now repeat on the other side of the car and your done.
2014 C-Max Energi
302A Package
Sterling Gray
